Old Feb 19, 2012, 10:58 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
I just tried an MKS DS760 and instantly fell in love.
Dr.M is offline Find More Posts by Dr.M
Old Feb 20, 2012, 03:57 AM
mahbouni is offline
Find More Posts by mahbouni
Heli Hooligan
London
Joined Dec 2006
FWIW I've been running two BLS251's @ 6V for about 18 months with no issues
mahbouni is offline Find More Posts by mahbouni
Old Feb 20, 2012, 11:10 AM
Probicha is offline
Find More Posts by Probicha
Joined Jul 2009
DrM, have you tried a BLS 251 to campare with?
Probicha is offline Find More Posts by Probicha
Old Feb 20, 2012, 03:02 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
I haven't tried any BL servos. I have this personal notion that BL servos draw too much power (I may be wrong) and that comparable performance can be achieved with the less Amp-hungry brushed coreless motors.
Also, the specs for the MKS 760 are better than BLS251, and the former can work at 6V.
Old Feb 20, 2012, 06:51 PM
pwkpete is offline
Find More Posts by pwkpete
ElektroRC.com - MSH,LAHeli,YGE
Pewaukee, WI, USA
Joined Mar 2002
As mahbouni mentioned many of us have been using the BLS251s at 6v for a long time. No issues...
Brushed or brushless both can be efficient (or not) - depends on the servo and manufacturer. I have some Savox coreless that are power hogs - need 10A BEC to prevent LV brownouts. The BLS are generally pretty efficient.
pwkpete is offline Find More Posts by pwkpete
Old Feb 20, 2012, 07:06 PM
buzzsaw 46 is offline
Find More Posts by buzzsaw 46
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
Like Pete has said brushless can be very efficient. I have BLS 255's on my 6HV and holding it up by the blade grip arms and slapping the collective up and down as fast as I can, I was drawing less than 4a.
buzzsaw 46 is offline Find More Posts by buzzsaw 46
Old Feb 20, 2012, 09:53 PM
Probicha is offline
Joined Jul 2009
Thanks guys, I'll probably go toward BLS. I'll run it at 5,5V along with my Hitec 5254MG cyclic servos. With the MKS, I would have gone up to 6V
Anyway as mentionned above, I can not go wrong with one or the other.
Any more comments?, I'll do the order tomorrow.
Old Feb 20, 2012, 10:03 PM
nick779 is offline
Find More Posts by nick779
Heli addict -> Quads
United States, PA, Pitts
Joined Feb 2012
im flying with the spektrum h6080G only $79
Product Specifications
Size Category:
Standard
Type:
Digital
Application:
550-700 size heli tail rotor
Torque:
55.5 oz-in (4.0kg-cm) @ 4.8V; 69.4 oz-in (5.0kg-cm) @ 6.0V
Speed:
.06 sec/60 @ 4.8V; .05 sec/60 @ 6.0V
Length:
1.6 in (40mm)
Width:
0.8 in (20mm)
Height:
1.5 in (37mm)
Weight:
2.00 oz (56.4g)
Bushing Or Bearing:
Bearing
Bearing:
Dual
Motor Type:
Coreless
Connector Type:
z-connector
Gear Type:
Metal
Voltage:
4.8V-6.0V
nick779 is offline Find More Posts by nick779
Old Feb 21, 2012, 03:34 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
How is the 6080G? That's a newer servo, I haven't seen many users. What gyro and how's the tail in fast backward flight? What about piro stops?
Old Feb 21, 2012, 03:52 PM
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
Not sure but I have heard the Spektrum servos are rebranded Savox. Specs match the SH-1290MG
Old Feb 22, 2012, 06:59 PM
nick779 is offline
Joined Feb 2012
its on a beastx, and its still too cold, ive only gotten a chance to hover it, but ill update as soon as i get some backwards flight in
Old Mar 24, 2012, 05:36 PM
wbefield is offline
Find More Posts by wbefield
United States, GA, Lilburn
Joined Jun 2011
I've got the 6080G/BeastX and couldn't be happier. holds very solid on backwards flight, and stops dead on in piros. I even crashed it once and it still works perfect.
wbefield is offline Find More Posts by wbefield
Old Jun 05, 2012, 05:26 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
How's it going, gents? Kinda quiet on the Protos forum... I guess all Protii are running smoothly and putting big grins on their respective owners' faces? Mine certainly is
Old Jun 05, 2012, 07:48 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
Can't complain! My (Mini) Protos is my "go to" helicopter. Flew it for a year stock, stretched it this year to 350s and a 6S power system (thanks Pete!). It's a whole new level of awesomeness.
Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Jun 05, 2012, 08:39 PM
Sctholson is offline
Find More Posts by Sctholson
Woodstock, VT
Joined Jan 2007
Normally I'd make some snarky comment like 'well nobody listens if you were to complain' but we all know that isn't true, most of do listen, every show in fact...
Sctholson is offline Find More Posts by Sctholson
Yippee! IFO owners thread #1 jimklein Scratchbuilt Indoor and Micro Models 1861 Jun 05, 2015 07:06 AM
Alert Skyshark owners thread Chris Nicastro Scale Kit/Scratch Built 32 Nov 14, 2012 02:44 AM
36# owners' thread. J-ken Micro Helis 20 May 23, 2008 03:41 PM
Discussion Blade CP Owners Thread PiperLance Micro Helis 3281 Mar 19, 2006 08:01 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
