Old Jul 26, 2001, 03:42 AM
Smifta is offline
Find More Posts by Smifta
Crusty Banana-Sniffer
Smifta's Avatar
OXON, UK
Joined May 2001
Anyone Build / Fly /Own an ACT ME-163
People,
I am after some input from builders and flyers of the ACT ME-163 Komet.
The plane is basically billed as a super fast Pico Jet, and only 15 pounds ! It can be found at http://www.acteurope.com
Although it might be advisable to run the site through babelfish as it is in German only! http://babelfish.altavista.com
Any input would be GREATLY appreciated.
Regards,
Alex.
Smifta is offline Find More Posts by Smifta
Old Jul 26, 2001, 04:51 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Alex
This little model has been the subject of much discussion here and in the scale modelling forums. A quick search for Komet or Me163 will yield you quite a few posts.
Got one hanging up here (unpainted as yet) awaiting a maiden flight when I gather up enough bottle. These little 'uns are seriously quick.
Having seen a couple of these in action I would say stick with the recommended 6vSp400 and 7x500AR batteries as they are plenty rapid enough on that set up and according to their pilots they like to be kept light. Apparently the C of G marked in the instructions might also benefit from some experimentation, but I can't vouch for that. Maybe someone who has actually flown theirs would like to coment?
Saw a chap in the LHS the other day being advised to stick a 480 in one on 8 cells - from what i've seen I don't believe this is necessary if the model is kept light enough (should be under 17 ounces).
I replaced the very very heavy fin with one made from balsaply. Also replaced that strange motor tube supplied with my own type made from a film canister and used a Protech Rondo type ESC mounted on the back of the motor. Hitec Superslim receiver under the wing and two HS-81 servos. I modified the top, cutting away the foam to add a clear canopy (easter egg container)and a slightly different hatch arrangement. Based on another ezoner's comment I also extended the strake underneath with some EPS to make it look more Komet-like. Did I mention that the supplied fin is very very very heavy???
Oh ... and made a likkle lightweight pilot for the office by cutting down a commercial item and making a new head that resembles the pictures of the poor suckers who risked getting melted by the T und C Stoff.
Probably too much effort for the expected four second life expectancy of the model but what the heck.
hth
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Jul 26, 2001, 05:10 AM
Smifta is offline
Smifta's Avatar
OXON, UK
Joined May 2001
I assumed that there would be other e-zoners with this model, and did do many searches on me163 and komet etc beforehand.
Unfortunately it seems that any previous post have been lost
Sorry if this thread does seem repeatitive.
Cheers to one an all,
Alex.
Old Jul 26, 2001, 05:30 AM
SJ is online now
SJ
Find More Posts by SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Hi
Ive also built one. Havn´t had it in the air yet. Got a pic of it here: http://bornholm.adsl.dk/modelfly
SJ
SJ is online now Find More Posts by SJ
Old Jul 26, 2001, 04:51 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Aaaargh!!!! The horror! The horror!
Just out of rehab, and what's the first post I see? This one! The very reason for my breakdown in the first place!
Ok now...deep breaths....calm...
ACT 163; Very small, very fast, very fragile. Needs minimal aileron, and lots of elevator movement + about 2-3mm of reflex built in. Easy to lose orientation.
When mine finally crashed beyond repair into a rock, the battery hurtled forward, cracking the receiver and pushed the Rondo Esc into the back of the motor (hard enough to total both) before the pack itself broke into 2 halves.
To sum up; would make ideal trainer for lone newbie
tim
tim hooper is offline Find More Posts by tim hooper
Low Wing Skimmer 400 anyone build and fly one? fred420 Electric Sailplanes 32 Feb 17, 2011 09:59 PM
Act Me 163 Tyson Foamies (Kits) 9 Dec 09, 2001 09:33 AM
Best prop for Act Me 163 Tyson Foamies (Kits) 8 Nov 22, 2001 07:55 AM
ACT Me-163 Ready to Fly! God help me! Smifta Foamies (Kits) 25 Aug 02, 2001 09:52 AM
ACT Me-163 sources in the UK? Thomas B Foamies (Kits) 4 Apr 25, 2001 12:29 AM
