Go Back   RC Groups > Aircraft - Sailplanes > Scale Sailplanes
Old Jun 07, 2008, 03:51 AM   #16
Scale Nazi - apparently......
salisbug's Avatar
Good work Jase,
I've been exercising every ounce of willpower I have to resist buying this one.
Is it me or does this model have the (same) slanted fin that the Discus had? (especially evident in your last photos).
I like the plastic bits - from the photos they look very nicely done.
Q - how do the tips compare in plastic as opposed to the ill fitting glass ones in the previous kits?
Can you imagine the riducule we are gunna be subjected to with these baby models at a VARMS aerotow? Bring it on!
salisbug is offline Find More Posts by salisbug   Reply With Quote
Old Jun 07, 2008, 05:31 AM   #17
Magic Blue Smoke costs to much
jason H's Avatar
They look the same but when you have them both side to side they are different, not just the fins but also the hole fuze.
With regards to the "tips" I don't know as my Discus has wood tips. But the Ventus tips look very nice.
  • Name: Ventus Discus tail.jpg
Description: Also not the top of Ventus fin, It can be seen just above the Discus's rudder. Also not the top of Ventus fin, It can be seen just above the Discus's rudder. 48.3 KB · Views: 712
  • Name: Ventus Discus top shot.jpg
Description: Wing roots on Discus are bigger and the Ventus as a longer tail moment. Wing roots on Discus are bigger and the Ventus as a longer tail moment. 53.4 KB · Views: 778
  • Name: Ventus Discus side shot.jpg
Description: Canopy on the Discus is longer and also is alittle longer in the nose. Canopy on the Discus is longer and also is alittle longer in the nose. 69.0 KB · Views: 901
jason H is offline Find More Posts by jason H   Reply With Quote
Old Jun 07, 2008, 06:19 AM   #18
Originally Posted by salisbug
Good work Jase,
Hey there Glen you can always electric aerotow on Sunday at the Feild Col and I had a crack at it last weekend with good sucess and even Max aproved.
Big Nuts 181 is offline Find More Posts by Big Nuts 181   Reply With Quote
Old Jun 07, 2008, 09:48 AM   #19
Swamp Slopester
Swampster53's Avatar
Hey Jase, when we opened the box and pulled out the Ventus fuzz, I could have sworn it was shorter than the Discus. Must've been an optical illusion. I must admit, it looks bloody great and the quality is definately an improvement over the Discus. If you keep getting these new models I can see my wrecks taking longer to get repaired and back in the air. I might have to start getting a few newies too!!
Swampster53 is offline Find More Posts by Swampster53   Reply With Quote
Old Jun 07, 2008, 04:51 PM   #20
jason H's Avatar
Hey there Swampy, don't fear it's sitting on the bench now while I work out a plan of attack.
Old Jun 07, 2008, 07:26 PM   #21
salisbug's Avatar
Aido,
You could always:
a/ stop crashing
b/ learn to repair your own, which may make you want to a/
btw. any bites on the Assassin front?
Sorry for the hijack Gunna
Old Jun 07, 2008, 10:42 PM   #22
excelpoint's Avatar
Thats it I'm in. I'm going to grab one of those Ventus on Tuesday.
Jas. How many servo's all up and what type for what?
excelpoint is offline Find More Posts by excelpoint   Reply With Quote
Old Jun 08, 2008, 12:38 AM   #23
excelpoint's Avatar
Well Jas you had to go and mention aerotow didnt ya. I've just been watchin all the aerotow vids I can and cant wait to give it a go. So where do we find a tow release for these things?
Old Jun 08, 2008, 01:59 AM   #24
jason H's Avatar
Matt,
The Ventus will need 7 srevo'sfor Aerotowing,
2 x Ailerons
1 x Elevator
1 x Rudder
1 x Tow release
1 x Retract
1 x Spoilers
I'm running Craptech HS-56HB's.
Mate the Tow releae is aready installed in the nose, all you have to do is add a servo....
Old Jun 08, 2008, 02:03 AM   #25
jason H's Avatar
Well started work on the Ventus wings today. Haven't done a great deal of work on it as I had other thing that needed doing for the family first but I pan on doing alittle more tonight.
  • Name: Ventus servo's in wing.jpg
Description: Glue aileron servo's in the wing using the old method of masking tape and  epoxy/microballons mix. Glue aileron servo's in the wing using the old method of masking tape and epoxy/microballons mix. 48.6 KB · Views: 1047
Old Jun 08, 2008, 02:07 AM   #26
excelpoint's Avatar
Jas. Will you be using 56's all round? Will the fuze take standards as I have some Hitech digi's that could use a home
Old Jun 08, 2008, 02:13 AM   #27
jason H's Avatar
Next up was the spoilers. The manual calls for the covering to be cut back and sealed over into the cavity before glueing in the spoilers with epoxy. I didn't do that , I really don't like seeing the red of the airbrake while they are closed so I cut the covering back, slide the spoiler into the cavity and CA'ed it in. Then I sealed the covering back over the spoiler housing. The top of the spoiler was then sealed with Profilm to match the top of the wing. Dosen't look to bad, just need to work out some of the air bubbles.
  • Name: Ventus airbrake added.jpg
Description: Covering peeled back and spoiler housing slide in. CA'ed in place with Med Zap. Covering peeled back and spoiler housing slide in. CA'ed in place with Med Zap. 53.5 KB · Views: 1001
  • Name: Ventus airbrake covered closed.jpg
Description: Spoilers finished. Not as neat as a ParaTech scalie but you'll never see it from the air. Spoilers finished. Not as neat as a ParaTech scalie but you'll never see it from the air. 47.7 KB · Views: 1017
  • Name: Ventus airbrake covered open.jpg
Old Jun 08, 2008, 02:17 AM   #28
jason H's Avatar
Yes mate 56's all round but at only 1.2kg's i'm not to shore how about the retract, might be abit light....
She could take standards but I recon you'd be pushing it, Better off sticking with Mini's I think.
Old Jun 08, 2008, 02:20 AM   #29
excelpoint's Avatar
Cool. I was thinking then of going with 56's and maybe an 85mg on the retract.
Old Jun 08, 2008, 02:49 AM   #30
jason H's Avatar
Yer 85 or an 81 maybe what i'll use too.
For Sale Giant Scale CMPro Cessna Skylane ARF 140 - 83" (ARF) bcdiscount Aircraft - Fuel - Airplanes (FS/W) 0 Nov 12, 2007 11:14 AM
Question CMPro Cessna-182 ARF 46~50 smbc Glow to Electric Conversions 5 Aug 25, 2007 03:21 AM
Sold NIB CMPro F6F HELLCAT ARF punkindrublik Aircraft - Fuel - Airplanes (FS/W) 5 Nov 07, 2005 06:08 PM
Sold NIB CMPro F6F HELLCAT ARF punkindrublik Aircraft - Fuel - Airplanes (FS/W) 1 Oct 14, 2005 08:12 PM
Sold NIB CMPro F6F HELLCAT ARF punkindrublik Aircraft - Fuel - Airplanes (FS/W) 4 Oct 08, 2005 09:30 PM
Bored? Want to fight?
Join the RCGroups clan!
