Old May 25, 2008, 09:11 PM
Dewey Parker is offline
Find More Posts by Dewey Parker
Joined Aug 2007
Programming different models on DX6i
Can someone explain to me how to program different models on the DX6i? I have set up one model, but can't see how to set up a second one. When I go to Models on the menu, it just lists the one I already have. How do I start a second, or third model without affecting the first one?
Can someone sort of list the steps one by one to get me started?
Thanks! I really appreciate it.
Dewey
Dewey Parker is offline Find More Posts by Dewey Parker
Old May 26, 2008, 07:18 AM
schoonerj is offline
Find More Posts by schoonerj
schoonerj's Avatar
Berne, NY
Joined Sep 2004
Here is a link to the manual online. It is 13mb if you need to downlaod it.
http://www.horizonhobby.com/ProdInfo...nual-LoRes.pdf
Here are the basic steps.
Turn the transmitter on
Press the roller to access the Adjustment List
Press and hold for 1 sec, if you hold the roller button for 2-3 sec the setup menu comes up. You can scroll to the last menu option in the setup menu which will be the Adjustment menu.
Turn the roller wheel once to the right to highlight the Model Select option
Press the wheel, this should bring up the model select menu
Turn the wheel to the right, and the model number on top should change. Model1, Model2 etc.
Press the roller and that models settings will be downloaded to the radio.
On the main screen you should see the MDL# "plane name" Displayed.
It is much easier if you name the models!
And off you go. Make sure you follow the binding instructions to enable model safe. This will prevent selecting the wrong model. If the wrong model is selected it won't work, adn you'll know you almost lost a plane.
Hope this makes sense, it's still early yet
schoonerj is offline Find More Posts by schoonerj
Discussion Advanced CX2 on DX6i Programming MikeyToo Coaxial Helicopters 2 Feb 01, 2008 12:45 PM
Programming not working on Futaba T6XHs. HankF Radios 3 Jan 18, 2003 05:07 PM
Putting different plugs on servos? Ryan Nau Radios 4 Jul 17, 2002 10:46 PM
Invisible models on FMS ??? RookieOne Electric Plane Talk 3 Jun 21, 2002 10:41 PM
GWS Tiger Moth - are there different models? Peter Young Foamies (Kits) 4 Jun 06, 2002 08:36 AM
