Old May 26, 2008, 06:46 PM
TheFlyingAce is offline
Find More Posts by TheFlyingAce
TheFlyingAce's Avatar
Joined May 2008
Spektrum claims the DX7 has full range....does anyone know the actual range in ft?
Does anyone know the actual operational range of the dx7 in ft or miles (if it goes that far) of the dx7? I've never gotten it farther than a couple hundred feet, do I've never tested it to it's capabilities.
TheFlyingAce is offline Find More Posts by TheFlyingAce
Old May 26, 2008, 07:08 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
I rather doubt you will find anyone willing to state a specific figure. Too many variables - terrain, antenna location/orientation, even atmospheric conditions. Accept "as far as you can see the model" and you will be fine.
Bill
ebill3 is offline Find More Posts by ebill3
Old May 26, 2008, 07:13 PM
Joined May 2008
I'm not
I'm not looking for an specific figure, but rather a good estimate, because I can see the model 1/2 a mile away and it not be operational if it's out of range.
Can anybody give me a good estimate, or average, because I want to try and do some long distance flying (at least a mile) with an fpv setup (the cam is well over 3 miles, so that's not the problem, it's the radio's range I'm concerned about) 8D
Thanks to any help.....
Old May 26, 2008, 07:18 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
They have been privately checked at well over a mile - the problem with ANY radio is that in actual use the immediate enviroment (the model) affects this range. even th 6100 which has been blasted roundly by some " expert" works out this far --provided nothing blanks or reflects the incoming signal
In real world use , the manufacturer says " NO!" it is designed for and made for small in close foam flyer stuf - and in that enviroment - nothing even remotely approaches it for light weight and simple use . I have flown my 6100s - as far as I can see the model attitude (40"span models ) but this is a bad idea - the little models are really best at up to a couple of hundred ft.
But modelers being the group that they are - will try stuf till it quits -- even tho forewarned --
richard hanson is offline Find More Posts by richard hanson
Old May 26, 2008, 07:32 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Here you go - real world range tests ON THE GROUND (so air will be further)....
1.7-2.8 miles - sounds pretty full range to me!
http://www.rcgroups.com/forums/showthread.php?t=783753
Old May 26, 2008, 11:01 PM
HobbyCNC is offline
Find More Posts by HobbyCNC
HobbyCNC's Avatar
Joined May 2004
3,500 feet and still had complete control. The on board altimeter verified this on numerous flights. That is far enough for even turbine operations. Flew the DX7/AR9000 setup over 85 flights in my BVM KingCat and NEVER had a frame lost.
Dave
HobbyCNC is offline Find More Posts by HobbyCNC
Old May 27, 2008, 12:26 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
I did some range tests at my local flying field. Tx approx. 1m above ground, rx approx. 1.5m above ground. Max. range with European DX7 (100mW peak power) approx. 470m, US DX7 approx. 700m, Futaba FASST approx. 1030m. All tests done the same day under identical conditions.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old May 27, 2008, 09:43 AM
Joined Oct 2007
Once more -- the POSSIBLE range may not be the range you will see due to your own installation.
Spektrum /JR offers a excellent receiver diversity arrangement for models where blanking or reflections etc., MAY cause reception fading
these have up to 4 receivers .
If you have a special installation - contact Spectum support and ask about it. We also tested a model with on board altimeter - to 1300ft and the model looks very small at that range. If you intend to do out of operator sight flying - (fly via onboard TVfeedback) you could easily get into trouble.
Old May 27, 2008, 11:35 AM
California Condor is online now
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
These flights were made with the DX6 and the AR6000 receiver. Traces are from a ZLog altimeter set at zero at take off.
California Condor is online now Find More Posts by California Condor
Old May 27, 2008, 11:56 AM
teamdavey is online now
Find More Posts by teamdavey
Sunnyvale, CA, USA
Joined Apr 2000
Note that the DX6 Tx output is less than the DX7 by a significant amount - don't have the time to remind myself of the exact figure right now.
Also, if you dig around you will find that Jurgen's numbers represent very much the low end of anyones published figures.
Way back Larry Hilgert checked out a DX6 at way over a mile as underwritten by these http://www.rcgroups.com/forums/showthread.php?t=783753 tests for the DX7.
My own field checks confirm that a 2:1 ratio in (close to) ground test results can result from the local ground conditions so the range of data you see is not surprising. Note also that Jurgen got only 1030 meters for a FASST which others have seen over 2km. Personally I think Jurgen has some sort of personal RF absorber built in but, hey, your milage (literally) may vary
teamdavey is online now Find More Posts by teamdavey
Old May 27, 2008, 03:41 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
It is good upto visual ranges. Beyond visual ranges? Why do you care?
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old May 27, 2008, 04:03 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Jurgen also has a Euro spec radio, so the power is reduced. He did at least one test between full power and Euro power.
village_idiot is offline Find More Posts by village_idiot
Old May 27, 2008, 04:08 PM
Sunnyvale, CA, USA
Joined Apr 2000
Yes - I know. He posted both above. My point was that he gets figures that are the lowest published that I have seen.
Old May 27, 2008, 07:01 PM
Joined Oct 2007
"full range"-- means operation should be good for any distances we use --
This claim has been shown to be quite accurate by recent model meets where the number of operational DSM2 (Spektrum) radios exceeded the the suggested maximum of systems to operate at one time - other 2.4 systems were also working tho only in token representation (one or two examples .)
Basically , not only is the range excellent - the the system functions well even in what some would view as a saturated model enviroment
I would call that "full range"
Old May 27, 2008, 09:18 PM
Danal Estes is offline
Find More Posts by Danal Estes
Flys with Thumbs
Danal Estes's Avatar
Frisco, TX, USA
Joined Sep 2001
http://www.rcgroups.com/forums/newreply.php?do=newreply&noquote=1&p=9840778
Since you have downlink... how about flying a "Flight Log" capable RX,
http://www.spektrumrc.com/Products/D...ProdID=SPM9540
And watching the number of antenna/frame losses? You could easily see when you are hitting the limit of range before any problems occur.
You can verify range for all of us! (For you site/aircraft/conditions, of course)
You'd need the Flight Log (or an Eagle Tree that plugs into the same spot, or similar) and an AR9000 or AR7000 with the new firmware.
Danal Estes is offline Find More Posts by Danal Estes
Does anyone know anything about Jack Stafford kits? Randall Miller Electric Plane Talk 13 Jul 20, 2010 02:34 AM
Discussion does anyone know the transmitting distance of the dx7 nashiem Electric Plane Talk 6 Aug 27, 2007 03:57 AM
Does anyone know if HF-MODEL has a website? JimJams Scale Sailplanes 3 Oct 17, 2005 04:29 AM
Question Does anyone know who has the new wireless Lama in Stock? brucie1dog Coaxial Helicopters 4 Dec 10, 2004 04:05 PM
Does anyone know of an online shop that has gws 9x7 props. The Other Dave Parkflyers 3 Jan 04, 2002 10:33 PM
