Old Jan 21, 2003, 07:32 AM
Propeller
Propeller
Guest
n/a Posts
Saito 100 and a dubro softmount rated up to 80 size
Hello
I have a Saito 100 and a dubro softmount rated up to 80 size fourstroke I
consider using for this engine.
Could not get hold of the 80-91 size.
I think the weight of the dubro unit is heavy in the first place, and the
weight of the saito 100 (550g, less than 20 oz.) does not exceed any 80 four
stroke on the market.
The vibrating mass and frequency will certainly be within the design
conditions for the mount, but the thrust and torque is clearly larger.
Has anyone tried this combination? or does anyone have any thoughts about
this?
Jon in Oslo
Old Jan 21, 2003, 01:32 PM
Richard Kletnieks
Richard Kletnieks
Guest
n/a Posts
Re: Saito 100 and a dubro softmount rated up to 80 size
Don't worry about it. It will be fine. I have seen guys using Moki's, both
the 1.8 and 2.1, on the 1.2 size Du-Bro mount without problems. Just check
the rubber now and then to make sure it's in good shape.
"Propeller" <jh@baa.no> wrote in message
news:CgaX9.18210$Rc7.258867@news2.e.nsc.no...
> Hello
four
> this?
> Jon in Oslo
Discussion Safety Spinner Nut Size for Saito 100 deegola Engines 2 Feb 10, 2006 12:18 AM
Found wtb os70 or saito 72 or 80 size 4 stroke rcguru Aircraft - Fuel - Airplanes (FS/W) 4 Jun 16, 2005 08:24 PM
Size of Jam Nut on Saito 100 muffler??? noahb Engines 1 Apr 20, 2005 11:23 PM
Saito 100 Prop size and RPM CDignition Engines 1 Mar 05, 2004 11:58 AM
