Old Jan 06, 2012, 09:04 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
yes i know that.. Read again
pavcon is offline Find More Posts by pavcon
Old Jan 16, 2012, 04:10 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
http://www3.towerhobbies.com/cgi-bin...?&I=LXWGR1&P=M
StarHopper44 is offline Find More Posts by StarHopper44
Old Jan 18, 2012, 05:44 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
I just ordered 5.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jan 19, 2012, 02:33 AM
pavcon is offline
Joined Jan 2010
2 for me.. I just need one anyway..
Old Jan 20, 2012, 05:15 PM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Originally Posted by billpa View Post
I just ordered 5.
dont you already have a stash hidden somewhere
freshmint is offline Find More Posts by freshmint
Old Jan 24, 2012, 12:39 PM
FTA_FTW is offline
Find More Posts by FTA_FTW
FTA_FTW's Avatar
Joined Apr 2011
Originally Posted by freshmint View Post
You can use the airspeed unit on any rx
What airspeed unit are you referring to? And are you talking about a spektrum rx?
FTA_FTW is offline Find More Posts by FTA_FTW
Old Feb 26, 2012, 11:59 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
OK I realize that AirSpeed Sensor is effected by the wind and that accurate ground speed readings can not be expected flying with or into the wind however how much effect does a cross wind at say 90 degrees to the flight path effect the readings?
Bill If you happen to read this yes I am still around and still flying. A couple of speed test runs this morning using the ET Airspeed Micro Sensor V3 in a wing I am playing with prompted this question.
Charles
Old Feb 27, 2012, 05:29 AM
garris2 is offline
Find More Posts by garris2
Australia, VIC, Glen Waverley
A crosswind won't affect your airspeed at all.
Your aircraft doesn't know how hard the wind is blowing or from what direction.
If you fly (relative to you) upwind and downwind at the same throttle/level flight setting your aircraft will have the same airspeed in both directions.
Of course the ground speed will change by the amount of the wind speed plus the airspeed in the downwind direction, and wind speed minus the airspeed in the upwind direction.
If there is cross wind (relative to you) the ground speed will vary plus or minus by the vector of the wind relative to you but the airspeed of the model at the same given throttle/level flight, will remain the same.
Geoff
garris2 is offline Find More Posts by garris2
Old Feb 27, 2012, 11:35 AM
Southern Pride
Thank you for the clarification, it seems I have topped out at 76 MPH with my present setup which is not really bad for a 240 watts setup on a 30" ,228 sq.in. 11.5 oz. combat flying wing.
Charles
Old Feb 27, 2012, 06:25 PM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
?v=
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Mar 17, 2012, 11:44 AM
AlGerbens is offline
Find More Posts by AlGerbens
AlGerbens's Avatar
United States, AZ, Mesa
Joined Feb 2007
Altimeter V3 Drift
Here's a graph from datalogger v4 and altimeter v3.
The aircraft is a quad copter.
The graph covers two ascents to about 30 feet over a short period of time, you can see the ascents in the current plot.
Is the recorded altitude shift over this time period typical?
AlGerbens is offline Find More Posts by AlGerbens
Old Mar 21, 2012, 02:58 PM
Thierry Platon is offline
Find More Posts by Thierry Platon
Joined Jun 2006
Hello
I got an Elogger V4 with speed, altimeter,GPS and G's sensors. My aim is to make measurements on F3F gliders and to use recorded data to compute aerodynamic parameters as CL.
G's sensor works very well and gives good dynamic measurements
GPS works as expected. With numerous GPS loss when rolling and making tight turns ( I never imagine anything else on a carbon gliger making F3F runs !).
But I'm disapointed by the poor dynamic behaviour of airspeed and altitude sensors. Filtering is very important and is not adapted to any dynamic flying including F3F. ( This fliltering seems specially adapted to calm thermaling)
When I submit the altimeter to a sudden depressure (to simulate a high climbing rate) it takes more than 0.5 s to reach the new altitude. Then when the depressure is stopped, the altitude reached is latched during about 2 s or more before begining to decrease to zero. Decreasing takes more than 0.5s.
The airpeed sensor has exactly the same behaviour which is not suited at all to make measurements on dynamic flights.
I tested the dynamic response of these sensors on my F3F plane by making aerobatics and more specifically by making several consecutive loops. Maximum/minimum G's should correspond to maximum/ minimum airspeed and to minimum/maximum altitude. In fact records show more than 2s delay beetwen maximum/minimum G's and maximum/minimum airspeed or altitude!
Moreover altitude and speed variations seems much reduced compared to reality. Consequently it seems impossible to make usable CL calculation. Computed CL during loops can reach more than 2 or 3 !!!
So my questions are :
Is it possible to modify or to suppress the filtering ?
(I would prefer to make my own post filtering on raw data with Excel)
What is the filtering algorithm ? Is it possible to make a reverse computation to reduce filtering ?
TP
Thierry Platon is offline Find More Posts by Thierry Platon
Old Mar 30, 2012, 02:54 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Thierry,
Yes, here are a couple of things you can do:
1) I'd recommend logging at 50Hz, if you are not doing so already.
2) Under "advanced, custom hardware options" click "I wish to turn off averaging/smoothing of downloaded data".
let me know how this goes.
Site Sponsor
Old Mar 31, 2012, 08:18 PM
Joined Oct 2006
my altimeter took a plung into salt water, I headed back to get a raft. and retrieved my plane. about a few hours later, Lip expanded. 808 keychain cams DO, and returned home cleaned up blew everyting off with a blower, what are my chances that hte Altimeter will work?
BAM! 1 -1-4-3--1-1-4-3...... how sweet it is. have not yet gone back up t osee ifit registers a new height. thank you Eagle treefor making it pritty much water tight. clearly said in the manual.....
I had seen my unit start to work at 59 feet, where as 60 feet is the actual start to read height. not just when you hit the highest. ilike to see it read all levels, and when after 10 seconds of stand still read the highest height reach. for expple
flying 60, 65,70,100, 90,110,75,60,... landed picked unit says 110. this way when a cam is on youactually see the heights flown, after max height reached.
Old Apr 01, 2012, 02:30 PM
Joined Jun 2006
Hi Thierry,
Thank you very much Bill.
I was already logging at 50hz. Switching the averaging off seems to fix the issue. I will try it in fly the next week-end.
TP
Discussion New Standalone Altimeter and Airspeed Sensors from Eagle Tree! billpa Product Announcements 0 Jun 06, 2008 12:29 PM
For Sale HiMax Brushless Motors BLOWOUT starting at $29.99 realdeal Aircraft - Electric - Power Systems (FS/W) 0 Feb 17, 2006 03:51 PM
For Sale Rocket brushless motor/ESC COMBO deals starting at $49.99 FREE SHIPPING! realdeal Aircraft - Electric - Power Systems (FS/W) 4 Nov 27, 2005 07:11 PM
Gain Altitude, Airspeed and Ideas at the same time, "IN A HURRY or NOT ". WagMax 2 rparigoris Foamies (Kits) 2 Aug 11, 2002 08:59 PM
FS-Sky Skooter at 109.99 mmm208 Aircraft - Electric - Airplanes (FS/W) 3 Aug 07, 2002 12:42 PM
