Old Jun 08, 2008, 09:55 PM
Trackercal is offline
Find More Posts by Trackercal
Trackercal's Avatar
United States, OR, Bandon
Joined Apr 2007
Show us your FPV / RVP ground Base set up in action
Show us your FPV / RVP ground Base set up in action. Don't know if this has been done yet. But it would be nice to see different photos of ways everyone sets up their ground base equipment to fly their Aircraft.
Thanks for any info on this.
Trackercal
Trackercal is offline Find More Posts by Trackercal
Old Jun 08, 2008, 10:44 PM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Here's my older setup when I first started out. GPS Tracking, 2.4ghz downlink. On screen Monitor plus Video Goggles..
The other one is a quick setup I did for my 900mhz rig. I've since changed it a bit after the 'accident'.
typicalaimster is offline Find More Posts by typicalaimster
Old Oct 04, 2008, 03:02 PM
sergio00 is offline
Find More Posts by sergio00
sergio00's Avatar
Spain / Argentina
Joined Mar 2007
My new base:
Case: Pelican 1550
Display: 7" Farenheit T-7000MHR with 450cd/m2
Googles: z800
Vga converter: Gadmei TV5821G ( better quality than the old 3300 ). No blue screen
Recorder: Sony MC1 DVD
Battery: 12V 7A lead in the case, under the control panel
Note: photos taken with my movile
sergio00 is offline Find More Posts by sergio00
Old Oct 04, 2008, 04:03 PM
CATPart is offline
Find More Posts by CATPart
CATPart's Avatar
Joined Mar 2008
My setup is very simple. Everything fits in the plastic container (radio, goggles, tools, diversity, receivers, antennas). 100 foot extension cord attaches to the car battery to power my ground equipment. The antennas just hang over the side of the container and sit on the ground.
CATPart is offline Find More Posts by CATPart
Old Oct 04, 2008, 04:24 PM
IanJ is offline
Find More Posts by IanJ
Aberdeen, Scotland, UK
Joined Dec 2007
Hi all,
Here's my base station, comprising:-
2.4ghz 9dBi omni with integral receiver in the home made base stand.
8" LCD monitor and an Archos 605 for recording.
There's a video hub hidden in the case which takes the signal from the receiver and buffers it to the 8" LCD and Archos.......I found that too much loading on the video signal deteriorates the signal.
All powered from a 12v 17AH "car start" batter unit.
The alloy case has a portable shroud to keep the sun out.
I also have a helmet/goggles setup which comprises a head movement sensor, 640*480 goggles and an integral receiver hidden in the lining of the helmet and connects to a 9dBi omni antenna poking out through a hole in the top of the helmet.
It's all wireless apart from the line to the trainer conn of my radio (for pan/tilt).
IanJ is offline Find More Posts by IanJ
Old Oct 04, 2008, 06:28 PM
JustinONE is offline
Find More Posts by JustinONE
Torrance
Joined Feb 2005
are you guys powering your goggles from the lithium cell that came with them or are you using a larger power supply system to run everything?
JustinONE is offline Find More Posts by JustinONE
Old Oct 04, 2008, 07:13 PM
hoysome is offline
Find More Posts by hoysome
hoysome's Avatar
Alberta, Canada
Joined Jun 2008
I run mine on a set of lipos running through an anyvolt micro. my HDV camera runs on the same AVM through a second cable. (both run on 5v)
hoysome is offline Find More Posts by hoysome
Old Oct 05, 2008, 12:04 AM
massimo is offline
Find More Posts by massimo
massimo's Avatar
Joined Nov 2001
Originally Posted by sergio00
My new base:
Case: Pelican 1550
Googles: z800
waww nice converter Sergio
massimo is offline Find More Posts by massimo
Old Oct 05, 2008, 03:32 AM
IanJ is offline
Joined Dec 2007
I have thrown away the battery unit that came with them and run via a lipo on the side of the helmet that also powers the receiver. No more fiddling for the power switch etc etc.
Ian.
Old Mar 20, 2009, 06:25 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Nice i just redid my ground station a few days ago and will post soon. All i need now is one large battery like yours instead of a whole bunch individually powering everything.
Originally Posted by cfe7
This is my latest creation. I spent almost a year thinking and planning before I ended up with this kind of coarse made plywood box. Everything made with KISS in mind.
I also made a 4 meter extension cable for the goggles so that I can locate the box (and receivers) where I get the best reception.
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Mar 20, 2009, 06:44 PM
pandauric is offline
Find More Posts by pandauric
Joined Nov 2007
FPV Camera Backpack Portable Ground Station
Here are a few pictures of my portable FPV ground station. I bought an inexpensive camera backpack off of ebay and converted it into what you see here. I also use a small storm case (bought off ebay too) to carry around a few of the other items I need.
pandauric is offline Find More Posts by pandauric
Old Mar 20, 2009, 08:31 PM View Post
Defacto
A moderator felt this post violated the following rule: Cross-posting. It is temporarily hidden while Defacto edits it. Show it to me anyway.
Old Mar 20, 2009, 11:43 PM
WTurbiasz is offline
Find More Posts by WTurbiasz
Tree Flyer
WTurbiasz's Avatar
Albany NY
Joined Feb 2005
You already got an answer no need to ask the same question all over the forum.
http://www.rcgroups.com/forums/showt...5&page=4&pp=50
Tek
WTurbiasz is offline Find More Posts by WTurbiasz
Old Mar 21, 2009, 12:52 AM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
Here's what I usually bring to the field:
- alu tripod to mount the tracking antenna
- camcorder for recording
- ImmersionRC Duo 2400 diversity receiver
- Diversity 11dBi 2.4GHz antenna on pan/tilt mount
- Futaba FF10 with EzUHF transceiver
- Two sets of FatShark goggles
All of that fits inside a medium sized duffle bag, besides the tripod, and hence is pretty easy to carry around.
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Discussion Show us your favourite or best looking/fastest rc thing in here!!! sirAbe Australia 121 Feb 06, 2008 05:40 AM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 07:23 PM
Show us your heli in the snow! uglyplane Electric Heli Talk 17 Dec 11, 2005 01:49 PM
Show us your heli in the snow! uglyplane Fuel Heli Talk 2 Dec 07, 2005 08:35 AM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 10:50 AM
