Old Feb 08, 2010, 07:03 PM
Buzzkill2 is offline
Find More Posts by Buzzkill2
Buzzkill2's Avatar
United States, MI, Grand Blanc
Joined Mar 2007
Originally Posted by Prof100 View Post
You can buy props direct from APC and the prices are in line with many LHS.
I took your advice and ordered six new props to try. I got some 9x9, 10x10 and 12x12 APCe props from Tower. 6 Props for almost 1/2 what my LHS charges for them.
I think the 9x9 will be good for the 4S setup, the 10x10 and 12x12 will go on a lower kv 3S setup I have in another T28.
Should be fun.
Buzzkill2 is offline Find More Posts by Buzzkill2
Old Feb 08, 2010, 07:09 PM
Toppers is offline
Find More Posts by Toppers
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
Originally Posted by nitrofevr View Post
here is my friend tearing up his stock trojan!! He really starts to hate the plane about 4:20 in, even clips a tree.
http://www.youtube.com/watch?v=j4vF4xT-f74
WOW !!
That is incredible flying.... the inverted 30 foot diameter circuits at 7 feet off the ground were a first. Very impressive control and an unbelievable recovery after the wing clip. Nice one
Toppers
Toppers is offline Find More Posts by Toppers
Old Feb 08, 2010, 07:46 PM
tre33 is offline
Find More Posts by tre33
Alberta
Joined Mar 2009
Originally Posted by Toppers View Post
Hi 333,
I don't have direct experience with a 10x5, but if I had to guess, I think it would be like the Corsair 3-blade (9x7), slower but with more thrust. I regularly fly the 3-blade and like the slow speed authority the extra thrust provides. The speed is plenty for my flying.
Give it a whirl and let us know.
Toppers
Thanks for the reply Toppers. I screwed up and drilled the prop out of center a little and wasn't happy as it vibrated alot at 3/4 throttle, so needless to say I never tried it and stuck to the stock prop and did alot of super slow flying just off the ground. It is sooooo stable, I love it. One cool thing today was an eagle that chased my plane and my sons mustang around for a few minutes. Kept us entertained anyway.
tre33 is offline Find More Posts by tre33
Old Feb 08, 2010, 10:59 PM
lamcam is offline
Find More Posts by lamcam
Joined Aug 2005
Blue Lipo 2650mAh?
Hey guys, I've been hearing good things about the blue lipo batteries. I like to try some on my new T28-D. But the only thing they have left in stock now are the Blue Lipo 3-Cell 2650mAh 3S1P 11.1v 25C. Can you guys advise me if the that battery would be ok for my Trojan? Or would that be too much juice, or too heavy. Thanks in advance.
lamcam is offline Find More Posts by lamcam
Old Feb 08, 2010, 11:14 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
It would probably work just fine. I run 2650 and 3000 in mine. You just have to move it back to maintain CG.
Prof100 is online now Find More Posts by Prof100
Old Feb 08, 2010, 11:28 PM
Buzzkill2's Avatar
Joined Mar 2007
It should be fine, the weight difference isn't going to greatly affect the flying characteristics of th T28 provided you adjust to the the current CoG your using.
I've flown my T28s on 2100,2200,2650 and 3000mAh 3S batteries along with 2200 ans 2650mAh 4S batteries. All of them (while slightly different) flew great without an issue. However, I can tell a difference with bigger batteries, after hundreds of flights on a T28 I can tell if there's even a small change in the setup but again, it still flies great.
As far as "too much juice" that depends on your current configuration and the quality of the "Blue LiPo". Some batteries like the Hyperion G3 (CX/VX) will maintain higher voltage curves throughout a flight, even at initial peak loads, so if these particular batteries hold voltage better than your current batteries and your already pushing your ESC/Motor thresholds then they might have "too much juice". I seriously doubt they will be an issue though.
