This thread is privately moderated by ihor14448, who may elect to delete unwanted replies.
Old Jun 04, 2008, 05:31 PM
ihor14448 is offline
Find More Posts by ihor14448
ihor14448's Avatar
Strongsville, OH
Joined May 2007
Cool
A scratchbuilt performance plane (with instructions)
This is my new plane, the only one i have that is in flying condition.
me and my buddy Alex build this plane in about 4 hours, and man is it good!
seriously this is the best plane ive ever flown, moves quick, can fly fast or slow, do loops and stuff. plus its nearly indestructable. i crashed it about 8 times already and all i broke was the vertical stab and a piece of balsa on the fuselage cracked, a little epoxy and its back in the air again.
some specs:
40" wingspan
3ch, aileron and elevator
tower pro motor with 10A esc i think
runs on a 3s 1000-1300mah lipo
this plane does not like stalling, if you stall and you dont got altitude, you are in trouble cause it starts looping thats how i mostly crash it.
handles great in wind up to 20mph
ihor14448 is offline Find More Posts by ihor14448
Old Jun 04, 2008, 05:53 PM
biber is offline
Find More Posts by biber
Needs brain lubrication
biber's Avatar
Aachen, very western Germany
Joined Dec 2004
Try a bigger tail.
Might cure the slow speed issues.
The horizontal looks way to small according to TLAR.
biber
biber is offline Find More Posts by biber
Old Jun 04, 2008, 06:22 PM
Michael Johnson is offline
Find More Posts by Michael Johnson
Proud member of AAA
Michael Johnson's Avatar
Joined May 2007
Very nice, got a build thread yet?
MJ
Michael Johnson is offline Find More Posts by Michael Johnson
Old Jun 04, 2008, 09:28 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
Originally Posted by biber
Try a bigger tail.
biber
no, its fine, the vertical tail is small because i will eventually put a ruder on it.
it does not need a bigger tail, the plane is so goodly balanced that only a little tap will send it out into the sky
Old Jun 04, 2008, 09:29 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
MJ
yea, the guy that help me build it has a thread i think, il look for it and post it here.
if i get someone to tape me fly that thing you will see.
Old Jun 04, 2008, 09:43 PM
steelhead is offline
Find More Posts by steelhead
TROUT OR THERMALS
steelhead's Avatar
Eureka, Ca
Joined Sep 2002
Howdy!
Sounds fun!
My initial thoughts are that you need more stab and rudder area. It might balance fine, but there are more things at work than just CG balance to a good handling plane.
At high speeds, smaller tailfeathers work OK, but at slower speeds, you need more area to provide the same stabilization.
A stall that send the plane into a loop....well, if that happened on any of my planes, I'd think the CG balance was off. Too tail heavy, add some lead to the nose.
As you said, a little tap will send it out into the sky, again, sounds like CG is off- too tail heavy, add some lead to the nose.
Just adding a few things to try to help you get rid of the nasty stall.
I clicked on this thread from the RCGROUPS homepage because I like seeing homebrew planes- I like it. What wing are you using?
Dean
steelhead is offline Find More Posts by steelhead
Old Jun 04, 2008, 10:57 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
the tail has to be small as ive been told, the original inventor Alex made dozens of copies of the planes for his friends, is flies fast and slow with enought controll, you will have to fly it to believe it, ill ask Alex if he has a thread about this plane. well the looping during stalling is just the way it is, the wing is kinda shifted back and there is alot of nose area before it, so the plane cant get the lift from the wing from the motor during the stall, but you can get out of it.
the rule is for these planes: if you get in trouble slam on the throttle
well i'm not saying is stalls, its kinda hard to stall, but if you do, you are in trouble.
the wing was cut out by a hotwire bow.
this is the perfect plane almost, handles well in high wind and all that, but one negative is the stalling.
ill try my best to get you guys some sort of information on how to build these
Old Jun 05, 2008, 03:58 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
there ya go, detailed instructions on how to build one of these
http://www.rcgroups.com/forums/showthread.php?t=736291
Old Jun 09, 2008, 04:41 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
going out to get a vid, hopelly will post it up tonight
Old Jun 09, 2008, 04:42 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
Originally Posted by steelhead
Howdy!
Sounds fun!
Dean
nice fish man! whats your total catches of trout this year?
Old Jun 10, 2008, 02:09 PM
TROUT OR THERMALS
steelhead's Avatar
Eureka, Ca
Joined Sep 2002
http://www.rcgroups.com/forums/showt...=hog+steelhead
Old Jun 10, 2008, 06:15 PM
mtdoramike is offline
Find More Posts by mtdoramike
Mt. Dora, Florida
mtdoramike's Avatar
USA, FL, Mt Dora
Joined Dec 2006
Wing is to far back, I had the same problem with my Slow Stickbeing tail heavy and stalling when I moved the wing to far back toward the tail. But once I moved the wing quite a bit forward and positioned the battery closer to the nose of the plane to achieve the proper CG, it became a very mild flyer.
some specs:
40" wingspan
mtdoramike is offline Find More Posts by mtdoramike
Old Jun 10, 2008, 06:16 PM
ihor14448's Avatar
Strongsville, OH
Joined May 2007
but this one flies how it is, flies good
Discussion suggestion for the best "1st scratchbuilt" plane ecologito Foamies (Scratchbuilt) 10 Nov 24, 2006 11:19 AM
New Product High performance plane for tricky landing areas -- New TYPE of constuction AndreasMergner Slope 201 May 30, 2006 10:59 AM
Would you consider this a performance plane? War Bird Radio High Performance 30 Sep 24, 2004 09:56 AM
Mako - Scratchbuilt Stunt Plane (long) Zoom Parkflyers 29 Aug 02, 2004 02:28 PM
What first high performance plane to buy? thomer High Performance 10 Apr 15, 2004 08:20 PM
