I have not tested it yet but i know that krylon has the h2o series of spray paints that are foam safe...
Might be worth looking into. I don't know how they compare the the fusion series though. (i suggest it because both black and white are available, you can read more about it here ) |
North vancouver, B.C. Canada
Joined Apr 2008
wow the first post really says it all |
Ok guys, i received my Castle Creations Berg ms4l today and i am attempting to install it. I am using the stock transmitter with this BERG receiver and i am having a little issue. Here is how i have everything hooked up.
Ch1 Throttle Ch2 Ailerons Ch3 Elevator Ch4 Rudder When i turn everything on it all seems fine but i am only getting inputs for throttle and elevator and nothing else. I have tried switching the rudder and aileron plugs with each other and i am still not getting rudder or ailerons movement. I have also tried moving all the plugs around and i noticed that Ch1 and Ch3 work with any control surface plugged into it but ch2 and ch4 don't work no matter what is in it. I have found that Ch1 is for throttle and Ch3 is for elevator though. What could be the problem? Does anyones know how to set up a BERG receiver with the stock transmitter? I am also using the stock TX crystal with a BERG crystal in the RX, they are both on the same channel but could this be the issue? Could my receiver be defective? JW |
| Thread Tools | |
| Article ParkZone T-28 Trojan RTF Review | Jim Walker | Electric Warbirds | 776 | May 12, 2013 02:01 PM |
| Official Parkzone P-51 Owners Thread - Part 2 | monitor | Parkflyers | 2601 | Oct 15, 2012 05:41 PM |
| Discussion Parkzone T-28 Trojan Thread | Edge767 | Parkflyers | 6527 | Jun 04, 2008 05:29 AM |
| Sold Parkzone T-28 Trojan, 480 960kv Motors (2) | Joe in Dublin | Aircraft - Electric - Power Systems (FS/W) | 4 | Jan 17, 2008 01:34 PM |
| Wanted Parkzone T-28 Trojan | webejpn01 | Aircraft - Electric - Airplanes (FS/W) | 4 | Oct 25, 2007 02:48 PM |
