Old Sep 06, 2008, 07:40 PM
Fly Or Die is offline
Find More Posts by Fly Or Die
Foam flies better
Fly Or Die's Avatar
From Canadia and proud of it!
Joined Jan 2006
So 9x9 wont be better than 10x7? Also, what was the stock speed? I think I read 60mph?
Fly Or Die is offline Find More Posts by Fly Or Die
Old Sep 06, 2008, 08:15 PM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Hi guys. I haven't posted over here in quite a while but just noticed about 75% of the Super Cub thread part 3 members are here too..lol Anyway I'm wanting to gain a little speed but not wanting to replace the motor / esc yet and I see a 10x7 is suggested but is it enough to notice?
raz is offline Find More Posts by raz
Old Sep 06, 2008, 08:42 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
The 10x7E was plenty for me.. I dunno how fast it was.. I wasn't going for speed.. The best thing to do would be To buy both props and try them.. I usually go through 3 or 4 props on a plane until I find the one *I* like..
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Sep 06, 2008, 11:06 PM
VF84Sluggo is offline
Find More Posts by VF84Sluggo
Wood flight decks, guns only!
VF84Sluggo's Avatar
Gulf Breeze, FL
Joined Nov 2007
Originally Posted by Tram
It will go vertical like a moonshot on the E10 with an 11x7E.. It's also plenty quick on that prop too..
Jeff
www.CommonSenseRC.com
I second this.
With a Power 10 and 40A Pro ESC, I've tried the stock prop, 9x9, 10x10, 10x6, 10x8, 11x7, 12x6...in my experience the 11x7 gives the best combination of speed and vertical (and fun). With this blunt-nosed plane, I found that the "speed" pitches were faster than stock but not much different from each other, just pulled more amps, hotter batteries and less flight time.
The hands-down biggest performance improver in speed and vertical was removing the landing gear (imagine that!) I wish I'd done this sooner. Whole new bird.
Again, this is my experience...your mileage may vary.
VF84Sluggo is offline Find More Posts by VF84Sluggo
Old Sep 06, 2008, 11:14 PM
VF84Sluggo's Avatar
Gulf Breeze, FL
Joined Nov 2007
Originally Posted by David22
Main thing is simplicity, for some extra money. If a motor fits on and can be replaced without hastle...
That's precisely why I chose an eFlite Power 10. From other posts it sounds like there are probably better motors in this class, but this motor is an exact remove-and-replace with the stock motor/mount. The motor length is just right, so there are no concerns with cowling/prop fit. I didn't want to have to do any mount modding, adding spacers, etc...just plunk down more $$$ for more power and go fly.
I like to mod, but not remanufacture.
Old Sep 07, 2008, 12:00 AM
cvoyles is offline
Find More Posts by cvoyles
BANDITRCN28
cvoyles's Avatar
USA, NC, Salisbury
Good news!!!! My T-28 will be back in the air tomorrow morning with a new Scorpion motor installed under the hood and a 45 amp ESC backing it up!!!
Man I can't wait, I think it should be alot faster than the stock motor was...
Safe Landings...CVOYLES
cvoyles is offline Find More Posts by cvoyles
Old Sep 07, 2008, 12:54 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Nice
just out of curiosity does your motor calculator tell your the same thingÉ
have you found 11x7 spins just too fast that you get poor air mix , low thrust.
mine is heavy so i need some tourque 12x6
11X7 or 11x8.5 just does not give me the thrust but less amps maybe 20% less
you like to experiment right, try the slow fly 11X7 (very different prop.)with power 10
that combo is super sized
don`t mention landing gear being better than gear on, it will create a big arguement lol
let us know
Originally Posted by VF84Sluggo
I second this.
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Sep 07, 2008, 01:53 AM
VietVet is offline
Find More Posts by VietVet
Garden Grove, CA.
Joined Feb 2007
T-28's on the scrap pile.. ( Just Kidding )
Posted some pictures on the F4U Corsair by ParkZone site...
http://www.rcgroups.com/forums/attac...mentid=2051697
I really like the Corsair.. But if you are recommending a trainer - the T-28 still rules..
Cheers VietVet -
VietVet is offline Find More Posts by VietVet
Old Sep 07, 2008, 05:29 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
This is just me, but I'd be careful running an SF prop on the Power 10.. At WOT the Power 10 is gonna be close to 450w, which IMO is a bit much for the SF prop.. Prop blade to the eye would ruin someones day..
Old Sep 07, 2008, 10:04 AM
Alan Carter is offline
Find More Posts by Alan Carter
"One more time around"
Tucson, Az
Joined Mar 2007
I went to use my second 3 bladed prop from Parkzone this morning. Let's just say I won't be buying those props again. They look good but that is about it. They are extremely weak. I was about 200 feet up, doing snap rolls and tight loops when one of the blades broke off,hit my canopy and knocked it off. I'm gonna go back to the ol' faithful 2 bladed prop for now. I also got to get a new pilot as for the old one had to "punch out"! Still managed to "dead stick her in without a scatch except the one the prop left.
Alan Carter is offline Find More Posts by Alan Carter
Old Sep 07, 2008, 01:14 PM
David22 is offline
Joined Apr 2008
That is very true! But give it a try and don't go crazy with the power, you won't need to, that is my point try it out just for fun. It will fly completely different than the ones you tried so far. Be carefull Tram is right about it not suited for power 10. but power 10 is not suited for the Trojan anyways.
Don't you just hate the guys in suits who make up the recommended factory configurations. just jokeing
apc e are the recommended props..
the size you use depends on what you like.
Old Sep 07, 2008, 01:18 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
APC SF props are good for 65000/prop diameter..
A 9" prop is good for 5,xxxRPM...
Use something that has a better chance of staying together at the hub..
Old Sep 07, 2008, 07:59 PM
mdine1us is offline
Find More Posts by mdine1us
I want to believe
mdine1us's Avatar
United States, CA, San Diego
Joined Jan 2002
hey Trojan pilots, I just finished mine up and was wondering, what are you guys using as the CG? Common sense tells me to use the spar or just in front of it as a start, but wanted to check with you guys first. Lemme know so that I can go
Maiden her tonight!
TIA
Marty
mdine1us is offline Find More Posts by mdine1us
Old Sep 07, 2008, 08:09 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Marty
I used the recommended CG on the manual.. This can be found at Horizon's site if you have lost your manual..
Jeff
Old Sep 07, 2008, 08:49 PM
mdine1us is offline
I want to believe
mdine1us's Avatar
Joined Jan 2002
thanks Jeff, I reviewed the manual twice and missed it somehow! And didn't even think about going to Horizons site, thinking all I would find would be a PDF of what I already had! Okay, back to the manual and apparently remedial reading class! LOL!
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
