| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Certified
MSH Protos Owners Thread
We have start this thread for Protos owners to talk about their power setup and also to share their findings, problems, and fixes. People will be running this helicopter on everything from 4s up.
The Protos is a 425mm blade helicopter brought to us by MSH. The guys running MSH brought you Gorilla gear/paddles and other Heliup performance upgrades. The Protos is different in many ways some of which are:
As much as possible stories and conversations should be centered around the Protos. Vendors are welcome to comment and share, but please no blatant advertisement. I reserve the right to update this post with more guidelines for this thread. Please share with me in PM any information I might find useful and anything that you think is wrong concerning this thread. I will do my best. Have fun! J Thanks kgfly, Hoverup, RealRaptors, and Corrado |
#2 |
Certified
A list of power setups (battery, motor, servos, pinion, HS...) in an almost standard format
So you can contact people with setups like yours: HighFreq Stock Motor 15T Pinion 6S 2500 Flightpower 3x9650 Servos Spartan + 9257 on tail MSH prototype ESC Peak at 1264 Watts JGoodwin JR DS3405MG Cyclic Hitec HSG5083mg Tail Hitec HG5000 Gyro Align 60a Hyperion 4a BEC (removed) Stock Motor W/ 15T Pinion 2250 6s lipo Grounded: Tail Boom and Motor Mount to Neg. jdanks Futaba 9650 cyclic Futaba 9257 Tail Futaba GY401 Gyro Hobbywing Pentium 60A ESC Stock Motor W/ 15T Pinion 6S A123 Battery geneween 9650's DS760 / 9254 AR6200 Align 100A ESC Kool Flight 6V BEC Scorpion 1000kv motor Two thunder power 2150's 6S RFT weight :1580g (3.4ish lbs) Kepler Cyclic: Hyperion HP-DS13TCB Programmable Digital Tail: Hyperion HP-DS12GCP Programmable Digital Futaba 401 Gyro Align 60A ESC with built in BEC Z20 980 kv motor 18 tooth pinion Hyperion 3700 mah 4S pack. RFT weight :1495g (3.3lbs) cfrank2005 Scorpion COMMANDER 26v 90A ESC SBEC Scorpion SCHK3026-1000Kv Motor AR7000 Rx Ino-lab HGD-250MG on the swash Futaba GY401 & 9257 combo for the tail Spectrum DX7 Tx Mashem Marv Stock motor 5s tp 3300 batts fut9650 servos for swash 401gyro with 9650 on rudder holds like a rock almost scary 40-6-18 kontronik ultimate bec 5min 2800mh 18th pinion weighs 3.52lb or 1598g kth Cyclic servo: Ino Labs HG-D251MG cyclic Tail servo: Ino Labs HG-D261HB Gyro: Spartan DS760 Speed control: Castle Creations 60 BEC: Dimension engineering SportBEC buzzsaw 46 3x S3155 cyclic KO PROPO PDS-3014 tail servo LGT-2100T gyro Stock motor JR 790 RX SJM 60a ESC 6s FP EVO light 2100's or 6-7s A123's Ted U JR z3650s 9257 tail servo Jazz 55 with CC BEC VBar Stock motor w/ 15T TPX 2600 6S V2s JiriK Align 75A esc (Not happy with turnigy) Castle bec 6S A123 Stock motor HG-D260HB cyclic servos Spartan ds760 + S9257 servo AR6200 rx. laughingstill Protos kit with blades (SAB) and motor (Lipotech) Align 60 amp ESC running @ 6v Ino Labs HG-D251MG HT Metal Gear Digital Cyclic Ino Labs HG-D261HB High Performance Digital Tail Servo GY401 Spektrum Ar 6200 rx 2x FP EVO 3s 2200 (in series for a 6s setup) mahbouni Stock motor + 15T pinion 2 x TPV2 3s 2600mAh (in series) Kontronik Jive 80+ LV Spartan ds760 gyro JR DS3500G tail servo JR DS3405 cyclic McLaren Cyclic: HS-5085MG ESC: Scorpion Commander 60A (no soft start!) Gyro / Tail Servo: D770 / 3500G Battery: 6s FP EVO light 2500 Pinion: 15 tooth Rx: Spectrum 6200 ST2 flat 95% with 2830HS Tail grounded with SS shim stock and wire from tail box to motor mount Clicky Stock Protos Align 60 amp ESC running @ 5v (for now - because of S9257) HS5245MG for cyclic S9257 + GY401 on tail Spektrum Ar 6200 rx 