Old Jun 05, 2008, 06:16 AM
Astrowall is offline
Find More Posts by Astrowall
Andrew
Astrowall's Avatar
Australia, SA, Paralowie
Joined May 2008
0.46 ASP Engine prop size?
Hi all,
A long long time ago (but in this galaxy).. I bought an ASP 0.46 sized engine (with the red head). Well I have recently discovered that I still have this engine in the possession of someone else who has had it stripped along with some other ASP engines and the parts are in his shed. I am going to give myself a little project and try and get at least one motor working. I am wondering is it an 11x6 prop I use on the 0.46 engine? I have this number floating around in my head for some reason....
Help greatly appreciated...
Andrew.
Astrowall is offline Find More Posts by Astrowall
Old Jun 05, 2008, 07:13 AM
panzerd18 is offline
Find More Posts by panzerd18
panzerd18's Avatar
Melbourne, Australia
Joined Dec 2005
A 11x6 will be fine. They are the same as a Magnum 46.
panzerd18 is offline Find More Posts by panzerd18
Old Jun 05, 2008, 03:24 PM
Andrew
Astrowall's Avatar
Joined May 2008
Thanks mate... thought there were similarities between the engines. most likely coming out of the same factory to reduce costs etc...
Old Jun 05, 2008, 08:25 PM
Curare is online now
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
if you can find them, the bolly clubman props are really good, as the'yre that half an inch you need to get your engines honking.
I was running a 10.5 x 6 and it was the sweetest prop for a 46 IMO.
Oh and for the record the engines aren't coming out of the same factory, but have their roots in the same engine, so they're very similar in looks but metallurgy can be vastly different between brands
Curare is online now Find More Posts by Curare
Old Jun 06, 2008, 04:33 AM
panzerd18's Avatar
Joined Dec 2005
Thats weird I thought they were both made by SANYE. Is Magnum the better brand/better metals?
Question ASP 0.46 Engine Big_AlF Engines 5 Apr 23, 2008 09:51 AM
Help! plane size/prop size for a 0.12 engine rcminiman Fuel Plane Talk 11 Oct 02, 2006 04:18 AM
Discussion engine/prop size Master crafter USA - District I 0 May 11, 2006 06:41 PM
Question .61 engine prop size icebox44 Fuel Plane Talk 9 Feb 25, 2005 02:31 AM
Prop size and break in for Irvine .46 War Bird Radio Engines 5 Aug 19, 2004 11:12 PM
