Old Jul 22, 2001, 01:21 AM
buckeyes1997 is offline
Find More Posts by buckeyes1997
buckeyes1997's Avatar
columbus, oh, usa
Joined Jun 2001
blue foam plane pics???
hello everyone. im working on designing a few blue foam planes for both electric and gas power. i would like to see any and all pictures of everyone else's attempt....successful or not..hehe. so post yer pics/links and let the world take a peek.
thanks.
matt
<img height="250" src=http://www2.eboard.com/eboard/boards/7/82/29/RCcombat/att-349384/51side.jpg>
[This message has been edited by buckeyes1997 (edited 07-22-2001).]
buckeyes1997 is offline Find More Posts by buckeyes1997
Old Jul 22, 2001, 10:10 AM
e-flyer is offline
Find More Posts by e-flyer
Stuck in my wizard suit
e-flyer's Avatar
Deale,MD,USA
Joined Apr 2001
heres a pic of a foam plate that marked and I built. it flies quite well....
Alex
[This message has been edited by e-flyer (edited 07-22-2001).]
e-flyer is offline Find More Posts by e-flyer
Old Jul 22, 2001, 10:55 AM
dave_lilley is offline
Find More Posts by dave_lilley
Texas
Joined Aug 1999
Link to video: http://www.geocities.com/dave_lilley
Hey, you may want to also check out this thread on foam bashing: http://www.ezonemag.com/disc/Forum12/HTML/001812.html
[This message has been edited by dave_lilley (edited 07-22-2001).]
dave_lilley is offline Find More Posts by dave_lilley
Old Jul 23, 2001, 04:48 PM
jastown is offline
Find More Posts by jastown
Warsaw, IN, USA
Joined Jun 2001
I've made several blue foam planes in the last two weeks.
You can see them at:
http://www.jastown.com/airplane/tindonkey.htm
jastown is offline Find More Posts by jastown
Old Jul 23, 2001, 11:13 PM
columbus, oh, usa
Joined Jun 2001
those are great!!! im going to check at lowes for that bluecore stuff. is that what its called?? what area of the store would i look for it in??
i know there are a lot more planes than these three out there so post em here for the world to see.
Old Jul 24, 2001, 02:21 AM
ChrisP is offline
Find More Posts by ChrisP
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Er.........
It was Chris from Germany and not Peter !
Love the Roland, so we'll let that go.
PS - The only thing that's missing (dare I say) is the characteristic black nose with the 4 corners of the fuselage picked out in a stripe. You can see that on the cockpit photo. Also the LE of the wing, tailplane and fin have a black stripe.
Ugly beast, isn't it !!!
ChrisP is offline Find More Posts by ChrisP
Old Jul 24, 2001, 06:48 AM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
Look in the building supplies, by the lumber. In the real world, it's used for insulation. Depending on the supplier you'll find it in blue, pink or grey - the Home Depot by me has pink (Owens Corning). They come in thicknesses from 1/2" to 2" or 3". You need to be careful aligning your pieces when using the thicker stuff because there are 3 or 4 slots milled down the length of the sheet.
I've heard that there is a slight difference between the density of pink, blue and grey foam, but I haven't detected any differences between pink and blue.
You will also find 1/4" or 3/8" foam in 1'x8' sheets - I've seen these used for fins and stabs. This appears to have a similar density to the thicker sheets, but the feel is different.
Lastly, you'll find white foam. This is considerably less dense than the others. It makes good cores for veneered wings, but you might find it too weak used by it self. Home Depot usually only has this in 1/2"x4' sheets in a width to fit between furring strips (16" or 24" minus 1.5")- it's usually used as insulation behind dry wall over a basement wall.
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old Jul 24, 2001, 09:22 AM
jastown is offline
Warsaw, IN, USA
Joined Jun 2001
Dow makes Bluecor. It's 1/4" X 48" X 50 Feet in a fanfold package. It is used as insulation under sideing and makes very nice planes. You can make 20 to 30 planes for $25 or $30.
Old Jul 24, 2001, 09:56 AM
mattk17 is offline
Find More Posts by mattk17
mattk17's Avatar
Dallas,TX
Joined Jul 2001
After reading from others here, I went to home depot and lowes looking for the blue dowcor foam. At home depot all I found is this pink 1/4" stuff and didn't like that because well it's pink! At lowes they didn't have anything but some 3/4"x4'x8' sheets.
Where do I find the 1/4" blue stuff?
mattk17 is offline Find More Posts by mattk17
Old Jul 24, 2001, 03:03 PM
jastown is offline
Warsaw, IN, USA
Joined Jun 2001
I got mine at Lowes. Ask places that sell siding. They have a page for it at the Dow web site.
Old Jul 24, 2001, 03:58 PM
sb1 is offline
sb1
Find More Posts by sb1
sb1
Charlotte,NC
Joined Jun 2001
Hey jastown,
I like your planes, are they all 280 powered,I am thinking of building a larger version with a 400 g/box, 2.33:1 would be too fast I think. Do you cut the wings with a utility knife then shape them with sandpaper??? What type of glue do you use??? Keep on building neat planes.
sb1 is offline Find More Posts by sb1
Old Jul 24, 2001, 04:59 PM
jastown is offline
Warsaw, IN, USA
Joined Jun 2001
Most are powered with the litestik powerplant. GWS DX-A gearbox - I think the motors are 180's ???, The biggest one needs at least a 280.
I cut them with a razor knife and trim with the knife with no sanding. Elmers ProBond Glue is what I use and I works very well on this material.
I have lots of ideas for future planes, I will try to make up web pages as I go.
Thank you for your comments.
Jon
FMS plane to blue foam rchotrod Foamies (Kits) 3 May 23, 2004 03:51 PM
My Meat tray Foam Plane:pics FLYWINGFAN Parkflyers 19 Jan 06, 2004 10:25 PM
My First Blue Foam Scratch Built Plane Randy Due Foamies (Kits) 23 Dec 20, 2003 02:11 PM
Blue Foam IFO-ish Plane at SEFF--Plans DavidJ Foamies (Kits) 7 Jun 27, 2003 02:04 PM
My first blue foam plane, the XB-1 SUNDIAL indybudd Foamies (Kits) 11 Feb 06, 2003 03:34 PM
