| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#556 |
Clippern RC
One possibility might be to put a servo in each wing connected to the air brakes so you get a nearly gap-free linkage.
The white plastic thing connecting the push rod in the body, I think is not so good. It is a little backlash. I have now cut off the nose of my plane. I've turned the motor shaft to the engine and now I'll make an adapter plate to the engine mount. Adapter plate will be glued to the hole in the nose. We turn the motor shaft so the engine mount should be at the front, otherwise it is a bit into the nose and becomes less stable, especially if you happen to make a landing on the nose. Last edited by smajly; Sep 21, 2009 at 05:28 PM. |
#557 |
Fast and low!
what kind of edf is needed for the power pod?
#558 |
Did you get any information on the motor speed control setup for the power pod on the Ventus- 2HX 2600mm
| Thread Tools | |
| For Sale Giant Scale CMPro Cessna Skylane ARF 140 - 83" (ARF) | bcdiscount | Aircraft - Fuel - Airplanes (FS/W) | 0 | Nov 12, 2007 11:14 AM |
| Question CMPro Cessna-182 ARF 46~50 | smbc | Glow to Electric Conversions | 5 | Aug 25, 2007 03:21 AM |
| Sold NIB CMPro F6F HELLCAT ARF | punkindrublik | Aircraft - Fuel - Airplanes (FS/W) | 5 | Nov 07, 2005 06:08 PM |
| Sold NIB CMPro F6F HELLCAT ARF | punkindrublik | Aircraft - Fuel - Airplanes (FS/W) | 1 | Oct 14, 2005 08:12 PM |
| Sold NIB CMPro F6F HELLCAT ARF | punkindrublik | Aircraft - Fuel - Airplanes (FS/W) | 4 | Oct 08, 2005 09:30 PM |
