Old Jan 19, 2003, 02:42 PM
Jeff F
Jeff F
Guest
n/a Posts
Body Painting - Type of Paint - Tips - Flaking Off
Are their any cheaper alternatives available "off the shelf" to paint clear
Lexan bodies?
The Kyosho Polyca paint I airbrushed didn't stand up to racing very well,
it's flaking off at the impact areas on the bumpers in big chunks. Did I do
something wrong?
What type of surface prep do you use?
Jeff
Old Jan 19, 2003, 04:12 PM
Dilbert Firestorm
Dilbert Firestorm
Guest
n/a Posts
Re: Body Painting - Type of Paint - Tips - Flaking Off
Jeff F wrote:> Are their any cheaper alternatives available "off the shelf" to
paint clear
> Lexan bodies?
> something wrong?
um, I think you're supposed to paint on the inside of the body, not outside of
the body, assuming thats what you did.
Old Jan 19, 2003, 10:52 PM
Snape
Snape
Guest
n/a Posts
shelf" to
> paint clear
> > Lexan bodies?
well,
do
> > something wrong?
outside of
And you should graze out the inside with metal wool stuff to roughen it up,
that stops the paint flaking when the plastic gets bent.
And usually most people have to have 2 shells anyway. One for smashing up in
races and one for just driving it around.
Old Jan 19, 2003, 11:12 PM
Tempestnightmare
Tempestnightmare
Guest
n/a Posts
Iuse Spray cans...make sure the temp of the paint is at least 70 degrees f.
(both for air brush and can)
Then use 000# steel wool to etch the inside of the body and spray several
light coats of paint, let each coat dry...
then use a back up coat of silver or white to seal it..
Jon
"Jeff F" <jfremder@myrealbox.com> wrote in message
news:b0e7it$o454i$1@ID-57870.news.dfncis.de...
clear
> Lexan bodies?
do
> something wrong?
> Jeff
Old Jan 19, 2003, 11:22 PM
123outlet
123outlet
Guest
n/a Posts
Remember to wash the inside of the body before you do anything on it....
with warm water and neutal soaps like those you use to wash plates.... I
think you can find them in your kitchen....
I don't used to wool the body, but most of my bodies can last for almost
half year.... without major crash... I mean even the body have damaged,
those paints will not flak off...
Usually I use faskcolor from Parma to airbrush my bodies, and sometimes
Tamiya PC series will do the job.
Check for my bodies in my ebay auctions and leave some comments thx.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3108404365
clear
> Lexan bodies?
do
> something wrong?
> Jeff
Old Feb 26, 2008, 08:36 AM
wiangube is offline
Find More Posts by wiangube
wiangube's Avatar
Baltimore
Joined Feb 2008
Hi Jeff F,
I would recommend you to try the NFL Face Painting Kit from here:
www.bodypainting.com
just in case you want some good results.
wiangube is offline Find More Posts by wiangube
Discussion DX7 - paint flaking off U.S.U.L Radios 20 Jun 20, 2007 06:35 AM
Painting the GWS C-47--type of paint?? Waldo Pepper Foamies (Kits) 3 Oct 28, 2004 07:20 PM
Multiplex Twinstar, Cargo, etc. - What type of Paint? sgil2001 Foamies (Kits) 7 May 31, 2002 06:45 AM
What type of paint can I use for GWS moth cowling?? chargin Parkflyers 3 Jan 13, 2002 07:25 AM
Anybody know what type of paint I could use on Scorpio ME 109? slowflyer Foamies (Kits) 6 May 24, 2001 08:25 PM
