Old Jun 08, 2008, 02:23 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
I figured they were hard to get cause hand tool companies kinda have the market cornered right now, and I know really they are not really ours, just meant to be funny given the question. Are they not viable for car use? or are they viable and there scooping them up? I know GM is planning some 123 use in the new E-flex system.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Jun 08, 2008, 02:32 PM
lslewis is offline
Find More Posts by lslewis
Stilwell Shipyard
lslewis's Avatar
United States, FL, Cape Coral
Joined Nov 2003
Erik - Almost all of the car manufacturers are looking to the lithium battery as the next step. Toyota is building a plant to make them.
I think we have hijacked this thread and should get back to watching nacelles.
lslewis is offline Find More Posts by lslewis
Old Jun 08, 2008, 04:07 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
Word is they have been used in The Toyota Prius for years by about 500-1000 cells each car. Many do still not realize LiFePo technology is pretty old and proven.
I would not use any Lipo in an A10 including mine. way too expensive and way too short lifespan IMHO.
Back to thread indeed...
Good luck with this awesome project!
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Jun 08, 2008, 04:29 PM
Lynxman is offline
Find More Posts by Lynxman
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
The Toyota Prius has a Ni-Mh battery in its stock form.
Lynxman is offline Find More Posts by Lynxman
Old Jun 08, 2008, 06:39 PM
ScaleBrad is offline
Find More Posts by ScaleBrad
115 inches of 'hog
ScaleBrad's Avatar
United States, FL, Orlando
Joined Aug 2004
Getting back on topic.... My plans are to use an 11S lipo setup for power. Probably somewhere around the 8000 mah range. The lipos will be the last purchase, much depends on the amount of nose weight needed; A-10 models are notoriously tail heavy. For some reason if I do need to add weight to the nose I would rather add battery capacity instead of lead. On the other hand, if the plane comes out heavier than I want, I will have to skimp on battery capacity to save weight, and live with shorter flight times.
ScaleBrad is offline Find More Posts by ScaleBrad
Old Jun 09, 2008, 01:26 AM
Joined Aug 2002
granted anything can happen but that thing is so huge all your electronics and all your cells could probably sit together in the nose so hopefully c/g wont be a prob.
Barry
Old Jun 09, 2008, 01:41 AM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
Well Brad I got to hand it to ya. You have taken on a large project there. If your woman is still with you by the time your done Than I need to congratulate her for being so understanding. Then you also know she's a real keeper.
Now what paint scheme are you shooting for?
lavochkin is offline Find More Posts by lavochkin
Old Jun 13, 2008, 05:44 PM
115 inches of 'hog
ScaleBrad's Avatar
Joined Aug 2004
Most likely going with the Barksdale AFB scheme, I like the newer grey camo more than the older green camo.
Old Jun 13, 2008, 05:52 PM
Joined Dec 2003
I have a winter camo colorsheme somewhere. I'll dig it up for ya if you like.
Somehow I think you might have visibility problems with the light grey sheme
Need to finish mine later. I found a twin project too expensive for Lipolly. an other problem was the very long wiring from Battery/esc which is an issue with lipolly. This project will be after the 80" turbine trainer/edf project and Huckebein project
Old Jun 14, 2008, 02:00 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
ScaleBrad.....that is one big hog
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jun 14, 2008, 04:48 PM
MustangAce17 is offline
Find More Posts by MustangAce17
3d and EDF, some scale
MustangAce17's Avatar
United States, FL, Ocala
Joined Sep 2005
Brad,what a monster,you should come down and fly again soon.
MustangAce17 is offline Find More Posts by MustangAce17
Old Jun 14, 2008, 06:37 PM
115 inches of 'hog
ScaleBrad's Avatar
Joined Aug 2004
The building has begun !!
I used the included engine pod bulkheads as templates to cut some new ones, from 1/4" ply to 1/4" light ply, total weight savings of 2 oz. so far...
But, it will add up, 16 bulkheads= 1 pound saved, in theory.
I'm starting the build with the engine nacelles and mounting to fuse.
Have to order balsa sheeting for wings and tail, none of the LHS stock wide sheeting. After much research, I found Dave Brown's " Southern's Sorghum" very popular for sheeting wings. It's a water-based (I think) contact adhesive. I just picked some up and the first test went perfect...easy to use, sticks like nothing else.
Old Jun 15, 2008, 05:22 AM
Joined Dec 2003
Use depron instead of lite ply if the former is not stressed and only needed for keeping the glass parts in shape. with this many formers the weight really adds up with lite ply.
grtz, Erik
Old Jun 15, 2008, 10:39 AM
Joined Dec 2003
http://video.google.com/videoplay?do...KBwqiDDw&hl=nl
Discussion A-10 with stock EDF-55s and 300h and NiMh flyable? GetterDragun Electric Warbirds 6 Oct 11, 2007 05:50 PM
Question GWS A-10 with EDF-55 tony209 GWS (Grand Wing Servo) 20 Feb 19, 2004 08:46 AM
GWS A-10 with EDF-55s...worth it..? chrisw Electric Ducted Fan Jet Talk 4 Jan 12, 2004 03:40 PM
A-10 flies with ONE EDF 5 RMason GWS (Grand Wing Servo) 9 Nov 16, 2003 02:14 AM
Jim Hendry's A-10 with 2 GWS EDF-50 GoEFlight Parkflyers 25 Oct 04, 2002 06:33 PM
