Old Jan 21, 2009, 08:34 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Originally Posted by parkpilot101
How much u want and where do u live?
I would need a couple of weeks to do it and if your serious about it, PM me.
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Jan 21, 2009, 08:36 PM
mohawkboy4 is offline
Find More Posts by mohawkboy4
flyin high
mohawkboy4's Avatar
Fort wayen IN
Joined Oct 2008
Originally Posted by flyboy321
on the Supercub thread were pushing 1,000!!!!!! Oh yeah you guys, the longest time I've ever gotten was when me and my friend kept doing touch and goes and landings. Our battery lasted about 1/2 an hour and we didn't even hit LVC!!
who did that with you
mohawkboy4 is offline Find More Posts by mohawkboy4
Old Jan 21, 2009, 08:38 PM
ugly john is offline
Find More Posts by ugly john
Baa baa baa *thump!*
ugly john's Avatar
USA, FL, Green Cove Springs
Joined Jul 2008
Originally Posted by kmart
flying the SC with big lipos, i get it up, then lay down- you are keeping your head normal, but still can look up.
You obviously don't have fire ants up your way.
ugly john is offline Find More Posts by ugly john
Old Jan 21, 2009, 08:42 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
ugg, i hate that word
there in texas, and we have family there. so annoying. i dont know how you do it. nope, no fire ants, but mountain lions, black bears, bobcats, and way too many deer.....
i would never live somewhere where there are fire ants.... they are viscious!!!
lol
Kmart is offline Find More Posts by Kmart
Old Jan 21, 2009, 08:44 PM
flyin high
mohawkboy4's Avatar
Fort wayen IN
Joined Oct 2008
lol
do you ever see the black bears there.
Old Jan 21, 2009, 09:26 PM
kgh31386 is offline
Find More Posts by kgh31386
Joined Apr 2008
sadly had my first 2 crashes today
Both of them were STUPID haha. I flew in 15mph winds and landed FINE all 10 times. Today NO wind at all, and I'm flying low to the ground turning left, and for some dumb reason I let the left wing clip the grass and it cartwheeled like 3 times and as it settled the butt smacked the ground. Chunk is now missing off the very bottom of the rudder. Next crash again my fault, I landed smoothly...and drifted towards the curb, the wing clipped it and turned immediately to the curb. The little fork that connects the servo wire to the aileron broke. So I took the one off my cub and screwed it onto the Trojan. Is it bad if the servo gets hit like that? Before that though, 10 smooth landings again.
kgh31386 is offline Find More Posts by kgh31386
Old Jan 21, 2009, 09:30 PM
flyboy321 is offline
Find More Posts by flyboy321
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
I was joking, but I don't know about park pilot.
flyboy321 is offline Find More Posts by flyboy321
Old Jan 21, 2009, 09:37 PM
Zerts is offline
Find More Posts by Zerts
John,not Zerts.JOHN, NOT Zerts
USA, AZ, Chandler
Joined Nov 2007
I am setting up the power system in a "parts-built" Trojan, and noticed a large amount of vibration with the motor throttled fairly high. The motor mount has a little bit of "give" where it is fastened the to the front of the fuse, obviously the flexibility of foam.
Is this normal? The prop was balanced, etc.
Zerts is offline Find More Posts by Zerts
Old Jan 21, 2009, 09:42 PM
kgh31386 is offline
Joined Apr 2008
how bad is it to run the lipo to LVC? I was letting my plane run down at like 1/4 throttle and forgot about it for about 10 minutes. When I went to check on it, it was just sitting there. not even enough juice to spin the prop, servos still moved though...is that really really bad for the lipo?
Old Jan 21, 2009, 09:45 PM
Hellsiege is offline
Find More Posts by Hellsiege
Staying Frosty
Hellsiege's Avatar
United States, CO, Colorado Springs
Joined Feb 2008
Check the motor mount sounds just like when you have cracks in that mount. Replace it or use CA to fix the hairline cracks, there usually on the 90's..hope this helps.
Hellsiege is offline Find More Posts by Hellsiege
Latest blog entry: Construction Projects - Updated
Old Jan 21, 2009, 09:51 PM
Staying Frosty
Hellsiege's Avatar
Joined Feb 2008
You'll get what you put into a lipo when it comes to taking care of it...
Why would you let it run down? What voltage is it now? Any "puffyness"?
Old Jan 21, 2009, 09:53 PM
kgh31386 is offline
Joined Apr 2008
I didn't know if the charger would recognize it was still half charged, so I thought I'd better be safe and run it lower so I could avoid overcharging it. I dunno the voltage, but it was just sitting there....prop not spinning but the throttle was at 1/4. Should I try to charge it up again now? It's not warm or puffing or anything
Old Jan 21, 2009, 10:03 PM
Zerts is offline
USA, AZ, Chandler
Joined Nov 2007
It's a brand new setup. I was bench testing it. I just switched to a larger diameter, less pitch prop and the vibration went down a lot. It still is kind of excessive, but a lot less. Maybe the motor was running too high RPM's with the smaller prop. Maybe it will be flyable now. (I will do the first few flights w/o cowl and keep an eye on the mount)
Old Jan 21, 2009, 10:27 PM
Staying Frosty
Hellsiege's Avatar
Joined Feb 2008
If your using stock charger it will prob error when you plug it in if you got the cells below 3v per cell. I mentioned above doing this with a lipo receiver pack and it's toast now... You want to make sure when you drain your packs they don't go below 10v for a 3 cell pack... I recommend 11v for your stop point but the choice is yours.
Old Jan 21, 2009, 10:29 PM
Staying Frosty
Hellsiege's Avatar
Joined Feb 2008
Stock motor? What size prop before and then now?
Hows the motor shaft spin w/no prop on it? Aftermarket spinner not balanced properly? Just tossing out ideas really suprised when you said it wasn't the mount....
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 889 Nov 08, 2015 04:45 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 05:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 06:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 02:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 03:48 PM
