Old Jun 01, 2008, 02:16 AM
ChrisP is offline
Find More Posts by ChrisP
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
RTR Severn Class Lifeboat
I just bought the 'ready to run' Graupner Severn Class Lifeboat. I'm pretty sure it is the same as the one offered in the UK.
I would like to fit 'real' R/C to this model. I have already done this with a couple of the low cost toy category boats currently available and have been very pleased with the results. Unfortunately this does not appear to be a simple task on the lifeboat as there is only a small access hatch for the batteries
Does anybody know how to remove the superstructure ? I have done some exploratory prods with a screwdriver and it seems that the top is only clipped on, not glued. I tried a little force, but chickened out to avoid causing damage.
Any advice would be very welcome.
Chris P
ChrisP is offline Find More Posts by ChrisP
Old Jun 01, 2008, 03:22 AM
VO70 is offline
Find More Posts by VO70
VO70's Avatar
Hampshire UK
Joined Nov 2006
Hi
The superstructure is screwed on from underneath, you have to remove the deck first.
There is a lot of information on the Mayhem site, have a look here to get some ideas.
HTH
Richard
ps mine's in bits waiting new motor etc......
VO70 is offline Find More Posts by VO70
Old Jun 01, 2008, 03:37 AM
ChrisP is offline
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Richard
Go to the top of the class and assume hero status.
That's exactly what I needed.
Many, many thanks.
Chris P
Old Jun 01, 2008, 04:27 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
I didn't realize that Graupner was the manufacturer of that little model.
Is it propellers and rudders or is it dual propeller with differential steering?
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Jun 01, 2008, 09:34 AM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Well, yes and no; Graupner has it made in China and is the distributor.
It has the 'dreaded' tanksteering if I'm informed correctly.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Jun 01, 2008, 12:05 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
it is pod drive, but easily converted
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Jun 01, 2008, 12:17 PM
Tugboat Andy is offline
Find More Posts by Tugboat Andy
Joined Apr 2007
Glad this popped up! Please keep us updated on progress. I am very interested in how the project goes togerther.
I was considering trying to modify one this winter but RC SCALE MODELS here in the US ran out of stock and I couldn't afford the hefty bill to get one special ordered. Thought about having one sent over from the UK as well but.....plans change
Ghost - have you converted a Severn? What type of glue/goop/adhesive would one use on a plastic hull to secure shaft tubes and rudders?
Tugboat Andy is offline Find More Posts by Tugboat Andy
Old Jun 01, 2008, 12:18 PM
ChrisP is offline
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
If I'm not mistaken, the UK model has been out for a couple of years and the Graupner model is fairly new. I assumed that Graupner was not the instigator of the model, but maybe I'm wrong.
Ghost - I don't know the term 'pod drive',but I can confirm that the rpm's change on one side when the stick is operated.
I have read the Mayhem site a few times and taken a good look at the model, but I'm not sure how to remove the deck. Is it glued on ? Does anyone know ? I just don't want to break anything.
On a different note - one person's comment on Youtube about this model was that his model sank. When you see the size of the gap between the deck and superstructure it's not surprising. So there's a real interest in doing the job properly.
Old Jun 01, 2008, 12:21 PM
ChrisP is offline
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Andy
I'm in similar circumstances. All I really need is for someone to tell me how to remove the deck and I'll work out the rest myself. In any case, I never did a kit bash in the past the same as anyone else.
Old Jun 01, 2008, 12:37 PM
Ghost 2501's Avatar
stoke on trent
nope, however to secure the various tubes that pierce the hull, treat it like a regular abs kit and use regular epoxy glue, (eg araldite).
Old Jun 01, 2008, 12:40 PM
Sneek, Netherlands.
Joined May 2004
Originally Posted by ChrisP
Ghost - I don't know the term 'pod drive',but I can confirm that that the rpm's change on one side when the stick is operated.
I have a gutted NQC 'Pelican' that had the same pod drive and ran on 6 penlights, quite high up in the hull, causing an 'adventurous' CoG, making it sway from side to side.
I replaced the penlights by a 6V SLA deep down in the hull, which made for a much smoother ride.
Eventually the sealing on the pods started to leak badly and the motors rusted solid, I pried them out , but they'll never run as before...
The deck was fixed witn numerous screws, hidden under rubber stops and (how devious) deckfittings, I nearly broke the thing trying to find the last few.
So I'd try to remove all deckfittings. stancions, deck housing to locate the screws, you'll get there eventually.
Question from my end: what did you use as glue to keep the new propshafts in place, my hull is the type of plastic, nothing I have will stick to...
Very frustrating, as I have the parts for a refit with 'normal' radio gear at the ready.
Regards, Jan.
Old Jun 01, 2008, 12:57 PM
VO70 is offline
VO70's Avatar
Hampshire UK
Joined Nov 2006
The deck is screwed down, the screws are under the black plugs on the deck. In the pictures one of them is under your screwdriver. The deck is sealed with a large o-ring which fits all round the top of the hull, so be careful when you remove deck.
I can dig out some pictures if it helps
HTH
Richard
Old Jun 01, 2008, 01:04 PM
ChrisP is offline
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
HTH
Richard
You bet it would !!!!!
As there seems to be some interest, I would be quite happy to go ahead and report on my build progress.
Old Jun 01, 2008, 01:14 PM
ChrisP is offline
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Yes sir, way to go !!!
I just bashed a toy cabin cruiser and used nothing but 5 minute epoxy.
Old Jun 02, 2008, 12:13 PM
ChrisP is offline
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
OK - I removed the five rubber plugs and the corresponding screws underneath them and the deck came off a treat. I found the mentioned seal / O-Ring and treated it with due respect.
I now understand what is meant by the term 'pod drive'. Yes, it has pod motors.
trent class lifeboat ernest2 Scale Boats 1 Sep 28, 2005 12:28 AM
