Old May 24, 2008, 08:01 PM
myp is offline
myp
Find More Posts by myp
myp
Joined Oct 2007
Question
Suppo motor for 15-16 oz 3D plane?
I will be getting my first 3D plane and would like suggestions for a Suppo motor + prop for a 15-16 oz 3D flyer (e.g. Flash, DW Foamie Yak)? I will be using my TP 1320 3s batteries.
thanks
mike
myp is offline Find More Posts by myp
Old May 24, 2008, 08:40 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
A 38g A2208/14 (1450Kv) with an 8x4 GWS HD on 3s gets you this:
10.8v, 11.90A, 128W, 11190rpm, 42.2mph, 686g, 24.16oz, 5.36g/W
If you think your 1320's can cope with closer to 20A, them the A2208/12 (1800Kv) with a Graupner 7x4 SF gets you this:
10.7v, 18.25A, 195W, 12330rpm, 46.7mph, 787g, 27.71oz, 4.04g/W
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 24, 2008, 10:04 PM
manuel v is online now
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
DW Foamie is 38.7 inch wingspan.
and fly with 10-11 inch propeller for 3D.
Any good substitute Hacker A20-22L. with same o lower Kv.
Manuel V.
manuel v is online now Find More Posts by manuel v
Old May 24, 2008, 10:35 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
The only Suppo I can see is the 51g A2212/15 - that spins an 11x5.5 @ 10.3A/111W and gets you 25.3oz @ 32mph or a 2212/13 which with a 10x6 GWS HD gets you 28oz @ 43mph from 13.05A/141W.
3D doesn't require a large prop - it requires a good thrust/weight ratio and in my book one of the 2208's (13g lighter) might be the better bet.
Old May 26, 2008, 11:22 AM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
2208/17 might get you there (these are available from Lightflight RC). I run a 9x5 GWS direct drive prop on one on a sport plane and while full throttle bursts are beyond the offical ratings of the motor at 12+A I'm seldom at full throttle for more than a few second and get 25 minute flights out of a 3s 1200 pack.
My application is far different from yours but that's closer to the large diameter prop you're looking for. An APC 10x3.8 SF MIGHT be ok on the motor.
BEC is offline Find More Posts by BEC
Discussion Favorite servo for 16 oz 3D JamesD 3D Flying 7 Feb 02, 2007 11:25 AM
Motor/ESC/Battery Combo for 9.5 oz 3D Plane? rmgmag 3D Flying 3 Nov 08, 2005 08:28 PM
10 oz. 3D plane-which motor ? RonJ 3D Flying 24 Jul 14, 2005 01:36 PM
Which New hacker outrunner for ~13-15 oz 3D plane? Blackhawk3D Power Systems 5 Apr 14, 2005 11:01 PM
3D power for a 4 oz AUW plane mycamel Power Systems 2 Nov 12, 2003 11:10 AM
