Go Back   RC Groups > Aircraft - Sailplanes > Scale Sailplanes
Old Jun 05, 2008, 04:42 PM   #1
Magic Blue Smoke costs to much
jason H's Avatar
CMPro Ventus 2HX ARF
Well this afternoon after work i'm off to my LHS to pick up a new kit by CMPro, it's the Ventus 2HX. After having and flying the CMPro Discus for over a year now and keeping up with the build thread started by Salisbug here on RCG i'm pretty sure I know what i'm gunna be in for.
Some of the feature that come out with the Ventus as standard is scale airbrakes and a retractable wheel with open and closing retract doors. Here's a link to some pix as there isn't much else I can tell you until I get the model tonight.
http://www.modelflight.com.au/rc_mod...pro_ventus.htm
ps. with all the cheap chinese scalies out there now at 2.6 mtr maybe it's time we had a "Mini Aerotow" day with electric tugs and 2.6 scalies.
jason H is offline Find More Posts by jason H   Reply With Quote
Old Jun 06, 2008, 05:44 AM   #2
jason H's Avatar
Well it's here, I have it....I have pulled all the parts out of the box for alook and all seems fine. As always the model was packed well in the box with lots of light foam wraped around the parts and sealed in plastic bags. I've take a fair few pix for you all to see.
Let the slide show begin.....
  • Name: Ventus box.jpg
  • Name: Ventus box art..jpg
Description: Box Art shows retract, airbrakes and ABS wing tips. Box Art shows retract, airbrakes and ABS wing tips. 74.6 KB · Views: 630
Old Jun 06, 2008, 05:51 AM   #3
jason H's Avatar
Here's afew of the fuze and the formers in the fuze.
  • Name: Ventus Fuze.jpg
Description: Ventus fuze, decals aready added and clear coated over. Glass work seems alot better with this model than the Discus. Ventus fuze, decals aready added and clear coated over. Glass work seems alot better with this model than the Discus. 87.5 KB · Views: 957
  • Name: Ventus fuze rear formers and airbrake mech.jpg
Description: Looking down the fuze at the formers for the airbrake mech, retract bay and wing joiner tube. Looking down the fuze at the formers for the airbrake mech, retract bay and wing joiner tube. 80.8 KB · Views: 1139
  • Name: Ventus fuze front formers.jpg
Description: Looking at the formers in the front of the cockpit. This is where all the servo's live, note bar for aerotow release system. Looking at the formers in the front of the cockpit. This is where all the servo's live, note bar for aerotow release system. 73.9 KB · Views: 837
  • Name: Ventus fuze aerotow nose.jpg
Description: Hole aready in nose for aerotowing, alittle bit ruff but with alittle TLC will come up fine. Hole aready in nose for aerotowing, alittle bit ruff but with alittle TLC will come up fine. 46.2 KB · Views: 926
Old Jun 06, 2008, 05:53 AM   #4
jason H's Avatar
Here's a pic for the Ventus's canopy and cockpit. Not much different here from the Discus.
  • Name: Ventus canopy and cockpit.jpg
Old Jun 06, 2008, 05:58 AM   #5
jason H's Avatar
Next up is some of the fun parts. Here you'll see afew pix of the retract mech and the gear door. Both are made from ABS plastis and seem to be strong although there seems to be alittle slop in the parts. The retract has a good positive lock down feel to it and i doubt that it would close up on landing.
  • Name: Ventus retract wheel and gear door open.jpg
  • Name: Ventus retract wheel and gear door closed.jpg
Description: Here's a shot of the retract mech and the gear door, both in there closed state. Here's a shot of the retract mech and the gear door, both in there closed state. 114.6 KB · Views: 575
Old Jun 06, 2008, 06:06 AM   #6
jason H's Avatar
Well the wings are the same as the Discus, ply balsa built up type covered with white plastic film. The quality is fairly high for such a cheap kit. Note how thin the tip section is, the section they have used looks like it might have a good turn of speed.