For example: if your current battery produces 25a at 262watts then your cell voltage at that point is around 10.5. If the "Blue LiPo holds 11.1 volts with the same setup then you'll be producing considerably more watts/amps than your current pack and may exceed your ESC/Motor rating. These numbers are just examples (not actual data) to demonstrate the advantage of better batteries but, I think you get the picture.
The only way to know for sure is to use a watt-meter or data logging device that will show you what your actually drawing. I think you'll be ok though, as long as you don't over prop.
Old Feb 09, 2010, 04:52 AM
grizzlymatt is offline
Find More Posts by grizzlymatt
3DHS Addict DownUnder
grizzlymatt's Avatar
Perth, Western Australia
Joined Aug 2004
Ok Guys
Need some advice or links to pages that has this info.
Iam looking at making some mods to the Trojan.
1. Install Retracts - installation ideas , best ones etc.
2. Flaps
3. Landing Lights LED
I know there is a few link on the first page but Iam sure there is a alot more idea and and information on people doing these things so can you guys give me some insight
Cheers
Matt
grizzlymatt is offline Find More Posts by grizzlymatt
Old Feb 09, 2010, 08:45 AM
Toppers is offline
Toppers's Avatar
Joined May 2008
Originally Posted by grizzlymatt View Post
Ok Guys
2. Flaps
Cheers
Matt
Try the search button.... also search on youtube.
Old Feb 09, 2010, 09:51 AM
nitrofevr is offline
Find More Posts by nitrofevr
nitrofevr's Avatar
WOW !!
Toppers
It was actually the vertical stab that got hooked. Here is a pic.
Here in about a week or so we will be shooting more video but we expect it to be the death of this bird so I will post when done
nitrofevr is offline Find More Posts by nitrofevr
Old Feb 09, 2010, 05:56 PM
Joined Aug 2004
I knew I would get that response.
Old Feb 10, 2010, 12:34 AM
Belem is offline
Find More Posts by Belem
Foam flogger
Roseville, CA
Joined Apr 2009
There's a retracts thread for the t28 on the warbird board.
Belem is offline Find More Posts by Belem
Old Feb 10, 2010, 03:02 AM
Joined Aug 2004
Thanks just what Iam looking for
Old Feb 10, 2010, 10:10 AM
IEATSRT is offline
Find More Posts by IEATSRT
Thumbflyer
IEATSRT's Avatar
Manning, AB, Canada
Joined Nov 2009
Ok Guys
2. Flaps
Matt.. here are a few build vids of I did on retracts and flaps for both my T28D and Corsair. If you go to my youtube site: http://www.youtube.com/user/IEATSRT and search through all my vids you will find all 6 videos. I didn't do flaps for the trojan in the vid but the corsair I demonstrated how to build flaps... feel free to ask away or pm me if you have any questions... hope this helps.
http://www.youtube.com/watch?v=wT8_swfU-70
http://www.youtube.com/watch?v=215XTB9Gz2g
Matt
Brandon
IEATSRT is offline Find More Posts by IEATSRT
Old Feb 10, 2010, 05:47 PM
nathan3009 is offline
Find More Posts by nathan3009
Joined Jan 2010
Hi guys would this motor be a good replacement for the stock motor while still using the stock esc and motor mount. If not what would you reccomend. http://www.hobbypartz.com/alpha-480-...ess-motor.html
nathan3009 is offline Find More Posts by nathan3009
Old Feb 10, 2010, 05:50 PM
Irg is online now
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
ok guys, I finally got my T-28 back together after it's last unfortunate meeting with the ground. The one that resulted in a lipo fire which consumed my souped up power system and the better part of a fuselage...
Anyway, here is a vid that I shot from the plane yesterday in Red Hook, Brooklyn. She's back to the stock power system, and flies like a pig with my big old Sony cybershot strapped to the top, but it was a fun day nonetheless.
T-28 Flying over Red Hook, Brooklyn NY (7 min 7 sec)
Irg is online now Find More Posts by Irg
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
