Old Dec 26, 2012, 11:03 PM
iskoos is offline
Find More Posts by iskoos
Orlando, FL
Hi billpa tkeeg (Tom),
I was going to ask a similar question. I have been using altimeter microsensor V3 for couple years now. I have to tell you that I wasn't impressed very much. Most of the time, I get very unreliable readings. Like I take off (I fly heli or multicopters) from a spot when it reads around 0,1, or 2 feet and when I land at the same spot it reads -20 feet. I always let it sit so it can adjust to outside temperature but it doesn't seem to help much.
I know this unit is sensitive to sudden temperature changes but whether or not the temperature changes significantly in the air is beyond my control.
Now, I got altimeter V4 and I am hoping that this will work better. We will see...
Bill, On V4, I see that the pressure sensor is under the clear shrink wrap. There is no direct opening to outside.
On the other hand, V3 models had pressure sensor enclosure that has a direct opening (a hole similar to pitot tube) to outside.
Is this the main difference between the 2 versions? Are the pressure sensors same or different?
iskoos is offline Find More Posts by iskoos
Old Dec 27, 2012, 05:26 PM
tkeeg is offline
Find More Posts by tkeeg
Multi-Rotor Pilot
tkeeg's Avatar
Trenton, NJ
Joined May 2008
Hi Iskoos,
I'm glad to see that I am not the only person with a V3 altimeter that works inaccurately! Not only one of them but both of my V3 altimeterís are substantially inaccurate.
Like you, I also ordered a V4 altimeter, hoping that that it will work better. It should be arriving within the next day or two.
Please post how your V4 works for you.
Regards,
Tom
PS: Bill, thanks for your reply to my earlier question.
tkeeg is offline Find More Posts by tkeeg
Old Dec 28, 2012, 04:33 PM
billpa is online now
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
iskoos, the barometric sensor used in the altimeter V4 is far superior to the one in the V3. I think you will be delighted with its performance.
In the last 2-3 years, there's been a revolution in mems sensing technology and cost. We should all have a shrine in the corner to cellphone manufacturers for driving costs lower and performance higher for baro sensors, gyros, accelerometers, and magnetometers.
billpa is online now Find More Posts by billpa
Site Sponsor
Old Dec 28, 2012, 11:56 PM
iskoos is offline
Orlando, FL
Thanks Bill. I haven't tried it yet but I am glad the pressure sensor is much better in V4. This will give me hope)) I got your reply to my other post on how to switch from V3 to V4. I will do as you recommended and give it a shot. I am hoping that I will see some improvement.
And Tom, I will post my findings here once I do the test flight. I have the unit in my hands already
Old Jan 01, 2013, 09:42 PM
tkeeg is offline
Multi-Rotor Pilot
tkeeg's Avatar
Trenton, NJ
Joined May 2008
Iskoos,
I had a chance to test out the altimeter V4 module and I must say that I am very impressed with it. It is a HUGH improvement over the crappy V3 module. This V4 is accurate enough to make me happy!
I loosely wrapped it in a bit of porous cloth & stuck it out of any direct airflow and it seems to be accurate to within a couple of feet in most instances and sometimes is seems to be accurate to the exact foot.
Tom
Old Jan 01, 2013, 10:47 PM
zl3vml is offline
Find More Posts by zl3vml
Sir Jasper
zl3vml's Avatar
Christchurch - New Zealand
Joined Jan 2003
I am confused. I thought that you had to fly to at least 50' before it would register and provide a new reading? Whenever I power mine on it shows the previous reading, so theoretically it will never show a reading below 50' anyway....
Mark
zl3vml is offline Find More Posts by zl3vml
Old Jan 03, 2013, 06:44 AM
tkeeg is offline
Multi-Rotor Pilot
tkeeg's Avatar
Trenton, NJ
Joined May 2008
Mark
Mark,
I am a novice with Eagle Tree Products, but a few years ago when I used to use the V3 altimeter as a standalone unit, (without the OSD Pro), it would immediately show the top altitude of my last flight as soon as I powered it up. I don't remember if I had to go past a certain altitude for it to register my current flight.
With the V4 altimeter hooked up through the OSD Pro, every flight starts off at, or near, 0 feet.
I donít know why someone from Eagle Tree didnít answer your question as this thread is in their Vendors Section of RC Groups.
