you can try it and see but they come with that 3s 2200 so im betting you will have short fly times with those batteries.batt may get hot too.not sure
Latest blog entry: Lil repair work.
Bill |
Latest blog entry: Well...
Ok here is something I've been looking closer at on my T-28s. The weak wing connection. You might have noticed that the wing does not fit snuggly to the fuse. Mine(all 4) do seem to vary greatly, one almost 1/4", the best one, just under 1/8". What I did was to wet the area a bit, then at the largest gap, squeeze in some white gorilla glue and let it expand. The water helps it to expand more. The wing is a lot more secure yet easy to cut through than epoxy or CA. The gorilla glue cuts nicely like foam. I don't glue the whole crack to give it some breakway if needed.
Rob |
Here is another neat little thing I picked up in the LHS. I tend to take off pretty steep when flying on concrete because my place has curbs. And the little wing tip protectors...because we've ALL tipped our T-28 on a wing tip turning to fast. BTW and I know the wing tips are on backwards....
since the scraping occurs close to the front tip, I reversed them.Rob |
Fort Wayne, Indiana
Joined Aug 2008
Hey Rob,
I did the same thing except for on the wings I just put some packing tape on the edges so as to not add very much weight. I just epoxied my wings together because I totally forgot about using gorilla glue. The reason I had to glue mine (again) was becaues on a landing I was coming in hot and had trees to my back so I tried to catch it... BAD IDEA!! I caought the wing... but the fuselage just kept on going!!!
Rob |
ill try and get some pics up soon i also put a strip on the side opposite of where the pegs go into the fuse, the vert piece by the screw area. this made the wing a lot more sturdy. |
| Thread Tools | |
| Article ParkZone T-28 Trojan RTF Review | Jim Walker | Electric Warbirds | 776 | May 12, 2013 02:01 PM |
| Official Parkzone P-51 Owners Thread - Part 2 | monitor | Parkflyers | 2601 | Oct 15, 2012 05:41 PM |
| Discussion Parkzone T-28 Trojan Thread | Edge767 | Parkflyers | 6527 | Jun 04, 2008 05:29 AM |
| Sold Parkzone T-28 Trojan, 480 960kv Motors (2) | Joe in Dublin | Aircraft - Electric - Power Systems (FS/W) | 4 | Jan 17, 2008 01:34 PM |
| Wanted Parkzone T-28 Trojan | webejpn01 | Aircraft - Electric - Airplanes (FS/W) | 4 | Oct 25, 2007 02:48 PM |
