Old Jan 21, 2003, 08:18 PM
dottney is offline
Find More Posts by dottney
dottney's Avatar
United States, NY, Fairport
Joined Jun 2000
retract servo
OK guys put your thinking caps on. Can you use a regular servo (i.e.: HS81MG for example) as a retract servo? I have a retract servo and am not quite sure what makes it special except that its bigger than what I'd like to use. Do retract servos have some sort of "limiting movement" on it to control the throw or are they just real strong servos?
thanks in advance
Dave
dottney is offline Find More Posts by dottney
Old Jan 21, 2003, 09:26 PM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
Servos designed specificaly for retract duty are usually slower as a consequence of lower gearing, which also gives them more torque. Additionally they usually rotate 180deg. All the units I've seen are in the "standard" size class though.
For small retracts you may be able to get away with using a smaller servo like your HS81MG. Just be absolutely sure that the mechanism is free moving and doesn't bind or jam anywhere. If it jams the servo will consume a lot of current and may fail or cause your BEC to fail.
I used a single HS85MG as the retract servo for my 1/12 scale FW190A http://bellsouthpwp.net/g/e/geraldod/FW190A.html
Gerald is offline Find More Posts by Gerald
Old Jan 22, 2003, 10:14 AM
Mike Payne is offline
Find More Posts by Mike Payne
Brum UK
Joined Jan 2001
I have used a HS 80 as a retract servo and it is still working well. I had very light wheels, balsa / ply hub with closed cell foam for the tyre. This made the retracts work without a lot of load on the servo.
Mike Payne is offline Find More Posts by Mike Payne
Old Jan 22, 2003, 03:45 PM
astroboy is offline
Find More Posts by astroboy
Superhero, Third Class
astroboy's Avatar
Carson City, NV
Joined Nov 2000
I tried an HS81 in my Herr Mustang, but had a lot of trouble getting the linkages adjusted right. I could see the servo shaft flexing. I replaced it with an HS85BB, and the problems all but vanished. The ball bearing-supported shaft made all the difference. I later stripped one of the gears, and replaced them with the metal set; so I'd recommend the HS85BB with metal gears.
Jeff
astroboy is offline Find More Posts by astroboy
Old Jan 22, 2003, 06:50 PM
dottney is offline
dottney's Avatar
Joined Jun 2000
Thanks guys,
Dave
Retract servo for the GWS Zero or P51 doc-e Parkflyers 7 Mar 28, 2004 06:49 PM
FS: New JR 513 Retract Servo twinster2 Aircraft - Fuel - Airplanes (FS/W) 1 Apr 12, 2003 11:01 PM
Pager motor retract servo, how to build? JonB Scratchbuilt Indoor and Micro Models 1 Apr 04, 2002 01:29 AM
Futaba S136G Retract Servo NIB fw-190 Aircraft - Electric - Airplanes (FS/W) 0 Apr 02, 2002 08:35 PM
hitec retract servo p471701 Aircraft - Electric - Airplanes (FS/W) 0 Sep 28, 2001 01:30 PM
