Old Jan 19, 2003, 12:50 PM
eye8it is offline
Find More Posts by eye8it
Craving My First Hover
Ennis, Tx
Joined Dec 2002
Good run of bad luck with the Corona
After building the Corona, I couldn't wait to learn to fly. I made some training gear out of wooden dowls and found a big slab of concrete to slide around on. I got about a foot off the ground (on accident) and let the throttle off to set her back down, but when she came down, I had my first boom strike. I tried to straighten out the boom by hand and it broke in half.
That day, I got to run my new heli for about 60 seconds.
Fast Forward 2 weeks (today)
My new tail boom came in and after installing it and freshly charging 3 battery packs, I was off to play. I ran her for about 60 seconds and then the Main Rotor blades starting hitting the Tail Rotor blades and before I could shut it down, One of the Tail blades snapped off.
Now I get to order more parts and wait. I've had this heli for 1 month and I've had it running for a total of about 2 minutes. I am discouraged, but at the same time, I'm determined.
eye8it is offline Find More Posts by eye8it
Old Jan 19, 2003, 12:56 PM
gmaster is offline
Find More Posts by gmaster
Hooked Heli Human
gmaster's Avatar
Western NC
Joined Dec 2002
how did the main rotor blades hit the tail?
gmaster is offline Find More Posts by gmaster
Old Jan 19, 2003, 01:07 PM
atcvector is offline
Find More Posts by atcvector
Joined Jan 2003
My procedure for fixing a bent tail boom (from one of the Arlton brothers). Remove the boom from the helicopter and use a wooden dowel the same diameter as the inside of the tail boom. Carefully force the dowel through the boom. By doing this you can get the boom fairly straight or at least straight enough to use.
Hope this helps.
Scott
atcvector is offline Find More Posts by atcvector
fig8 is offline
Find More Posts by fig8
Cnc-Nut
fig8's Avatar
USA, FL, Hudson
Joined Sep 2002
I'll bet he put the Nitro version tail boom on instead. It's shorter
fig8 is offline Find More Posts by fig8
Old Jan 19, 2003, 01:48 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
If he got the nitro version of the tail, he would have had to cut down the wire drive to match it.
I think gmaster is right...there is no way the main rotor can hit the tail rotor on a properly bit Corona. Something is seriously wrong.
I took a pic of my Corona's tail...you'll see there's about two inches between the tip of the main rotor blade and the tip of the tail rotor blade.
Toshi
TMorita is offline Find More Posts by TMorita
Old Jan 19, 2003, 01:50 PM
gmaster is offline
Hooked Heli Human
gmaster's Avatar
Western NC
Joined Dec 2002
Toshi.. thats what i was thinking.. I remember seeing vkmaynards corona 120 and i noticed it had lots of clearance... and i have seen a lot of videos and pics...
ey8it... any way you can take pics of what your corona looks like.. give us more information..
Old Jan 19, 2003, 02:13 PM
Wright Flyer is offline
Find More Posts by Wright Flyer
(aka Cliff Lawson)
Wright Flyer's Avatar
United Kingdom, Essex
Joined Oct 2001
Hi, I've read about this boom straightening using a wooden rod a few times but just one thing I don't understand - what about the nylon bushing that are a friction fit inside the boom. Don't they get in the way? But if you remove/replace them don't they then work loose?
Cliff
Wright Flyer is offline Find More Posts by Wright Flyer
Old Jan 19, 2003, 02:58 PM
eye8it is offline
Ennis, Tx
Joined Dec 2002
I don't have a camera so I can't post a pic. I did some measurements and my tail boom is about 18" long. I also measured the gap between my main blades and the remaining half of my tail blade and it's about a 1/16 of and inch (maybe less). I don't remember it being near that close when I first built it.
I never thought of checking this when I put on the new tail boom. I ordered the new boom over the phone and just assumed I was getting the stock boom.
Old Jan 19, 2003, 03:04 PM
eye8it is offline
Ennis, Tx
Joined Dec 2002
I just dug up the pieces to my old tail boom and compared the lengths. My new tail boom is exactly the same size as the old one.
Old Jan 19, 2003, 03:08 PM
TMorita is offline
Joined May 2002
Stock tailboom is exactly 17.5 inches long.
Toshi
Old Jan 19, 2003, 03:11 PM
TMorita is offline
Joined May 2002
1.75 inches of clearance between main rotor blade and tail rotor blade.
Toshi
Old Jan 19, 2003, 03:18 PM
TMorita is offline
Joined May 2002
Main rotor blades are 13 inches from tip to bolt hole.
Old Jan 19, 2003, 03:19 PM
TMorita is offline
Joined May 2002
Tail rotor tip to center is 4 inches.
TMorita is offline
Joined May 2002
19 inches from the main rotor shaft to the tail rotor hub center.
Old Jan 19, 2003, 03:22 PM
TMorita is offline
Joined May 2002
Hopefully those pics will help you solve the puzzle...hopefully it's not a local distortion in the space-time continuum...
Toshi
Bad luck with Simprop Selection. Kimble_Schmitz Electric Sailplanes 10 May 08, 2003 08:16 AM
Boy have I had some bad luck with orders latley buzzsaw 46 Vendor Talk 5 Feb 19, 2003 08:16 AM
Help! Bad Luck with HS-55's E's-R-Gr8 Radios 3 Nov 18, 2002 07:53 PM
a run of bad luck -- advice on trainer? joey221 Beginner Training Area (Aircraft-Electric) 9 Jun 12, 2002 10:29 AM
Bad luck with I'net purchases Larry Dudeck Electric Plane Talk 7 Jan 13, 2002 08:25 AM
