u.k
Joined Mar 2005
Onwards and upwards!
Tired again (early shift does nothing for me) I messed around with the wing parts tonight. Two pairs of inner ribs needed laminating and all the ribs from the root to the outer end of the spoiler box needed holes drilling for the cable guides, some need a single hole, some need a slot big enough for two guides. Five ribs had to be modified for the spoiler box. There are no holes for the spoiler cables in the fuselage sides so I marked the left side using the root rib, saves a bit of guesswork later. The lower spar, trailing edge and the false leading edge are cut to length and everything is dry fitted, no glue tonight. Cheers Gary
Toiling
Spent about nine hours today bashing balsa.
Have to post while I can remember what I did! Where where we? Oh yes, inner wing panel. I sheeted the upper 'D' box then turned it over for the lower surface. It is important that the structure is well pinned down as any warps will be fixed in as a 'feature' for eternity. But before sheeting the bottom don't forget to fit the spoiler cable guides! Instructions suggest a heat gun to bend the plastic guides, I don't have a heat gun but my wife has a hairdryer, job done but it burnt my fingers at close range!! I then fixed the spoiler box in place and I was happy that my guess at the rib cut-out needed was about right, the instructions could have been slightly more helpful here with a full size drawing of the ribs. There is a gap between the spoiler box and the sheeting, this was filled with 1/16th strip. I mentioned a drawing problem earlier, there was none! I could just not see what was going on under the woodwork, comes from having only one inner panel drawing to work on I suppose. Added rib capping strips (except at the dihedral break) and the leading edge which is pre-shaped, very little sanding was needed to blend it in to the sheeting. Will split this post, next installment in about 20 minutes (for those who can't wait).
