Old Dec 16, 2009, 10:45 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by tlewter View Post
I have a question...the small snap rings on the motor shafts have been nearly impossible for me to remove without damaging them. Is there a tool small enough to use on these thing or do I just need to purchase a bunch of snap rings? I did get some snap ring pliers but were too large for these snap rings.
Tom
I have a set of micro snap ring pliers and you still will bend it to much just getting it out of the groove. Take it off and toss it! Use the collar that came with the Turnigy. Snug it up close and lock it down. File a flat spot for the grub screw if you like. I just replaced a shaft on my Power 32 and it has NO snap ring, only the collar.
robj is offline Find More Posts by robj
Old Dec 16, 2009, 11:01 AM
divemasterphil is offline
Find More Posts by divemasterphil
Soon to be CrashMasterPhil
Rochester MN
Joined Dec 2007
Tower has replacement c-clips rings for under $2 for ten. Hope that helps.
http://www3.towerhobbies.com/cgi-bin...?&I=LXYCE9&P=0
Also, Hobbycity/king now has the right pliers:
http://www.hobbycity.com/hobbycity/s...dProduct=10617
Tom
divemasterphil is offline Find More Posts by divemasterphil
Old Dec 16, 2009, 11:04 AM
jamesppp is offline
Find More Posts by jamesppp
jamesppp's Avatar
Georgia, USA
Originally Posted by captjoey42 View Post
Worked like a charm the first try!!
can't wait to take it for a ride
Thanks for the help
EDIT: Never mind, I got it to work ..Just have to do it gain to tweak the time as it took a few minutes longer than the time I listed in the .txt file
jamesppp is offline Find More Posts by jamesppp
Old Dec 16, 2009, 01:49 PM
captjoey42 is offline
Find More Posts by captjoey42
We can still hand launch it !!
captjoey42's Avatar
Hampstead, NC
Joined Mar 2009
Key Chain Camera
Seems I am not the only one trying to figure this out so I thought I would post my research. Sorry for the long post. I hope someone finds it useful to have it all in one place
-The back left buttons are dummies just ignore them
-I will refer to the other 2 buttons as back and front buttons
-The back button is PWR and the front one is REC video or Take Photo
-Battery is rechargeable and from any USB port
-The light blinks when charging
-The light comes on steady when it is charged
-If Batt is dead the only way to know is that it will not turn on
-If batt dies during recording it saves the video to file and then turns it self off
-if mem card becomes full it does the same thing
Video
-Press and hold back button until Light comes on Steady (this turns power on)
-Press and hold front button until light flashes and then goes out (Starts recording)
-Press and release front button to stop recording (light will come on steady when recording is stopped)
-instead of holding down the front button press and release it
-hold camera steady until the light goes out and then comes back on
to turn off camera press and hold the back button until light goes out
-it will turn off by itself if no photo or video is taken for about 20 - 30 sec
to view files just plug into USB and treat like any USB drive (cut and past ect...)
I did a little test and it seems a full charge will record for about 1 hr provided you have enough memory
to set date
-Create a .txt file, named TAG.TXT ( you can use notepad in windows)
-Put the correct date and time into the file according below format. i.e.
[date]
2009/12/25
15:20:00
-Save the file, and copy it into micro SD card into the root directory (ie same area as the DCIM folder).
-Unplug camera from USB port
-Turn camera off and back on (use back button)
the date and time should be set up successfully now
shoot and view a test video of a clock to check it out
captjoey42 is offline Find More Posts by captjoey42
Old Dec 16, 2009, 02:47 PM
DaveG99 is offline
Find More Posts by DaveG99
DaveG99's Avatar
United States, TX, Forney
Joined Nov 2009
Got off work early today and got a couple flights in. All I can say is I love my T28. Im actually going to get back out there for two more flights later on.
DaveG99 is offline Find More Posts by DaveG99
Old Dec 16, 2009, 04:12 PM
tlewter is offline
Find More Posts by tlewter
I have to land it??$#%@!!
Mc Calla, Alabama
Joined Aug 2009
Thans guys on snap ring info
Robj and Divemaster thanks for the info on those snap rings. I really like the idea of using the collar and forgetting the darn things but I also like the idea of the snap ring pliers for $2 that will work and the 10 clips for a couple of bucks! Can't go wrong with either of them.
Thanks again,
Tom
tlewter is offline Find More Posts by tlewter
Old Dec 16, 2009, 05:51 PM
Lovin'It is offline
Find More Posts by Lovin'It
Joined Nov 2009
900w T-28
These guys are testing lipos and are using a T-28 as a 3s test bed.
The plane is putting out between 600w and 900w-
http://www.rcgroups.com/forums/showthread.php?t=1159731
Lovin'It is offline Find More Posts by Lovin'It
Old Dec 16, 2009, 06:14 PM
Lovin'It is offline
Joined Nov 2009
Those 10mm-50mm snap-ring pliers are too big for them 5mm c-clips shown in the tower link.
Effective range:
External: 10~50mm
Internal: 10~50mm
Todd
Old Dec 16, 2009, 08:03 PM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
I'm still waiting for my key chain cam to arrive and just wondered why does everyone want to put the time on it?
i just want mine to film stuff, i don't really care about dating it, as when i download it to the computer, the file will have a date anyway
cheers chuck
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Dec 16, 2009, 08:07 PM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Roscoe
Joined Jul 2008
cheers chuck
I think the date stamp is onscreen and its wrong by a few years. When you watch the video it would lead you to believe its old
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Old Dec 16, 2009, 08:16 PM
Rochester MN
Joined Dec 2007
It's time we make and market a tool, Yeah
Effective range:
External: 10~50mm
Internal: 10~50mm
Todd
Old Dec 16, 2009, 08:26 PM
Lovin'It is offline
Joined Nov 2009
Absolutely! I'm sick of screwing around with a hobby knife trying to get them clips off, so I can push the shaft thru.
Todd
Old Dec 17, 2009, 03:19 AM
tlewter is offline
Mc Calla, Alabama
Joined Aug 2009
Clips and Stuff
Todd
The clips was one issue...the second was it made me really nervous to stick the motor in the vice and drive it through. The press fit was much greater than I expected. I was sure I was going to ruin the brand new motor...but really the toughest part of all, as you noted was getting that flippin clip off! However, everything worked out okay and I have been impressed with the 3536C motor. Again, as noted by others, the stock motor doesn't even compare at twice the cost.
Tom
Old Dec 17, 2009, 09:29 AM
robj is offline
robj's Avatar
Joined Nov 2008
Basically what I did, took the smallest snap ring pliers, did a little grinding on the inside to allow them to get closer together. They work but 9 times out of 10 you will stretch the ring and its wasted. you can get a pair or long nose and sort of squeeze it back together. But the collar will be the catch all. I've never lost a prop and motor out of the front!
Rob
Old Dec 17, 2009, 09:37 AM
Rochester MN
Joined Dec 2007
We had that problem also. We had much better luck just tapping it through with a small brass hammer.
Tom
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
