Old Jan 21, 2003, 11:53 PM
LESLIEx317537 is offline
Find More Posts by LESLIEx317537
Inbox is almost full
LESLIEx317537's Avatar
Long Island, New York
Joined Nov 2002
GWS P-51 with Flaperons done. Pictures.
Here they are in normal flight:
LESLIEx317537 is offline Find More Posts by LESLIEx317537
Old Jan 21, 2003, 11:55 PM
Joined Nov 2002
I set up the land function of the flaperons at 30 percent droop and 15 percent elevator up.
This is how much the flaperons go down with 30%:
Joined Nov 2002
This is the with the flaps fully down:
Old Jan 21, 2003, 11:56 PM
Joined Nov 2002
This is with the flaps fully up:
Joined Nov 2002
These are my aileron throws:
Old Jan 21, 2003, 11:57 PM
RMason is offline
Find More Posts by RMason
A Few Sandwiches Shy
RMason's Avatar
Orlando, FL
Joined Jun 2001
Leslie -
Let me know how it flies. I'm thinking of doing this to my brushless version.
Rob
RMason is offline Find More Posts by RMason
Old Jan 21, 2003, 11:58 PM
k2rick is offline
Find More Posts by k2rick
k2rick's Avatar
laguna niguel, So Cal
Joined Dec 1999
How does it fly?
k2rick is offline Find More Posts by k2rick
Old Jan 21, 2003, 11:59 PM
av8rOC is offline
Find More Posts by av8rOC
plane crazy
av8rOC's Avatar
Northport, NY
Joined Dec 2002
Wow Les looks nice! I wish I could be there for the maiden...perhaps you should bring her donw to orlando.
av8rOC is offline Find More Posts by av8rOC
Joined Nov 2002
I set up the plane with 5 servos.
It weighs in at 18 Oz.
I'm using a Hitec Eclipse radio and control the flap via VR6 knob or use the flt. condition switch and switch it foward and the land sequence kicks in.
I may go Astroflight 010 for maiden.
Old Jan 22, 2003, 07:07 AM
gouda is offline
Find More Posts by gouda
Is it summer yet?
gouda's Avatar
Flight Level 46 X 92
Joined Feb 2002
18 oz!! With five servos? How did you do that? Does that include the landing gear, ESC, motor, battery and receiver? If you go brushless, what motor are you considering? I'm on the second Mustang, and am considering a geared Astro 010. But, from what I have read so far, it is not a great jump in power. Looking into what other options are available without breaking the bank.
gouda is offline Find More Posts by gouda
Old Jan 22, 2003, 07:47 AM
D W is offline
D W
Find More Posts by D W
D W
I love you man.
D W's Avatar
United States, NY, Pelham
Joined Sep 2002
What ESC are you using with 5 servos? From the little I know these things don't like too many servos.
D W is offline Find More Posts by D W
Old Jan 22, 2003, 10:15 AM
Joined Nov 2002
Yes ready to fly it weighs 18Oz.
Not one drop of heavy epoxy or probond on my plane. Just foam safe light CA.
I am using a 15amp GWS ESC with brake.
I can use my flaps and 4 blade prop to slow down my Stang to make the slowest land the RC world has seen with a GWS Stang. (Well I hope!)
Old Jan 22, 2003, 12:00 PM
Dax is offline
Dax
Find More Posts by Dax
Dax
There is no spoon
Dax's Avatar
Vancouver BC Canada
Joined Aug 2002
good job, if you 18oz stang flys then I won't feel so bad about allt eh batteries I am trying to pack into mine
Dax is offline Find More Posts by Dax
Old Jan 22, 2003, 12:27 PM
Darren Hintze is offline
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
Can the GWS ESC BEC handle 5 servos? Most of them go stupid with more than 3.
Nice job though. I've never had much luck with flaperons but I'll be interested to hear the report.
Darren Hintze is offline Find More Posts by Darren Hintze
Old Jan 22, 2003, 12:51 PM
Aldur is offline
Find More Posts by Aldur
Freak Member
Aldur's Avatar
Seminole, FL
Joined Nov 2002
ESC Used?
Which model number is the ESC?
Have you throughly tested the electronics to make sure you have no problems or glitches?
BTW: Are you using retracts?
I ask only because I ran into problems myself with the GWS P-51 and ESC.
Scott
Aldur is offline Find More Posts by Aldur
GWS P-51 with EPS 350C skyhawk Parkflyers 8 Sep 11, 2003 02:04 PM
GWS P-51 with 2S etec Mikey-flies Parkflyers 11 Jun 24, 2003 10:19 AM
GWS P-51 with Mega 16/15/6 Basketcase Parkflyers 28 Mar 27, 2003 04:55 PM
GWS P-51 with brushless rager24 Parkflyers 2 Feb 16, 2003 10:55 AM
GWS P-51 with the IPS motor pc_pilot Parkflyers 3 Jan 28, 2003 12:39 PM