  • Name: Ventus wings.jpg
Description: Ventus wings, ply balsa wing and plastic covering. Ventus wings, ply balsa wing and plastic covering. 82.6 KB · Views: 675
  • Name: Ventus wings tip profile.jpg
  • Name: Ventus wing ABS tips.jpg
Description: ABS plastic wing tips, look really sweet although a different shade of white to the wings and stand out abit. ABS plastic wing tips, look really sweet although a different shade of white to the wings and stand out abit. 102.1 KB · Views: 650
Old Jun 06, 2008, 06:10 AM   #7
jason H's Avatar
Well this is a great suprise, CMpro have upgraded the wing joiner bar from a carbon tube as used in the Discus to a 8mm steel rod. This has a much better feel to it and I have aready great faith in the Ventus over the Discus.
  • Name: Ventus steel wing joiner.jpg
Old Jun 06, 2008, 06:13 AM   #8
jason H's Avatar
Here's a pic of the stab and rudder. The Stab is of a built up nature that has a foil built into it.
  • Name: Ventus stab and rudder.jpg
Old Jun 06, 2008, 06:31 AM   #9
jason H's Avatar
The airbrakes are made from ABS also and are of the blade type. These also have a fair bit of play in them but seem to work just fine. The only thing that I don't like about them is when they are in the wing they are red on top, I think that i'll be covering them with white profilm.
  • Name: Ventus airbrakes.jpg
Description: Airbrakes, one open, one closed. Airbrakes, one open, one closed. 110.6 KB · Views: 738
Old Jun 06, 2008, 06:34 AM   #10
jason H's Avatar
Here is the hardware package. Parts seem ok but I think i'll be upgrading some of it to Dubro etc.
  • Name: Ventus instructions.jpg
  • Name: Ventus hardware.jpg
Old Jun 06, 2008, 06:38 AM   #11
jason H's Avatar
The best saved to last, Bench Fly shots. Looks pretty good for a cheap 2.6 scalie.
  • Name: Ventus bench fly 1.jpg
  • Name: Ventus bench fly 2.jpg
  • Name: Ventus bench fly 3.jpg
Old Jun 06, 2008, 07:15 AM   #12
excelpoint's Avatar
Jas. I like the look of that. i might have to get one for myself
excelpoint is offline Find More Posts by excelpoint   Reply With Quote
Old Jun 06, 2008, 08:40 AM   #13
Why is the left wing at such an odd angle? The model looks like it has anhedral in it. ( opposite of dihedral).
s2000 is online now Find More Posts by s2000   Reply With Quote
Old Jun 06, 2008, 08:47 AM   #14
I've got the tug end sorted, are we towing on Monday??
  • Name: 100_2013.jpg
  • Name: 100_2123.jpg
Big Nuts 181 is offline Find More Posts by Big Nuts 181   Reply With Quote
Old Jun 06, 2008, 03:39 PM   #15
jason H's Avatar
Thanx Matty, I think you won't go wrong "Bang for Buck".
s2000- if you are referring to the first photo on post #6 then it's just the camera angle. Look at the pix in post #11, no Anhedral....
Ross- gotta work Monday.
For Sale Giant Scale CMPro Cessna Skylane ARF 140 - 83" (ARF) bcdiscount Aircraft - Fuel - Airplanes (FS/W) 0 Nov 12, 2007 11:14 AM
Question CMPro Cessna-182 ARF 46~50 smbc Glow to Electric Conversions 5 Aug 25, 2007 03:21 AM
Sold NIB CMPro F6F HELLCAT ARF punkindrublik Aircraft - Fuel - Airplanes (FS/W) 5 Nov 07, 2005 06:08 PM
Sold NIB CMPro F6F HELLCAT ARF punkindrublik Aircraft - Fuel - Airplanes (FS/W) 1 Oct 14, 2005 08:12 PM
Sold NIB CMPro F6F HELLCAT ARF punkindrublik Aircraft - Fuel - Airplanes (FS/W) 4 Oct 08, 2005 09:30 PM
Bored? Want to fight?
Join the RCGroups clan!