2x any 3s ... in series Wesp Infinity CF frame MKS 9660 on cyclic CSM 720 + Ino Labs HG-D261HB CC60 + CC BEC 7S A123 Ar6100E 2800HS governed on 16T pinion 5:20 flight time 1730g RTF lubed belt Mrktplayer Scorpion 3026 1000kv + 15T Jazz 55 + external BEC JR Z3650 Cyclic @6v Spartan Ds760 Futaba 9257 on tail @5v FP 6S 2500 Mods: K&B Trex500 dampeners 3K tail blades Ground from tail boom to motor mount RCHeliForum Stock Motor 15T Pinion 6S 2500 Flightpower EVO 3 x JR DS3517 Servos JR G7703D Gyro + JR DS3500G on tail Align 60A ESC Speed Stick 3D Plastic Protos (Tail boom grounded) Stock motor/15T pinion MKS 9670A+ cyclic servos JR 3517 Tail servo PG800 Gyro Castle Creations Ice 75 Lite Note: anybody who wants their setup information here should PM me. It will only be added if it is sufficiently different than other setups. If your setup is the same as another user I will just add your name. This is all so people can contact you for help, not so you can show off. -J Last edited by jgoodwin; Sep 07, 2009 at 08:22 AM. |
#3 |
Certified
A list of servos known to fit swash:
Code:
MSH Protos (500-class) Swash Servo Roundup
kgfly, 29 Apr 2009
Mfr Model Ftr W (g) Speed Torque H L W (mm) USD$
Align DS510 DP? 25.9 0.13 3.7 29.2 35 15 45
DS520 DP? 25.9 0.09 1.9 29.2 35 15 45
Futaba S9257 DP2 26 0.08 2.0 28.6 35.5 15 65
S9650 DP2 26 0.14 3.6 28.6 35.5 15 55
S3155 DP2 18 0.15 1.5 29 30 11 29
HiTec HS-81MG AM0 19.6 0.12 2.3 30 30 12 22
HS-82MG AM0 19 0.11 2.6 30 30 12 22
HS-85MG AM1 22.3 0.16 3.0 30 29 13 31
HS-5085MG DM2 21.9 0.17 3.6 30 29 13 47
HS-5245MG DM2 32 0.15 4.4 32 31 17 45
Hyperion DS12ACB DP1 16.9 0.16 2.6 26.0 29.5 12 35
DS13ACB DP1 17.9 0.16 2.6 27.6 29.5 13 45
DS13TCB DP1 17.9 0.20 3.6 27.6 29.5 13 52
DS13TMB DP1 19.2 0.20 3.6 27.6 29.5 13 52
InoLabs HG-D251MG DM1 24.4 0.15 4.8 33.3 31.5 13.0 65
HG-D260HB DP1 16.9 0.12 2.4 31.5 30.0 13.0 51
HG-D260MG DM1 20.6 0.16 3.4 31.5 30.0 13.0 58
JR Z3650 DM2 29.5 0.09 3.0 25.9 33.0 14.7 75
DS3400G DP2 29 0.11 3.7 25.9 33.0 14.7 75
DS3405 DP2 30 0.13 2.8 26.5 33.0 15.0 Ģ50
MKS DS9660 DM2 35 0.12 3.8 28.6 35.5 15 50
DS9670 DM2 28 0.09 2.2 28.6 35.5 15 50
SJM SDG-502MG DM1 21.6 0.16 2.7 31.5 30.0 13.0 40
Notes:
a) Speed & Torque shown is for 4.8V
b) "Ftr" = "Feature" = Digital/Analog (D/A), Plastic/Metal gears (D/P), No. of ball bearings (0/1/2)
so AM0 = Analog, Metal gear, 0 ball bearing and DP2 = Digital, Plastic gears, 2 ball bearings
Opinions
Based on what I have learned, my suggestions for swash servos would be:
Priorities Servo g s kg.cm USD$
weight + performance + price Hyperion DS13ACB 18 0.16 2.6 45
price + performance + weight Align DS510 26 0.13 3.7 45
MG + price + performance MKS 9660 35 0.12 3.8 50
speed + price Align DS520 26 0.09 1.9 45
speed + MG + price MKS 9670 28 0.09 2.2 50
The JR DSxxxx servos are much admired but for me too expensive when there
are so many other good candidates that are significantly cheaper.
#4 |
Certified
A list of main and tail blades known to fit:
Need Info... Data: Tailblade size: 65mm T/R blade span (4mm root thickness) (MSH Gorilla tail blades included in kit) Mainblade size: 415mm-430mm (9.16mm root thickness) (3mm mounting holes) (SAB 425 Carbon Fiber blades included in kit) Last edited by jgoodwin; May 22, 2008 at 04:45 PM. |
#5 |
Certified
Useful Websites:
MSH Plastic Link Tutorial http://www.rcgroups.com/forums/showthread.php?t=869412 MSH MSH Protos 3D e-heli (425mm mains) Build & Review Design Thread: ***** New 500 Size Electric Helicopter by MSH ***** Last edited by jgoodwin; May 25, 2008 at 10:22 AM. |
#6 |
My kit has been shipped from Realraptors. Should be here tomorrow, but ahhh no 16/17T pinions yet. Damn.