Tom
Old Jan 03, 2013, 10:57 AM
zl3vml is offline
Sir Jasper
zl3vml's Avatar
Joined Jan 2003
Oh. OK. Thanks for that info Tom. Does the V4 start off and show 0' in stand alone mode as well or does it need to be hooked up to the OSD unit for that?
I use them in my Vintage models and they work great in stand alone mode so I don't need the OSD units, but it would be great for them to start off at 0 each time.
Mark
Old Jan 03, 2013, 02:51 PM
billpa's Avatar
Joined Nov 2003
Hi Mark,
The V4 has the same behavior in standalone mode as the V3 (reset at about 50 ft). This is to help ensure that max reading doesn't get inadvertently erased. Is the issue that you sometimes fly where your max altitude is less than 50'?
Site Sponsor
Old Jan 04, 2013, 02:25 AM
zl3vml is offline
Sir Jasper
zl3vml's Avatar
Joined Jan 2003
Nope, just curious since I want to get another unit and was not aware of the added functionality.
Thanks for the info.
Mark
Old Jan 17, 2013, 12:06 AM
iskoos is offline
Orlando, FL
Originally Posted by tkeeg View Post
Iskoos,
Tom
Hi Tom,
Finally past Saturday (Jan 12th), I made the switch per Bill's directions
(it is here: http://www.rcgroups.com/forums/showthread.php?t=1795907).
The switch went through w/o a glitch. I then took my multicopter to a test flight. It is like you and Bill said, this V4 altimeter is lightyear ahead of the V3 altimeter. Accuracy is within a few feet (or even better in some cases). There is no more sudden fluctuation/jump in this V4 sensor. The altitude value increases or decreases uniformly. And when you land at the spot you took off, you don't see crazy difference like I would with V3 altimeter.
So now the question is What to do with the V3 Altimeter?
Old Jan 21, 2013, 05:03 AM
goryc is offline
Find More Posts by goryc
Italy, Sicilia, Messina
Joined Apr 2011
I wanted to change the unit of measurement of Altimeter V4 (ft vs meters) and I made ​​the mistake of making this connection (wrong).
I'm correct, I made the right procedure and the right connection, and now the first flash I "1" and then flashes twice "0".
I also tried to read the OSD Display the values ​​and look right.
What harm could I have done?
goryc is offline Find More Posts by goryc
Old Jan 21, 2013, 08:39 PM
billpa's Avatar
Joined Nov 2003
Gory, as long as the altimeter is still functional with the OSD/eLogger, it was not damaged. I suspect it will be ok.
Site Sponsor
Old Jan 21, 2013, 11:10 PM
goryc is offline
Joined Apr 2011
"Fiuu....", thankfully! Now I have to try it in flight and then tell you. Thank you
Old Jun 12, 2013, 03:04 PM
Frank.T is offline
Find More Posts by Frank.T
Frank.T's Avatar
Netherlands, ZH, Rotterdam
Joined Jul 2010
I just bought the Altitude Microsensor V4 and IMO it is not working good (or my misunderstanding).
When power it on and look on the PC Data recorder and move the sensor up and down 15 meters I don't see any movements on the gauges or graph in live mode.
Even the display on the sensor is only blinking a zero.
Question, is the unit defect or is it only showing something above a certain height??
//Frank
Frank.T is offline Find More Posts by Frank.T
Discussion New Standalone Altimeter and Airspeed Sensors from Eagle Tree! billpa Product Announcements 0 Jun 06, 2008 12:29 PM
For Sale HiMax Brushless Motors BLOWOUT starting at $29.99 realdeal Aircraft - Electric - Power Systems (FS/W) 0 Feb 17, 2006 03:51 PM
For Sale Rocket brushless motor/ESC COMBO deals starting at $49.99 FREE SHIPPING! realdeal Aircraft - Electric - Power Systems (FS/W) 4 Nov 27, 2005 07:11 PM
Gain Altitude, Airspeed and Ideas at the same time, "IN A HURRY or NOT ". WagMax 2 rparigoris Foamies (Kits) 2 Aug 11, 2002 08:59 PM
FS-Sky Skooter at 109.99 mmm208 Aircraft - Electric - Airplanes (FS/W) 3 Aug 07, 2002 12:42 PM
