Old May 30, 2008, 03:40 AM
France - Maine et Loire
Joined Apr 2008
MPX Cockpit SX delta programming
Hi,
I have built a Delta model. I have a 4 channel receiver and I would like to use it with my MPX Cockpit SX.
As mentioned in manual, I have plugged my 2 servos in port 1 and 2 of receiver and set the corrects value in Delta mixing menu. (-30% and 30 % for
example)
The mixing is good, but the right lever (left/right) now commands elevator and the left lever (up / down) is set to ailerons/elevons....
I have not found the solution to this.
Thank's in advance for the ideas !!
Loïc
loicremy is offline Find More Posts by loicremy
Old May 30, 2008, 01:33 PM
smoking a buddy box
olivier2's Avatar
Brussels
Joined Nov 2002
Hi,
I suggest the following :
-first de-activate the delta-mix
-left elevon-servo in channel 1 of the receiver, right-elevon-servo in channel 2 of receiver
-activate aileron-stick to the left : your left-élevon should go "up" (if not, change sign of travel)
-pull on your élevator-stick : the rigt élévator should go "up" (if not, change sign of travel)
Now you know that both servo's are going in the right direction. Activate now the "delta-mix" and normally everything should work as expected.
Olivier
my website : http://users.belgacom.net/TX2TX : buddy box compatibility problems between different brands of transmitters
olivier2 is offline Find More Posts by olivier2
Old May 30, 2008, 11:03 PM
mostly gliders
liukku's Avatar
Skellefteå, Sweden
Joined Sep 2003
Hello
I tried delta on my SX and it woks ok.
The trick is to use correct stickmode and reverse one of the two servos.
I use stickmode 2, aileron and elevator on right stick.
You are in stickmode 1, aileron on rigjt and elevator on left stick. Reverse servo 1 or 2
and it will work ok, even if I prefer to have both aileron and elevator on the same stick.
So if you prefer to have aileron and elevator on the left stick, go to stickmode 3 and reverse either servo 1 or 2.
/Ville
liukku is offline Find More Posts by liukku
Discussion Cockpit SX Programming help please! mr_editor Slope 4 Apr 18, 2008 11:05 AM
Discussion MPX Cockpit SX MM JEFF R Radios 4 Apr 15, 2008 08:58 PM
Help! Multiplex Cockpit SX throttle programming? GliderGuideMan Radios 7 Jan 14, 2007 10:09 AM
Programming CCPM on MPX Cockpit MM, have problem!!!! kajakmannen Micro Helis 7 Mar 01, 2005 02:42 PM
MPX Cockpit TX Accu Radek Z Electric Plane Talk 5 Oct 27, 2001 01:19 AM
