Old Jan 19, 2003, 03:09 PM
DavidJ is offline
Find More Posts by DavidJ
Jefferson, GA
Joined Jul 2002
ParkFlyer Wall Hangers--How to Make Your Own!
Made some wall hangers for my planes. Thought I would share them with the forum in case others would like to make them. Here are the steps:
1.) Cut a 5"x1-3/8" block from a piece of good grade 1"x4"
2.) Take some 1/2" dowels and cut two 6-1/2" sections
3.) Drill 1/2" wide holes in block about 1/2" deep, 3-1/2" apart on center
4.) Set dowels in block with glue
5.) Paint the block and end of dowels with color of choice
6.) Get some 1/2" foam pipe insulation (Wal-Mart, $3)
7.) Cut foam in two 6" pieces
8.) Remove some the the foam (approx 25mm) lengthwise from the tube so that it will fit tightly on the dowels (test fit a couple of times)
9.) Put the foam on the dowel, remove the self stick tape backing, and seal tightly together around the dowel
10.) Drill a small home in the top center of the block for a screw
11.) Screw to wall (if sheetrock, use an anchor)
12.) Hang planes on them!
Very cheap and easy to do. Just a copy of a design sold by a brand name plane accessory maker. Cheap, sturdy, protects the plane, and looks good. The hanger just about disappears once the plane is on them. Attached some pix to help.
If you are interested in building some, and have questions, feel free to ask!
David J.
DavidJ is offline Find More Posts by DavidJ
Old Jan 19, 2003, 03:10 PM
DavidJ is offline
Jefferson, GA
Joined Jul 2002
more pix.....
Old Jan 19, 2003, 03:34 PM
Thomas Manson is offline
Find More Posts by Thomas Manson
Tee Sqaured
Thomas Manson's Avatar
Langley, B.C, Canada
Joined Jun 2001
Very good idea David!
Heres an idea of you have more cealing space that wall space. It's also very simple, just put some eye hooks in the cealing , and put coat hagers in them! use some foam padding if you want, here some pics of mine.
Thomas Manson is offline Find More Posts by Thomas Manson
Old Jan 19, 2003, 03:35 PM
Tee Sqaured
Joined Jun 2001
close up.....
Old Jan 19, 2003, 03:36 PM
John2003 is offline
Find More Posts by John2003
John2003's Avatar
Berkshire, UK
Joined Jan 2003
v clever.....cool. I myself have a problem. I dont have a plane yet and the one i am getting is the T-IFO....a delta plane...no proper tail!! hmm...I would like to hang it up though...hmmm...
John2003 is offline Find More Posts by John2003
Old Jan 19, 2003, 03:37 PM
Tee Sqaured
Joined Jun 2001
Mine would work with an IFO, His would also work if you put the wing on the long rails.
Old Jan 19, 2003, 03:40 PM
John2003 is offline
John2003's Avatar
Berkshire, UK
Joined Jan 2003
I see that yours would work but the only way i see that DavidJ's would work is if the plane was mounted not hanging but possitioned sticking out from the wall horizontally.....is that what you meant?
Old Feb 01, 2003, 01:52 AM
Mathias88 is offline
Find More Posts by Mathias88
Mathias88's Avatar
Gothenburg, Sweden
Joined Oct 2002
Here is one way to store the planes, and I think it would work for you to John2003.
Mathias88 is offline Find More Posts by Mathias88
Old Feb 01, 2003, 05:28 AM
John2003 is offline
John2003's Avatar
Berkshire, UK
Joined Jan 2003
yeah, that would work. So just some string attached to a hook screwed into the ceiling? I think ill do that, but with fishing line (make it look like it just hovering there).
thanks.
Old Feb 01, 2003, 06:56 AM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
Mine hang in the basement from hangers stolen from the wife.
I have steel beams that run back and forth and cross each other so I have lots of area to hang. Just got my 25 x 17 foot gameroom framed in so I am losing lots of space to hang planes up.
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Newbie: How to make your own battery packs? DaveyDave Batteries and Chargers 23 Sep 13, 2010 06:38 PM
Question How to make your own 3D models for AFP(D)? Dennis.f Simulators 2 Mar 15, 2006 02:19 PM
Mini-HowTo How-to make your own plans ! ! ! ! ! ! ! 3dflyindan Indoor Pattern/F3P 2 Mar 13, 2006 02:29 PM
how to make your own canopy? chainick The Builders Workshop 7 Feb 13, 2005 02:52 AM
Question How to make your own JST connector ? tibofo Power Systems 1 Dec 30, 2004 05:47 AM
