Old May 11, 2013, 11:03 AM
Dracolyth is offline
Find More Posts by Dracolyth
Crash test pilot
Dracolyth's Avatar
United States, KY, Louisville
Joined Mar 2013
Yes it's still the stock one, ill be putting in a metal mount just as a heat sink.
Just sent it up with the Watt's Up meter on board and here are the results...
Dracolyth is offline Find More Posts by Dracolyth
Old May 11, 2013, 11:09 AM
Crash test pilot
Dracolyth's Avatar
Joined Mar 2013
I know I'm good on the amps, ESC is good for 67 burst, not sure about watts though.
Nano-tech 2.25 3s 65-130c
Turnigy C3536 1450kv
Turnigy Dlux 55 sbec ESC
10x5 apc TE
8min in the air
Radar showed 72mph
Ir gun read 130F on the motor
Old May 11, 2013, 11:54 AM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
wow 63A! I have never gone that high but then neither my motor or ESC are rated for that. interestingly, a heat sink is primarily what I use my metal mount for LOL
cmdl is offline Find More Posts by cmdl
Old May 11, 2013, 04:53 PM
roversgonemad is offline
Find More Posts by roversgonemad
roversgonemad's Avatar
United States, ID, Idaho Falls
Joined Feb 2013
I finally got my T-28 back together today! Since I ripped the bottom of the firewall out, I had to resort to the epoxied in plywood trick. I used a 5/32 Dubro nose wheel bracket and 1-1/4" steering arm. I ended up putting a sleeve on the nose gear to make it fit better in the Dubro bracket. It should be a pretty durable setup. Now I just need to adapt some bigger tires to it. The local RC field only has a grass strip, so the little T-28 tires aren't going to cut it very well. I picked up some ultra light Dubro wheels, but they are too wide for the gear. I'll have to use some other collars and likely extend the axles with some tube. I could also drill out the hubs a bit and just sink the retaining nut in a little. I don't which one I will do... I also might just look for some taller tires that will fit....
roversgonemad is offline Find More Posts by roversgonemad
Old May 11, 2013, 04:58 PM
valk_17 is offline
Find More Posts by valk_17
valk_17's Avatar
United States, GA, Woodstock
Joined Jun 2011
^^ the 2.75" dubro wheels with the white spokes fit perfectly, you will need some small collars to hold them off the uprights though. Not even a little bit scale, but they work like a charm for rough grass fields.
valk_17 is offline Find More Posts by valk_17
Old May 11, 2013, 08:54 PM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
i think mine are 2.5 robart and seem to work well on my fields grass strip.
walter3rd is offline Find More Posts by walter3rd
Old May 11, 2013, 09:14 PM
valk_17 is offline
valk_17's Avatar
Joined Jun 2011
Good looking plane, Walter. Are the shocks functional or just for appearance?
Old May 11, 2013, 10:12 PM
walter3rd's Avatar
Joined Aug 2012
thanks. just robart strut covers.
Old May 12, 2013, 12:55 AM
redman042 is offline
Find More Posts by redman042
United States, CA, Folsom
Joined Jan 2013
Today I flew the T-28 with my new 808 keychain cam for the first time. I mounted it on top of the canopy pointing slightly downward, using velcro. I do one loop in this video but otherwise kept it simple and worked on my touch-n-gos. I'll admit a few of the landings were pretty rough but those didn't make it into the video
T-28 with Keychain Cam (5 min 28 sec)
redman042 is offline Find More Posts by redman042
Old May 12, 2013, 09:19 AM
Chris Sweeney is offline
Find More Posts by Chris Sweeney
Joined May 2013
Anyone know where I can get one of these RTF? I can't find it online anywhere
Chris Sweeney is offline Find More Posts by Chris Sweeney
Old May 12, 2013, 09:51 AM
cmdl is offline
cmdl's Avatar
Joined Jan 2012
i didn't think they made them RTF. at least not anymore.
Old May 12, 2013, 10:11 AM
dsheikh573 is offline
Find More Posts by dsheikh573
United States, CO, Denver
Joined Apr 2013
BNF or PNP only. No RTF offered.
dsheikh573 is offline Find More Posts by dsheikh573
Old May 12, 2013, 10:54 AM
BlinkguY is online now
Find More Posts by BlinkguY
BlinkguY's Avatar
United States, NJ, Newark
Joined Nov 2005
Ready to fly is long gone... Best bet is to get a bnf and get a use dx4 or dx5 used really cheap on classified section rcg
BlinkguY is online now Find More Posts by BlinkguY
Old May 12, 2013, 11:08 AM
dstewart51 is offline
Find More Posts by dstewart51
When in doubt, gas it!
dstewart51's Avatar
United States, CA, Lake Hughes
Joined Jan 2013
Or if you not a Spektrum fan, the PNP, just add your flavor of RX/TX.
dstewart51 is offline Find More Posts by dstewart51
Old May 12, 2013, 11:19 AM
Damnandblastit is offline
Find More Posts by Damnandblastit
A disaster in the making.
United Kingdom, England, Selby
Joined Jan 2013
Just been online and ordered a new wing for the Cub, I intend to put it back to standard, lose the ailerons and regain the magic it somehow lost after fitting them and flattening the wing a little.
While I was at it, I ordered 2 sets of main wheels for the Parkzone Spitfire Mk IX for the Troj to allow a bit more ground friendly handling on grass / lumpy tarmac and to lift the (fragile) 3 blade prop away from the ground a little more.
I seem to remember someone mentioning these wheels are a little bigger than the Troj ones and are a straight swap.
Have I ordered the correct parts?
Found 2 new runways today also. Took the dogs to the local airfield today and was walking around the peri track. The farmer who uses the land for crops has moved some haybales and swept up the leftovers leaving an almost pristine section of tarmac about 100 mtrs long by 10mtrs wide without all the craters the main runways have. Orientation is East to West.
Runway 2...
Due to some mining subsidence there are major flood defences being constructed in the area as the old ones are no longer viable. One minor road is having to be moved.
As a result they have almost finished constructing a brand new road at the other end of the village. The original was lined with fences, a railway line and trees. It crossed the railway using a manned level crossing with gates, so no one used it much as it was quicker to go around.
The new one is on open flat farmland, billiard table smooth tarmac, has 2 straight stretches 100 mtrs long separated by a 90 degree bend so orientation is north / south and east / west. 5 minute walk from the house. Best thing is probably 5 cars a day will use it as it still joins the level crossing.
Things are on the up.
Do you think the ghosts of the 55 crews who failed to return from ops from the airfield will mind sharing a taxiway with the Troj?
Damnandblastit is offline Find More Posts by Damnandblastit
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
