Old Jan 19, 2003, 12:39 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
I found a handy Slowstick repair fix for aluminum channel repairs!
I use Heat Shrink Tubing from Radio Shack on my wire solder/splicing jobs. The tubing I use is Radio Shack #278-1627B (It's a Variety Pack). I found out yesterday that the largest tube fits the Slowstick aluminum channel EXACTLY, it's a little tight but it will slide over the channel. I decided to try this because I used my Channel Locks to bend a little Down & Left in an effort to reduce porpoising, The Heat-Shrink tubing I fugured would cover up the slight bend & scratches that the Channel Locks left.
I go to thinking, if this is so tight without heat shrinking it, just think how tight it will be if you put your Iron to it! This might be an ideal answer to a Cracked or Broken Channel since those things are hard to come by.
P.S. - I was suprised how easy this was to bend, has anybody found a place where replacement channels can be bought?
-Mike-
mrebman is offline Find More Posts by mrebman
Old Jan 19, 2003, 02:21 PM
eBird is offline
Find More Posts by eBird
Look! Up in the sky!
eBird's Avatar
Grand Junction, Colorado
Joined Jul 2002
Re: I found a handy Slowstick repair fix for aluminum channel repairs!
Does that mean you trashed yours?
Here's the link to buy a new alum fuse:
http://horizon.hobbyshopnow.com/serv...nufacturer=ALL
Just noticed they're out of stock. Must be another online place to get parts...
eBird is offline Find More Posts by eBird
Old Jan 19, 2003, 05:39 PM
mrebman is offline
Joined Nov 2000
Ebird:
No I didn't trash it, just bent it a little to much & then bent it back, didn't bend it enough to break it, I think it will be fine unless I crash it & it bends where the current bend is, then I'm probably screwed.
-Anyway-Thanks! for the Link, I'll remember that when I need it!
-Mike-
Old Jan 19, 2003, 05:43 PM
eBird is offline
eBird's Avatar
Joined Jul 2002
You know what would be nice?
If that little plastic connector included in the kit had 3 down and right thrust.
Then you could cut the fuse near the nose, and reattach using this connector. Viola, instant downthrust and very little mod time.
Old Jan 19, 2003, 05:52 PM
AirWarriorBelgy is offline
Find More Posts by AirWarriorBelgy
Captain Carnage says......
AirWarriorBelgy's Avatar
Seminole (St Pete.), Florida/ Seminole Crash Fest
Joined Jun 2002
Horizon has had the NYA available on the slowstick fuse snce they put it on their website (i've been keeping a daily eye on it ever since i broke mine.
i found the same tubing at an Ikarus dealer online (through ebay)
its the same as used on the Bleriot, Grade Eindecker kits with one exception
it's only 34 inches long insted of 36 ......
i have 3 spare tubes (@34" long)
the quick fix i used when i broke my nose on SS's second flight so long ago was to insert a 5/16" hardwood dowel into the fuse and screw it into place. The extra little play let me set a thrust angle.......
Chuck
AirWarriorBelgy is offline Find More Posts by AirWarriorBelgy
Found a useful repair material for building up foam... diviatix Electric Plane Talk 14 Nov 29, 2005 06:47 PM
Found a 'universal' fix for easyfly/piccofly/aerofly serial port problem abennett Electric Heli Talk 1 Jul 27, 2002 07:34 AM
Fix for stiff logo10 tail slider jaggies Electric Heli Talk 6 Mar 23, 2002 01:23 PM
Is there a fix for chattering servos? ErnieR Electric Plane Talk 5 Mar 06, 2002 06:09 AM
A fix for frequency accidents BillH Electric Plane Talk 4 Nov 21, 2001 08:45 AM