#7 |
MSH 500 Protos Original Specifications
kgfly, 19 June 2008 - Main blade: 415mm-430mm (9.16mm root thickness) EDIT: 10mm grips now available - Tail blade: 65mm (4mm root thickness) - Flybar: 2mm x 280mm with Gorilla Gear programmable paddles - Maingear: 93T - Pinion: from 15T to 20T (integrated OWB) 13T and 14T to be added to the range in the future 15T ships as stock in the kits - Main hub: CNC aluminium - Swash: CNC aluminium - Mainshaft: 8mm (originally solid aluminium with a special coating - never sand it! but now steel, solid = cheaper and hollow = more expensive) - Frame: FRP (plastic + 30% carbon = conductive) - Grips: FRP, main with thrust bearings, tail without - Tailbox: FRP - Canopy: Plastic, pre-painted (white also available). FG also available - Boom: 17mm OD aluminum - Main to tail ratio: 4.33 - Stock motor: MSH 800KV, 1100W, 14 poles, 4s-6s, 5mm shaft, body height 48.7mm (50.2mm incl. circlip), max diameter: 37.3mm, weight 185g - Stock blades: SAB 425mm CF (Grip: 9mm, Hole: 3mm, Chord: 40mm) - Stock tail blades: MSH Gorilla Gear 65mm (Grip: 4mm) - Stock LG: MSH Gorilla Gear - Stock paddles: MSH Gorilla Gear programmable paddles Special features - Innovative single belt drive (motor->main gear->tail) - Programmable flybar-to-mainblade ratio - Tail grips with integrated Chinese weights so a mini size tail servo can have the same performance as a full size tail servo - As low as 1520g all-up-weight with a 6s lipo 2500 - As low as 1680g all-up-weight with a 7s A123 2300 - Supports mini sized servos having double or single mounting holes - Designed for LiPo from 4S (~3700mAh) to 6S (~2500mAh) - A123 7S 2300mAh humpback slab pack (2 cells over 5 cells) fits and balances - Gorilla Gear paddles, tail blades and landing gear Setup info Swash servo ball position: 16mm Tail servo ball position: 13.5mm Typical swash servos - Hitech HS81/82/85 - Futaba S9650, S3155 - JR z3650 - Ino lab HG-D251MG, HG-D260HB Last edited by kgfly; Mar 05, 2009 at 09:17 PM. Reason: Update info about 10mm grips and steel mainshafts |
#8 |
Mercedes C63 AMG heli hauler
For incorporation if you wish.
Tailblade size: 65mm T/R blade span (4mm root thickness) (MSH Gorilla tail blades included in kit) Mainblade size: 415mm-430mm (9.16mm root thickness) (3mm mounting holes) (SAB 425 Carbon Fiber blades included in kit) Pinion: from 15T to 20T (integrated OWB) Corrado has promised 13T and 14T as options. Cheers - Boyd
#9 |
It will be good to know the real rotor diameter with the supplied sabīs as a comparison purpose . I have come to my attention how big can a 425 heli be (Logo 400) depend on head span.
#10 | |
![]() Tried to order 15t pinion but they didnīt have any. So Iīll propably take one cell off from my 7S A123 packs so I can test it.. |
#11 |
Certified
I just could not resist. I had to start building mine at lunch at my desk!
J Last edited by jgoodwin; May 21, 2008 at 11:15 AM. Reason: My typing sucks. Or is it my spelling? |
#12 | |
#13 | |
#14 |
That car in the pic has the steering wheel on the wrong side
#15 |
Renewed interest
I am looking forward to participating here. My Protos has landed in country and just waiting on customs clearance.
| Thread Tools | |
| Yippee! IFO owners thread #1 | jimklein | Indoor and Micro Models | 1713 | Today 02:40 PM |
| Alert Skyshark owners thread | Chris Nicastro | Scale Electric Planes | 29 | Sep 19, 2009 04:16 PM |
| 36# owners' thread. | J-ken | Micro Helis | 20 | May 23, 2008 04:41 PM |
| Discussion Blade CP Owners Thread | PiperLance | Micro Helis | 3281 | Mar 19, 2006 09:01 AM |
| Official Parkzone P-51 Owners Thread | monitor | Parkflyers | 913 | Oct 04, 2005 10:02 PM |
