Old May 24, 2008, 08:00 PM
mitchfx is offline
Find More Posts by mitchfx
Altadena, CA
Joined Mar 2008
DX6i USB cable & Throttle Hold?
I just got this usb cable for my DX6i - http://www.helidirect.com/product_in...oducts_id=3171
It works fine for the main stick control, plus one of the channels (x rotation) is tied to the "gear/F Mode" toggle switch on the DX6i. However, what I really need is to enable the "Throttle Hold" switch to practice with CP helis. I'm not sure how much this could be changed via software (cable uses built in windows game controller interface) or if it's possible to somehow remap this with the DX6i itself.
Any help appreciated.
mitchfx is offline Find More Posts by mitchfx
Old May 24, 2008, 11:41 PM
skirtz is offline
Find More Posts by skirtz
Joined Sep 2002
"Throttle Hold" switch tells the Tx to switch to another set of Throttle and Pitch curves that are used for auto rotation. All this happens internally in the Tx and the cable does not transfer any information for the event to the simulator. If your Tx have the ability to assign a real Tx channel to a switch, you can assign for example channel 5 or 6 to that switch and then assign that channel to control the Idle Up in the simulator.
skirtz is offline Find More Posts by skirtz
Old May 25, 2008, 09:32 AM
mitchfx is offline
Altadena, CA
Joined Mar 2008
Stefan,
you are exactly right, I see that now. One thing I'm not sure about at this point is when setting up the controller for CV for use with a cp heli is do I calibrate and use the dx6i when already SET for that specific heli mode inside the tx? Or do I want to calibrate the ranges with the tx in some type of "generic/basic" mode, then switch to the heli program mode after calibration? Or possibly stay in a basic mode the whole time and let CV do the "program" curves? All this is very confusing to say the least.
thanks,
Mitch
Old May 25, 2008, 10:47 AM
skirtz is offline
Joined Sep 2002
ClearView implements Tx simulation and provides all curves on per model basis. Therefore, ClearView needs to read only the 4 stick positions from your Tx. ClearView generates the pitch curves (channel 6 on heli Tx) based on throttle stick position and flight mode you are in. That way, you can use any 4 ch Tx and fly CP helis in 3d mode (which normally requires 5 ch radio). As practical matter, you must have a single model on the Tx that is used for all models in ClearView. Typically, you create a new default plane model in the Tx and name it "sim" or whatever, so you know what the model is. Then, you callibrate in Windows, and after that you use that model for ALL ClearView models.
Stefan
http://rcflightsim.com
Discussion Program SPektrum DX6I Aero Throttle Hold GeneR Radios 4 Sep 09, 2009 06:39 AM
Aiptek USB Cable??? SpaKack Parkflyers 3 Aug 06, 2002 08:30 PM
Throttle Hold johnhlong Electric Heli Talk 10 Jul 16, 2002 07:40 PM
Trainer to USB cable pillboy Electric Plane Talk 5 Jun 26, 2002 07:59 PM
Throttle hold in governor mode dshuen Electric Heli Talk 0 Apr 28, 2002 11:48 PM
