Old May 29, 2008, 06:26 PM
Matd is offline
Find More Posts by Matd
Belgium
Joined Oct 2006
wasp V3 gyro connection to graupner R700 receiver
Hello everyone,
I've bought a wasp V3 from skyartec. It had the skyartec gyro on it.
Thera are two output leads: one for the tail servo(usual 3 wire connector) and one with a yellow cable. On the manual of my R700 receiver shows just one connection for the gyro (the servo connection) so what to doe with the connector with the yellow cable. Is this just to control the gain by you transmiter instead of turnig the gain screw on the gyro itself?
thanks,
Mat
Matd is offline Find More Posts by Matd
Old May 29, 2008, 09:47 PM
PAS is offline
PAS
Find More Posts by PAS
PAS
PAS's Avatar
California, USA
Joined Sep 2000
The extra yellow lead is the signal wire for the remote gyro gain. I am not sure what channel to connect it to on your Graupner, I think it would depend on the transmitter. For example with Spectrum equipment, we often select the channel labeled GEAR and use a switch on the transmitter to select between rate and heading hold mode.
-Paul
PAS is offline Find More Posts by PAS
Old May 30, 2008, 07:51 AM
Matd is offline
Belgium
Joined Oct 2006
I've now connected it to my to the channel that I also use to move retractable gear. So do I now just need to put it in the "gear out" position and start calibrating the helicopter?
btw: thanks for your answer PAS
Old May 30, 2008, 11:50 PM
PAS is offline
PAS
PAS
PAS's Avatar
California, USA
Joined Sep 2000
Unfortunately I don't have a Graupner radio but on the Spectrum Dx7, you would set the Travel Adjustment.
I use +54% for Heading Hold Mode and -60% for Rate Mode.
Hope this helps!
-Paul
Old May 31, 2008, 09:53 AM
Matd is offline
Belgium
Joined Oct 2006
surely does help.
thanks a lot
JR R700 receiver dreslism Radios 1 Oct 25, 2004 10:40 AM
F/S or Trade JR Quattro Trans & R700 receiver sheba Aircraft - General - Radio Equipment (FS/W) 2 Oct 07, 2004 10:51 AM
FS: JR R700 receiver nuevo Aircraft - General - Radio Equipment (FS/W) 3 Sep 10, 2004 01:23 PM
JR XP662 heli TX with R700 receiver FS ronvdp Aircraft - Electric - Helis (FS/W) 0 May 31, 2004 12:25 PM
EBAY-JR Quattro Transmitter & R700 Receiver w/Deans Whip Antenna on CH15 flytowner Aircraft - Electric - Airplanes (FS/W) 1 Nov 25, 2002 09:14 AM
