Old May 24, 2008, 06:01 AM
LannyG is offline
Find More Posts by LannyG
LannyG's Avatar
Angels Camp, California
Joined Jan 2006
LG repair
Originally Posted by Zero3803
Went out and flew the T-28 today. She flew great, but when I brought it in for a landing the right gear caught a hole in the ground and popped off. No damage to the plane thankfully as the landing was real smooth and slow. I've noticed a couple others have had this happen and was wondering whats the best way to fix this? I assumed 5 min. epoxy and just pop it back in, but I wanted to make sure it wouldn't tear a portion of the wing out if I happen to land in a rough patch later on down the road. Thanks in advance.
I think GOOP works the best. Mine is RV Goop.
LannyG
LannyG is offline Find More Posts by LannyG
Old May 24, 2008, 07:56 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
www.nesail.com/detail.php?productID=5587
they are advertising trojan rtf $209.00
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old May 24, 2008, 02:27 PM
mehrdotcom is offline
Find More Posts by mehrdotcom
United States, TX, Austin
Joined Oct 2007
Buy it from HobbyZone for $197.99 with free shipping using the coupon code: MNB
mehrdotcom is offline Find More Posts by mehrdotcom
Old May 24, 2008, 04:36 PM
Roon is offline
Find More Posts by Roon
Need More "Roon" 4 planes
Roon's Avatar
United States, TX, Sadler
Joined Dec 2007
strut covers
Well since it's so windy I was able to finish my strut covers today;
Edit for the link at the start of the T-28 Part II thread - These strut covers are Robart #106 mini strut covers. About $10.99 at my LHS. I cut about 1/4 inch off the rear covers to fit and a little more than that off the front cover.
If anyone has any questions feel free to PM me. It was simple, just do it!!!
Roon is offline Find More Posts by Roon
Old May 24, 2008, 04:38 PM
Hellsiege is offline
Find More Posts by Hellsiege
Staying Frosty
Hellsiege's Avatar
United States, CO, Colorado Springs
Joined Feb 2008
New owner here. Got PnP version and plan on runing it stock. I didn't see anything under servos. I have a PZ - Stryker that I hated the servos in and replaced asap how do the T-28's stock servos work/hold up?
Steve
Hellsiege is offline Find More Posts by Hellsiege
Latest blog entry: Construction Projects - Updated
Old May 24, 2008, 04:51 PM
Roon is offline
Roon's Avatar
Joined Dec 2007
Steve
Welcome to the club. Look at "glitches", that probably covers the servo issues. If you're going to be using the stock radio setup it's highly recommended to at least upgrade to a castle creation berg receiver.
A Park BEC is recommended for helping to not overload/burn up the ESC. There is a link on the first post for that as well.
Old May 24, 2008, 05:10 PM
Staying Frosty
Hellsiege's Avatar
Joined Feb 2008
Thanks will do that. Runing dx6i with ar6100 for receiver/radio. I'm ordering two hs55 servos + park bec so I can add some flaps... Definately looking forward to seeing how this thing handles though. Need something slower have the stryker for fast so looking forward to something a little slower.
Old May 24, 2008, 05:39 PM
David22 is offline
Joined Apr 2008
i thought prices were going up!?!?
roon any reason why you did not sand down your plane before painting?
Old May 24, 2008, 06:08 PM
Roon is offline
Roon's Avatar
Joined Dec 2007
From posts I read just felt it wasn't necessary. I'm not looking for perfect up close, just a different look (especially while flying). You can see "flaws" in the pics but how often will I be looking that close at the plane? Not much.
Old May 24, 2008, 08:29 PM
David22 is offline
Joined Apr 2008
no looks great i am just new at this thought every little bit helps with air flow while flying
Old May 24, 2008, 08:37 PM
David22 is offline
Joined Apr 2008
speaking about air flow
i just installed two cut off straws to help ventilate the esc in particular
going to wait for the wind to die down and try to vid.
Old May 24, 2008, 08:46 PM
toolguy420 is offline
Find More Posts by toolguy420
Ridin' the Spiral
toolguy420's Avatar
USA, ME, Holden
Joined May 2007
Thrust angle correct?
Well, I did it...finally got a T-28. Is the thrust angle supposed to look like this? Should the motor mounting surface be parallel with the front of the fuselage? I hope so on both counts...
toolguy420 is offline Find More Posts by toolguy420
Old May 24, 2008, 09:38 PM
Roon is offline
Roon's Avatar
Joined Dec 2007
That's the way it should be. Offset counters the motors torque while spinning.
Old May 24, 2008, 09:40 PM
Big Fran is offline
Find More Posts by Big Fran
I need a bigger Hanger!
Big Fran's Avatar
Philadelphia, PA
It's supposed to be that way. Down and to the right.
Big Fran
Big Fran is offline Find More Posts by Big Fran
Old May 24, 2008, 09:51 PM
Staying Frosty
Hellsiege's Avatar
Joined Feb 2008
Need some info, btw is there a main thread somewhere I should be asking noob questions in? I didn't see part 1 and don't want to be cloggin up the summary thread..Anyway my problem
Have the PnP version and putting receiver in... I have a servo plug coming from the nose and I can see the servo with rod to rear and front for gear and rudder... What is this servo under the motor and do I need to y harness that to what looks like the rudder servo and plug into rud channel? Using ar6100 w/dx6i for radio... Manual keeps refering to included y harness but I've yet to see these anywhere...good thing I have a few laying around but not sure how to configure these... I know the ailerons need the Y but not sure on this rudder config.. Thank You.
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
