R/C Cross Country Soaring
Let's discuss all general aspects of R/C CROSS COUNTRY SOARING here.
The main website for the XC SOARING COMMUNITY is www.xcsoaring.com R/C CROSS COUNTRY SOARING combines RC THERMAL DURATION FLYING with FULL SCALE RC CROSS COUNTRY FLYING and mixes it all up with a team on the ground in a chase vehicle. For a good overall description of a contest and the duties of the team members, I wrote an article for RCSOARINGDIGEST.COM covering the 2006 contest starting on page 32 here- http://www.rcsoaringdigest.com/pdfs/...SD-2006-08.pdf Many of us hope this thread will increase interest and answer the many questions people have about XC Soaring and the gear needed to participate. To subscribe to this thread to make sure you are notified when someone posts a reply, either make a post yourself to this thread, or click on "THREAD TOOLS" above and to the right and then follow the instructions. Dean |
Also, a good XC glider sacrifices some performance for visibility at altitude, which is why XC gliders have a relatively deep chord and hence lower aspect ratio than higher-performance gliders. They're relatively easy to land because of the relatively low wing loading, and good XC pilots find suitable LZs... : ) Dieter Mahlein, ShredAir |
JT |
JT |
I have a 5m plane I bought a few years ago. Actually, WS is 15 or 17 depending on the tips. it's called a Condor. Seller said it was one of a kind.
Still don't have a good way to launch it. Nearest winch club is about an hour away. Does anyone have any tips about auto-towing one of these things? |
We have successfully car launched while participating in the Soaring Safari. The appratus was a glorified hi-start (geez, I hate saying that anywhere on RCG). We worked out the vehicle speed and tested the gizmo at our club field. Launches were a bit higher than normal winch launch, based on Alti-2 altitude data. 25' of ~1/2" ID heavy wall tubing tied into a loop (use a Carrick Bend, a sailing knot) to form the loop so it can't pull out under tension, with a metal ring strung on the rubber before looping. 500' of winch line and a chute onto the ring. The rubber loop is mainly a shock absorber, though it will store a little energy for a zoom. We don't push the rubber too hard. We lash the rubber around a trailer hitch, then the truck drives out until the line is deployed. Helper and driver are in communication, cell phones work fine, or FRS radios. On command the driver accelerates to 21-23 mph (no more) and helper throws the plane. At the top of the launch, helper tells driver to stop, pilot uses the stored energy in the line/rubber for a reasonable zoom (for an XC plane). Reel in the line and hit the road. JT |
Ryan |
Latest blog entry: May 2013 US F3B Team Practice contest
| Thread Tools | |
| Question open/cross country soaring | mattbroomer2000 | Sailplane Talk | 10 | Apr 28, 2006 06:20 PM |
| Ban on R/C Soaring at Torrey Pines | bjaffee | Slope | 30 | Aug 16, 2003 06:14 PM |
| R/C soaring digest | Daniel Mc Crae | Electric Sailplanes | 0 | Sep 12, 2002 05:22 PM |
