Go Back   RC Groups > Vendors > Hitec/Multiplex USA
Old Jun 06, 2008, 08:54 AM   #1
on a vacation
Multiplex EVO Recall
In regards to the MPX recall for EVO, will Hitec in CA handle this recall for the U.S. MPX customers?
thanks
LouieB is offline Find More Posts by LouieB   Reply With Quote
Old Jun 06, 2008, 11:14 AM   #2
Hitec service
BRENDAN LUGO's Avatar
The recall does not apply to or affect any of the U.S. Evo units.
BRENDAN LUGO is offline Find More Posts by BRENDAN LUGO   Reply With Quote
Old Jun 06, 2008, 11:23 AM   #3
on a vacation
Thank you Brendan. You may want to state this in the Radio forum. There is a thread started there concerning this issue.
thanks
Old Jun 06, 2008, 02:33 PM   #4
My Evo 12 was bought in the US and I just wonder why the US models do not need to be overhauled as I am also using it in 35mgh...
Gustave Flaubert is offline Find More Posts by Gustave Flaubert   Reply With Quote
Old Jun 06, 2008, 02:47 PM   #5
Hitec service
The components in question are not used with the 72 mhz versions of the Evo.
Old Jun 06, 2008, 02:52 PM   #6
Ok thank you Brendan for telling me as I was ready to send it to Germany.
Old Jun 06, 2008, 02:58 PM   #7
MPX Recall
I just got off the phone with service rep in California. The recall does not apply to 72 Mhz systems sold in the U.S.A.
The parts in question are only in the European modules.
Jim
jimw1 is offline Find More Posts by jimw1   Reply With Quote
Old Jun 06, 2008, 03:45 PM   #8
<- Balsa flies better ->
wolw's Avatar
Send a message via ICQ to wolw
Correct me if I'm wrong, but aren't the basic Evo's all the same ?
In Europe you can buy them without module and put in whatever you like and a lot of them has gone on export out of EU. It's the module you put in that decides if it's 35/36/40/41/72MHz / 2.4GHz.
If it's the module that need service why send the whole Tx and not only my 35MHz HFM-S module ?
Peter
wolw is offline Find More Posts by wolw   Reply With Quote
Old Jun 06, 2008, 05:23 PM   #9
The Revegetator
Chris F's Avatar
Peter
Good question. I bought my Evo from Germany and my 36 MHz module from Australia. Why would an Evo with a 72 MHz module be any different?
Chris F is offline Find More Posts by Chris F   Reply With Quote
Old Jun 07, 2008, 03:40 AM   #10
I am wondering too why my tx should avoid the overhaul ? Just because it's on 72mgh and I bought it in the US ? If it's the hf module only why sending the whole radio and should I send to Multiplex my 35mgh cristal module ? This does not make much sense and we do need more information....
Old Jun 07, 2008, 09:06 AM   #11
on a vacation
Yes, I am curious about this as well. My understanding is that all the EVOs are made in the Phillipines so, are U.S. radios made in the Phillipines and European radios made elsewhere?
If all radios are made in the same factory then the recall should be for a know set of serial numbers and not just radios sold in Europe. Why send in the entire radio when the problem is the HF module?
Something is not adding up here.
Old Jun 07, 2008, 10:54 AM   #12
The problem is problem in the FM module and not on the mainboard. AT least now I don't have to worry about sending mine in.
chewy
chewytm is offline Find More Posts by chewytm   Reply With Quote
Old Jun 07, 2008, 02:44 PM   #13
on a vacation
chewy
Then why not send in just the FM module. I can understand that the problem may only involve the European frequencies but why send in the entire transmitter. Now if there have been evidence of the module causing problems on the mainboard then that would be a real good reason to send the tx in.
While we are not owed a full explaination from MPX about the recall it would be nice if they did give a full disclosure instead of the terse statement that they made.
Old Jun 07, 2008, 07:36 PM   #14
Got me wondering now as well. My Evo was purchased in the USA with a 72 MHz synth module, but I operate it with a 35 MHz module purchased in the UK.
What do I do?
aragon is offline Find More Posts by aragon   Reply With Quote
Old Jun 08, 2008, 03:47 AM   #15
And which module is supposed to cause troubles : the synth or the analogic one ? In 35 I have the analogic or whatever its name !
Multiplex EVO Tutorial Joedy Radios 586 Mar 21, 2005 08:17 AM
Help! Multiplex EVO interface cable? DeuceTrinal Radios 44 Jan 20, 2004 02:38 PM
Is Multiplex Evo 9 Synth available? Bart Vaio RCSE 0 Dec 19, 2003 02:33 PM
Multiplex Evo gldr guy RCSE 8 Nov 10, 2003 06:21 PM
Multiplex Evo transmitter Maarten rec.models.rc.air 3 Jan 21, 2003 02:52 PM
Congratulations SimpleM!
