Old May 23, 2008, 06:59 PM
wahoo63 is offline
Find More Posts by wahoo63
Joined Oct 2006
Vpx
Hi Everyone,
I have a Black&Decker VPX cartridge style 7 volt pack that I thought would make a good Rx pack, trouble is I've searched and searched and could only find the How-To's for the DeWalt 36v.
I'm not sure on the best way to go about tearing this thing apart.
Anyone using this style battery cartridge ?
John
wahoo63 is offline Find More Posts by wahoo63
Old May 23, 2008, 07:15 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
crack case with hammer
hall woo is offline Find More Posts by hall woo
Old May 23, 2008, 07:27 PM
CrashM@ster is offline
Find More Posts by CrashM@ster
United States, CA, Antelope
Joined May 2008
first, peel the sticker then you will see tabs to take top and bottom off.
here is the inside of a VPX.
CrashM@ster is offline Find More Posts by CrashM@ster
Old May 23, 2008, 07:29 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Once you peel the label off it is obvious.
http://www.rcgroups.com/forums/showthread.php?t=768729
Charles
Old May 23, 2008, 07:30 PM
lquick is offline
Find More Posts by lquick
Joined Feb 2003
If you just peel off the lable, you can see the clips that hold the end caps in place. Lift the clip and the cap comes off.
Lloyd
lquick is offline Find More Posts by lquick
Old May 23, 2008, 08:59 PM
wahoo63 is offline
Joined Oct 2006
Wish I woulda peeled the label b4 i smacked it with a hammer.
Thanks guys,
John
Old May 24, 2008, 04:27 AM
coro is offline
Find More Posts by coro
Slovakia
Joined Apr 2005
Try to peel the tabs (gently) before using them, to see whether they are worth using or will fall apart. There were reports of poor spot welding of VPX pack.
There is no such problem soldering small 1100mAh M1A 123 cells, using ordinary tools, such as that which is with "adult" big A123 2300mAh M1 cells...
coro is offline Find More Posts by coro
Old May 24, 2008, 07:37 AM
Tentacle is offline
Find More Posts by Tentacle
foamhead
Joined Aug 2005
What is the circuit board attached? A charging regulator?Do you need it to build the pack?
Tentacle is offline Find More Posts by Tentacle
Old May 24, 2008, 12:27 PM
wahoo63 is offline
Joined Oct 2006
This post is temporarily hidden while wahoo63 edits it ? post 6
Old May 24, 2008, 06:33 PM
Al M is online now
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
Remove the junk from the cells.
Al M is online now Find More Posts by Al M
Old May 25, 2008, 05:11 AM
JWilliams2 is offline
Find More Posts by JWilliams2
JWilliams2's Avatar
NY State
Joined Jan 2007
Yeah it's all useless, just get to the pure cell.
JWilliams2 is offline Find More Posts by JWilliams2
