Old May 27, 2008, 11:51 PM
Jurgen Heilig is online now
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Oops - DP.
Jurgen Heilig is online now Find More Posts by Jurgen Heilig
Old May 27, 2008, 11:54 PM
Joined Sep 2000
Originally Posted by teamdavey
Yes - I know. He posted both above. My point was that he gets figures that are the lowest published that I have seen.
At least my figures are measured with various systems under the same conditions and at the place where I fly most - my local flying field.
I could increase my max. range by raising the tx from 1m above ground to 5ft off the ground, but would that be realistic? Who operates his tx at this height?
Jürgen
Old May 28, 2008, 07:16 AM
TheFlyingAce is offline
Find More Posts by TheFlyingAce
TheFlyingAce's Avatar
Joined May 2008
Originally Posted by John Kim
It is good upto visual ranges. Beyond visual ranges? Why do you care?
It's for med range FPV (2.5-3 miles)
TheFlyingAce is offline Find More Posts by TheFlyingAce
Old May 28, 2008, 07:21 AM
Joined May 2008
Thanks for the link!
Originally Posted by Danal Estes
Since you have downlink... how about flying a "Flight Log" capable RX,
http://www.spektrumrc.com/Products/D...ProdID=SPM9540
And watching the number of antenna/frame losses? You could easily see when you are hitting the limit of range before any problems occur.
You can verify range for all of us! (For you site/aircraft/conditions, of course)
You'd need the Flight Log (or an Eagle Tree that plugs into the same spot, or similar) and an AR9000 or AR7000 with the new firmware.
Wow! I had never seen that at the spektrum site! I'm gonna get it. I'll try to post my figures soon!
Old May 28, 2008, 11:20 AM
teamdavey is offline
Find More Posts by teamdavey
Sunnyvale, CA, USA
Joined Apr 2000
"I could increase my max. range by raising the tx from 1m above ground to 5ft off the ground, but would that be realistic? Who operates his tx at this height? "
This is relavant - how?
The bottom line is the "test environment matters". Talking range test mode now I can get anything from 35 paces to almost 100 paces with my Spektrums depending on how the model is positioned - thats with the tx held normally of course.
The 35 is on a grassy area with the models sitting in the grass. The 100 paces is down my street, provided there are not too many cars in the way, with the model on a 12 inch plastic box. This street has multiple wifi networks and a municiple hotspot on a pole - so it isn't exactly quiet.
In the middle is where I fly my helis; I check with the heli on a wooded table ~ 4 feet I guess and get well over 60 paces (I can't rmemeber when it actually quits and treat that as my go/no go point) with a chain link fence between Tx and model.
So. about the only test results I give any credance to are the type Hilgert did in the early days (and some of the others mentioned in this thread), making sure he was in "free space". All the big numbers published are done that way and represent realisitic, "in flight" scenarios.
Personally, I can't fly accurately enough to get below 1 or 2 feet at 1000 yards - I must be getting old
teamdavey is offline Find More Posts by teamdavey
Old May 28, 2008, 12:18 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
I thought you were buying a Futaba 14MZ with FASST module None of the Spektrum stuff will work with that radio.
village_idiot is offline Find More Posts by village_idiot
Old May 28, 2008, 03:54 PM
Joined May 2008
Range tests prove that the Spektrum has a better range, for some reason, and I had placed my order for the Futaba, but canceled it because I decided to wait until my turbine project was underway (about 1-2 months), and besides, I decided to keep my Spektrum. I'm saving it for my younger brother, one I DO buy the FASST (or a JR radio which I was looking at today. It called my attention from the ad at the top of the page) Nonetheless, I will keep my Spektrum. Haven't gone to my local hobby shop lately (a lot of online ordering) But I plan to buy this nifty little gadget once I do!
P.S: I am in the process of changing my username!!!!!!!!!!!!
Old May 28, 2008, 04:25 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
I shall await
richard hanson is offline Find More Posts by richard hanson
Old May 29, 2008, 03:43 AM
Joined Sep 2000
Originally Posted by TheFlyingAce
Range tests prove that the Spektrum has a better range, for some reason. ...
Well, my practical tests at my local flying field show different results:
Spektrum DX7 EU Version: 470m
Spektrum DX7 US Version: 700m
Futaba FASST: 1030m
Jürgen
Old May 29, 2008, 06:02 AM
lazy-b is offline
Find More Posts by lazy-b
Manila, Philippines
Joined Jul 2004
Guys, Have read somewhere in this Forum, a guy able to test the range of Futaba Fasst system is more than 3.8 Kilometer, they even show the location of the Transmitter and receiver in Google Earth Map......I am really amazed......thats why been thinking of getting a Futaba Fasst system.
look like I have only 2 Choice, either Futaba Fasst or Spectrum DSS.
here is the forum that have range check a Futaba Fasst:
http://www.rcgroups.com/forums/showthread.php?t=831638
lazy-b is offline Find More Posts by lazy-b
Old May 29, 2008, 08:39 AM
Joined May 2008
Originally Posted by richard hanson
I shall await
Yes, yes you shall.....
EDIT: P.S: Did you see my name Change?!?!?!?!?!?!?!?!?!?!?
Old May 29, 2008, 08:45 AM
Joined May 2008
Futaba FASST: 1030m
Jürgen
Actually, the post after you, has a range test in relation to the Futaba System with the 2.4 module. It shows that conclusive range tests go to about 3.8 KM, while one of the first links in this thread has a link to the futaba, which they tested at a range of 2.8 miles, or 4.5km.
Futaba Range Test: http://translate.google.com/translat...hl=de&ie=UTF-8
Rx7 Range test: http://www.rcgroups.com/forums/showthread.php?t=783753
Now I am seriously confused
TheFlyingAce
Old May 29, 2008, 09:54 AM
Sunnyvale, CA, USA
Joined Apr 2000
Check post 20 and you might get a clue why published results vary so much.
Old May 29, 2008, 10:03 AM
Joined May 2008
Oh, I see......test environment matters.....Thanks....
Old May 29, 2008, 10:25 AM
Joined Sep 2000
That's why I perform my own tests at the location I fly most, i.e. my local flying field and under identical conditions on the same day.
Jürgen
Does anyone know anything about Jack Stafford kits? G.F. Beurling Electric Plane Talk 13 Jul 20, 2010 01:34 AM
Discussion does anyone know the transmitting distance of the dx7 nashiem Electric Plane Talk 6 Aug 27, 2007 02:57 AM
Does anyone know if HF-MODEL has a website? JimJams Scale Sailplanes 3 Oct 17, 2005 03:29 AM
Question Does anyone know who has the new wireless Lama in Stock? brucie1dog Coaxial Helicopters 4 Dec 10, 2004 03:05 PM
Does anyone know of an online shop that has gws 9x7 props. The Other Dave Parkflyers 3 Jan 04, 2002 09:33 PM
