Old May 30, 2008, 01:24 PM
Chargle is offline
Find More Posts by Chargle
Joined May 2008
Landing strip
Hey, I fly my electrics at El Dorado Park in Long Beach, CA. It is a glider/electric field. The spot is great - tons of wide open air, control board... great. The big problem is that the "landing strip" is dirt and it has been ravaged by pocket gophers. So, I am going to work with the park to try and get a paved landing strip laid down. Can anyone offer suggestions as to the dimensions that I would need to offer electrics a good runway/landing strip? Thanks.
Chargle is offline Find More Posts by Chargle
Old May 30, 2008, 01:35 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
Depends on the model...
20 ft X 50 ft would be more than adequate for some...
50 ft C 300 ft would be insufficient for others.
I have electric powered models at both extremes...
fhhuber506771 is offline Find More Posts by fhhuber506771
Old May 30, 2008, 02:55 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Depends more on the pilot than the model..
The runway at my local county field is 400x50', and people still have problems hitting it..
..a
Old May 30, 2008, 03:15 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
The field I fly at is 394x50, and it is more than enough for the turbine jets to takeoff and land, the lighter ones that is.
I'd say that a field about 450x50 is plenty, even for large electric models. Out at the MWE a few weeks ago, we had a large number of big electric models, and they easily took off from the field. It's about 400x20, so something of about 450x50 should be plenty.
Xpress.. is offline Find More Posts by Xpress..
Old May 30, 2008, 03:18 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
We have a 200'x150' landing area where we fly, mostly 2# or less planes, and it's barely adequate for those. 3D's do OK, but sport flyers have a problem. The guys who fly larger planes (6# is about the largest) really have a problem. I would recommend at least 300' as a minimum if you can swing it.
Chuck
Chuck is offline Find More Posts by Chuck
Old May 30, 2008, 04:10 PM
jrubenis is offline
Find More Posts by jrubenis
Custom CNC machining
jrubenis's Avatar
Plymouth, UK
Joined May 2006
For a landing strip i think 50metres x 50 metres should be enough for most flyiers. 400ft seems a little excessive i think. Thats over 130metres.
jrubenis is offline Find More Posts by jrubenis
Old May 30, 2008, 04:16 PM
Joined Mar 2005
Depends on the aircraft... I have a few that are hard to get stopped in 300 ft after touch-down. If you don't touch-down at the end of the runway... you can easilly need more. And the average RC pilot does not consistently touch at the end of the runway
I only have one that needs more than 200 ft to get off the ground. Takeoff is rarely what is used to determine the runway necessary for a model.
Old May 30, 2008, 04:19 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
150x150ft. is enough for SMALL electric models, not for the entire range of electrics. If your area only permits park flyers under 3lbs. then that is fine, but other than that, it's just not enough room. My field is barely 400ft., and it seems much shorter when it takes only about 10-15 seconds to walk down to the other end to check out the new guys stuff, and make sure he is set up properly.
And for me, I only need a platform to stand on to be my runway. My 3D planes I just reach out and grab, and hand launch them, so I need very little place to "takeoff" and "land".
Old May 30, 2008, 04:32 PM
ltbidrawn is offline
Find More Posts by ltbidrawn
Joined Mar 2008
more.....
i've seen you fly, chargle. i'd suggest a BIG landing strip.
and maybe we could set up a "dive bomb" competition to take out those gophers.
ltbidrawn is offline Find More Posts by ltbidrawn
Old May 30, 2008, 05:17 PM
CFisher1421 is offline
Find More Posts by CFisher1421
CFisher1421's Avatar
Geneva, IL
Joined Jul 2007
So you're saying the 8ft wide straight section of bike path that I always try to land on is too thin?
No wonder I'm always missing the darn thing!
CFisher1421 is offline Find More Posts by CFisher1421
Old May 30, 2008, 05:35 PM
The Dead Baron is offline
Find More Posts by The Dead Baron
Joined May 2008
Poll the club members and find out whose plane needs the most landing strip and use those dimensions.
The Dead Baron is offline Find More Posts by The Dead Baron
Old May 30, 2008, 06:16 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Joined Dec 2005
..a
Yep .... I have a couple hundred of acres to land in and over the last holiday weekend I hit 3 trees in 3 days.
I hear that depth perception gets worse as one gets older.
Lou is offline Find More Posts by Lou
Old May 30, 2008, 10:22 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
^Oh, if that's so, then I'm lucky that I'm young
Nonsense! I've landed on smaller (8ft. long bench that is ~1 1/2ft. wide ).
Old May 31, 2008, 01:58 AM
Dakrat is offline
Find More Posts by Dakrat
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
What are the rules for flying there? (how big a plane) That should be a good starting point...
Dakrat is offline Find More Posts by Dakrat
Old May 31, 2008, 02:55 AM
Threshold is offline
Find More Posts by Threshold
Threshold's Avatar
London UK
Joined Jul 2004
As has been said take off is not a problem, with a paved strip stopping is a problem. Perhaps you can come up with a trap of some sort both ends to stop the planes, then you could get away with a much shorter strip?
Threshold is offline Find More Posts by Threshold
Discussion portable landing strip wolfpack72 Electric Warbirds 30 Dec 24, 2009 11:02 AM
Hummer on concrete landing strip mumblety-peg High Performance 15 Sep 06, 2005 12:54 AM
What is the easiest way to create a landing strip? monts High Performance 9 Mar 10, 2004 06:22 AM
The perfect landing strip for your parkflyer? jeffs555 Parkflyers 20 Jan 02, 2004 11:06 PM
