Old Mar 19, 2010, 09:53 PM
moonpock is offline
Find More Posts by moonpock
I don't need no stink'n nitro!
Thompsons Stn, TN
Joined Nov 2008
Originally Posted by Buzzkill2 View Post
I picked up a couple 9x9,10x10 and 12x12 props a while back to try but, my T28s are far from stock. My "go to" T28 is running a 12x8 MA E-only prop.
One is 900w 3S and the other is 1200+w 4S. They still will fly low and slow like a stocker but, open them up and it's all bets off
Really would like to get a PZ P-51 to try and beat the 136mph record but, I have to many other projects I want too.
1200 watts in a <3 pound plane!!!
Now I understand where "Buzzkill" comes from...
How do you like the MA prop? I just balanced two for my Trojan, but I haven't flown them yet... Static tests look good, even if I'm ONLY running 350 watts.
moonpock is offline Find More Posts by moonpock
Old Mar 19, 2010, 10:27 PM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Roscoe
Joined Jul 2008
Originally Posted by G550Ted View Post
F2F,
That's what i like... simple!
Thanx for the reply,
Ted
edit - I should have quoted your post. This was in regards to using poly to coat over colored tape. Sorry for any confusion.
Simple, no confusion, gothcha
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Old Mar 19, 2010, 11:09 PM
Buzzkill2 is offline
Find More Posts by Buzzkill2
Buzzkill2's Avatar
United States, MI, Grand Blanc
Joined Mar 2007
Yup! 1200+ in a T28. It's a rocket and quite a "Buzz" to fly! The "Buzzkill" comes from the inevitable crashes I have from time to time
12x8 MA is a great prop IMO. I like the black and shape on this type of plane better than the APC's and the sound is great in the air. The 12x8 works perfectly fine even with the gear on (if your landings are good) and it really gives unlimited vertical truly "unlimited" if you have a good motor.
My 1200+w setup is a 4S 2200mAh Hyperion VX pack with a Hyperion HS3026-1400Kv. Hyper overkill but, it is so much fun. I got the 9x9 and 10x10 APC props to try and keep the amps below 100a and add some pitch speed.
The other T28 has a Hyperion Zs3020-08 (900w) and I've never seen a faster T28 on a 3S anywhere. Motor Costs less than the stock plastic motor too. More than a Turnigy or Super Tiger but, you just can't compare it to these motors.
If the weather holds I'm going to try them tomorrow or Sunday. After a week of 60 degree weather, wouldn't you know it it's supposed to snow here
EDIT: Hyperion motors are the only motors I have personally used that will take abuse like that and keep going without a hiccup.
Buzzkill2 is offline Find More Posts by Buzzkill2
Old Mar 20, 2010, 01:13 PM
handyflyer is offline
Find More Posts by handyflyer
Round Lake, IL
Joined Oct 2007
Has anyone used this motor with a 40 amp speed controller on this a/c?? I think it is almost the same motor as the Turnigy 35-36 motor from hobbycity.
http://www.valuehobby.com/product_de...29&item_id=150
handyflyer is offline Find More Posts by handyflyer
Old Mar 20, 2010, 01:18 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Check and see if maybe Dr Kiwi has tested it. He has a large database of tested motors, and you may find his test results to be helpful in making a decision.
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Mar 20, 2010, 02:23 PM
moonpock is offline
Thompsons Stn, TN
Joined Nov 2008
That looks very similar to the BP2814-08 that I'm running, only I'm getting 1100kv.
I went with a Suppo type motor because they have the shaft exiting the motor opposite the firewall mount, rather than through it, and I can use a standard prop adapter that fits through the cowling without modification. Just something you might want to think about...
Old Mar 20, 2010, 02:34 PM
moonpock is offline
Thompsons Stn, TN
Joined Nov 2008
I feel you're pain. Around here, we have a saying... "What follows two days of wind and rain?" MONDAY!
Ditto on the Hyperion motors... There's none built better! Good planes, too, from what I've seen.
Old Mar 20, 2010, 04:09 PM
captjoey42 is offline
Find More Posts by captjoey42
We can still hand launch it !!
captjoey42's Avatar
Hampstead, NC
Joined Mar 2009
Spektrum DX6i has 9 marks to the left of the throttle stick.
when the stick is at idle you are on the 2nd mark
When the stick is all the way forward you are on the 8th mark
When I increase throttle slowly My motor accelerates smoothly but obtains WOT at the 7th mark (instead of the 8th one)
From what I have read on other posts there is no way to MIX the throttle to solve this problem.
Does anyone know how to fix it or is it just a live with
CaptJoey
captjoey42 is offline Find More Posts by captjoey42
Old Mar 20, 2010, 04:25 PM
Joined Jul 2006
CaptJoey
Have you tried the throttle trim button yet?
Old Mar 20, 2010, 04:40 PM
captjoey42's Avatar
Hampstead, NC
Joined Mar 2009
it seems to effect the idle much more than WOT
full down trim I can move the stick to the 2nd mark before the prop turns but the WOT position stays about the same.
If i start to add trim with the stick at full idle the prop starts to turn at half way between center trim and full up trim
I usually just keep the trim in the canter
Old Mar 20, 2010, 04:48 PM
Joined Jul 2006
You know.... now that you mention this, I'm not so sure any of my planes have as their WOT, the very last notch on the throttle stick. It seems to me the last few notches (or clicks) don't do anything.
Old Mar 20, 2010, 05:05 PM
captjoey42's Avatar
Hampstead, NC
Joined Mar 2009
Well I am sort of new to this so It may just be a "live with"
Old Mar 20, 2010, 05:12 PM
Joined Jul 2006
Let's put it this way. If my motor reached maximum rpm on the very last notch, I'd be saying to myself.... "Hmmmm, I wonder if it's really maxed out?" Then that would drive me nuts.... lol
I have the DX6, and the DX7, and I really don't think it's a matter of having to 'live with it'. I think it's just the way the throttle controls work on our planes.
I also use Castle Creations ESC's which auto detect the maximum throttle stick position, and all my planes still reach WOT a click or two below the last click.
Chuck
Old Mar 20, 2010, 05:15 PM
Joined Jul 2006
Hmmmm, I just thought of something else. There's a way to take the throttle stick and convert it to a 'click-less' affair like the kind used by Helicopter pilots. This affords them the finer and more precise way of making minute changes to their throttle position...so that just leads me to think that our ratcheted sticks are working properly after all.
Chuck
Old Mar 20, 2010, 06:40 PM
captjoey42's Avatar
Hampstead, NC
Joined Mar 2009
Thanks Chuck !!!
I will learn to like it the way it is and forget about changing it
untill now I have been flying pretty much by just taking off at full power and then pulling it back a bit and just flying around but I am now learning how to manage my power a bit better. That's why it took me until now to figure out how it worked. The T28 is so great though you can be really sloppy with the power and it flys fine (very forgiving).
What a great plane !!!
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
