Old Dec 09, 2009, 09:25 PM
maxwolfie is offline
Find More Posts by maxwolfie
Joined Oct 2009
Small problem
Had a nose over yesterday. The prop adaptor (I think.... Small metal piece on the end of the prop shaft) is a little loose.. It will loose grip at anything about 1/2 throttle. There seems to be a grub screw in the side of it, but it's covered in pink/purple coloured glue.
What's the best way to proceed?
maxwolfie is offline Find More Posts by maxwolfie
Old Dec 09, 2009, 09:26 PM
DaveG99 is offline
Find More Posts by DaveG99
DaveG99's Avatar
United States, TX, Forney
Joined Nov 2009
Originally Posted by LouBoxer View Post
I am thinking of getting this charger will this adapter will work with it and allow me to charge 2 batteries at once????
http://www.hobbycity.com/hobbycity/s...idProduct=7028
http://www.hobbycity.com/hobbycity/s...idProduct=6569
Can we use a Rhino 2350mAh 3S1P 25C Lipoly Pack or is that a no no??
Ive been researching and found this charger to be the best deal. And it comes with all your connections and power cord.
http://www.hobbypartz.com/thac6smbachw.html
And the batteries are cheap at hobby king but shipping takes forever! I searching for at least one battery to get my plane flying. One local hobby shop I called wanted $47 for a 2100mah 3s 25c lipo! I was like no thanks!
DaveG99 is offline Find More Posts by DaveG99
Old Dec 09, 2009, 09:30 PM
Toppers is offline
Find More Posts by Toppers
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
Originally Posted by Tom Eutsler View Post
Thanks for the picts very interesting Video looked good that ya had posted
I spect the velcro is on the Horizonal more or less permanently ? What name does the little camera go by ? Much Obliged te.....
The camera doesn't effect handling or performance at all, so the velcro will be staying on, the camera switches planes.
I got it from this guy... highly recommended. Here you go.... http://cgi.ebay.com/Spy-Camera-Key-C...item25575f88a4
Toppers is offline Find More Posts by Toppers
Old Dec 09, 2009, 10:10 PM
Rockin G is offline
Find More Posts by Rockin G
If It Aint Broke,I'll Break It
Rockin G's Avatar
United States, TX, Lockhart
Joined Dec 2008
Originally Posted by maxwolfie View Post
Small problem
Can you post a close up pic?
Rockin G is offline Find More Posts by Rockin G
Old Dec 09, 2009, 10:44 PM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Roscoe
Joined Jul 2008
Small problem
loosen the grub screw, pull the adapter off and look for the flat spot on the shaft (if there is one). Re install the adapter and tighten the grub screw up on the flat and get it as tight as you can with a quality wrench. Dont wreck the screw if at all possible. If that doesnt fix the problem you will have to file a flat on the shaft yourself to get it to hold. Youll get it.
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Old Dec 09, 2009, 11:05 PM
Joined Oct 2009
Cheers - I don't how how to actually get the grub screw out though, it's covered in pink/purple epoxy-looking glue (only a small amount, but enough to not be able to see the grub screw at all.)
Should I get the glue off first (with something? Nail polish remover?) - Or just try to get the screw out (which size?)
Old Dec 09, 2009, 11:11 PM
FLY ANGRY
FIXXIN2FLY's Avatar
Joined Jul 2008
Can you get the allen wrench in there securely. you can heat it up with the soldering iron to loosen it
Old Dec 09, 2009, 11:25 PM
LouBoxer is offline
Find More Posts by LouBoxer
Northernly Inverted
LouBoxer's Avatar
MN USA
Joined Nov 2009
Dave thanks for looking into this.
LouBoxer is offline Find More Posts by LouBoxer
Old Dec 10, 2009, 12:05 AM
DaveG99 is offline
DaveG99's Avatar
Joined Nov 2009
lou that one will work. Id buy at least 2. I think Im going to place an order also.
Old Dec 10, 2009, 12:11 AM
LouBoxer is offline
Northernly Inverted
LouBoxer's Avatar
MN USA
Joined Nov 2009
Thanks Dave
How about the charger why is it alot better for the $ ( I am trying to educated so I can justify the extra spendature but am on a tight budget as well so a $35 charger sounds better)
Also will that battery have the proper connectors as the photo doesnt show??
Old Dec 10, 2009, 12:26 AM
DaveG99 is offline
DaveG99's Avatar
Joined Nov 2009
Thanks Dave
Im not sure. I know the thunder ac6 comes with a bunch of connectors and the power cord. I just needed the charger here by the weekend so I didnt want to wait for hobby king. They take forever to ship.
Old Dec 10, 2009, 12:27 AM
Joined Oct 2009
Cheers mate - Got it all apart. It appears that the out motor casing has a small crack in the front area, between the two grub screws. After pulling it all apart (except the rear spacer that holds it all together - I couldn't get this grub screw out - too tight!), and putting it back together, it seems as though I've eliminated the issue (for now at least)
Old Dec 10, 2009, 12:36 AM
FLY ANGRY
FIXXIN2FLY's Avatar
Joined Jul 2008
Good, great to hear it. Yea those motor casings suck. They all crack sooner or later. Thats why I upgraded to the Turnigy 3536c 1100
Old Dec 10, 2009, 08:30 AM
G4ORCE is offline
Find More Posts by G4ORCE
Joined May 2009
Jr Spektrum is positive expo
Futaba is negative expo
Thank you all for your input. I was interested to know what you have as the stock "roll" seemed to be boring and wasn't spinning like a muther like I would have liked it to do. Maybe its not supposed to do that on stock or even this type of plane altogether.....somehting for aerobatics and extra's
I will play around with the control arms and horns and see what I can do as the rates are on 100% already !
Thx anyway
G4ORCE is offline Find More Posts by G4ORCE
Old Dec 10, 2009, 08:36 AM
G4ORCE is offline
Joined May 2009
On another note....
What is the maximum C rating I can have for a stock T-28D (30A ESC) ?
I'm currently using 20C and wanted to know if I can use this instead:
Turnigy 2200mAh 3S 30C 40C burst Lipo Pack lipo battery
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 889 Nov 08, 2015 04:45 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 05:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 06:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 02:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 03:48 PM
