Old May 26, 2008, 01:14 PM
BACKEMFNRG is offline
Find More Posts by BACKEMFNRG
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
Question
How much KV is too much for 1/5th scale TTFM-1e?
I have aquired a Hacker 5S motor (7300KVapprox.) and its brand new.
I was wondering if this is too much, then I could sell it and get something else.
These aren't the easiest motors to come by, somewhat of a special wind.
I got a great deal .
Help please, I only have a Schulze U-Force 75amp controller.
BACKEMFNRG is offline Find More Posts by BACKEMFNRG
Old May 26, 2008, 03:39 PM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
too much, unless you turn down your endpoints... or if you are doing straight line speed runs.... "power is nothing without control"
I say hold on to it... turn down the power and have fun... no need to waste a good motor... but I say 5700KV on 7.4 volts is more than enough and it seems that is what 90% of brushless riders are using
Akura2 is offline Find More Posts by Akura2
Old May 26, 2008, 04:40 PM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
Thanks Jimi
Old May 26, 2008, 04:52 PM
5150driver is offline
Find More Posts by 5150driver
burnout king
cali
Joined Oct 2006
i race with a 7700 just fine it's all about gearing. oh and finger control
5150driver is offline Find More Posts by 5150driver
Old May 29, 2008, 06:50 PM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
Could you recommend some gears? I'm usually a direct drive electric boat racer.
Thats a small pinion or big spur right?
Thanks.
Old May 29, 2008, 07:02 PM
burnout king
cali
Joined Oct 2006
pinion 26 48p
spur 96 48p
front sprocket 10
rear sprocket is 25
since you probaby dont have the same gears just try to get the ratio around the same. my bike can pul wheeies but a lot harder to with this gearing.
Old May 29, 2008, 07:25 PM
Moto Migs is offline
Find More Posts by Moto Migs
r/c nut
Moto Migs's Avatar
Fremont, CA
Joined May 2008
pinion 26 48p
spur 96 48p
front sprocket 10
rear sprocket is 25
Is that the gearing you're running with your 7700....?
Moto Migs is offline Find More Posts by Moto Migs
Old May 29, 2008, 07:34 PM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
Great, thanks. I'll need to order some gears up.
I've got all the sprockets from the early CNR days.
I was one of the first guys on here to get a FM-1e and trick it out about 5 years ago'ish. Just kept it shelved for a long time and now with the new 1/8th's coming out I'm dusting off the 1/5th and piecing back together.
Old May 29, 2008, 07:44 PM
burnout king
cali
Joined Oct 2006
moto---thats with the 7700. you going to be able to stop by rams natc race this weekend in sj???
ray--i was running a 9/23 rear gearing that was cnr. hit the ratios and you'll be fine.
Old May 29, 2008, 07:49 PM
r/c nut
Moto Migs's Avatar
Fremont, CA
Joined May 2008
Ya, I'm gonna try and make it out there for both days for a little bit. I'll just be spectating though. I haven't had a chance to get any run time with this TTN that I bought. Not to mention I need to get a new radio since I sold my M11 w/Spektrum module about a year ago.
Old May 29, 2008, 08:15 PM
burnout king
cali
Joined Oct 2006
i use a m8 with a y-harness. third channel mixing is nice but not required.
Old May 29, 2008, 08:19 PM
r/c nut
Moto Migs's Avatar
Fremont, CA
Joined May 2008
What's the Y-harness used for....?
I'm guessing the third channel mixing is used for front/rear brakes...?
Old May 29, 2008, 08:57 PM
burnout king
cali
Joined Oct 2006
ya front and rear bias is third channel mixing. since the m8 doesn't have the mixing ability i use the y harrness and set my endpoints for full front brake then program the speedo for the rear brake
Old May 29, 2008, 09:54 PM
r/c nut
Moto Migs's Avatar
Fremont, CA
Joined May 2008
Oh ok... that makes sense. I'm gonna probably need some help from you local guys to help setup my bike(s) when I get everything I need. Stubby has already given me a list of some necessity parts.
June is going to be a bad month for me financially with my daughters graduation coming up and some other things that need to get paid.
Sorry for getting off topic....
Old May 29, 2008, 11:47 PM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
I don't mind. It's all good.
1/5th Scale Nieuport 11 Norm Scale Kit/Scratch Built 11 Mar 25, 2008 09:26 AM
Fuel tank location for 1/5th scale? SailplaneDave Fuel Warbirds 1 Jul 08, 2005 05:17 PM
Catapult launcher for 1/12 scale planes dave_lilley Power Systems 68 Jan 08, 2002 08:27 AM
1/5th scale Nieuport flies cwatters Scale Kit/Scratch Built 3 May 14, 2001 03:33 PM
