! A big fat OMG! I couldn't stand that long, much less concentrate to fly...How long are you flying her per battery? I just might have to order some of these props for mine.... Looking good my friend, looking good ![]() John |
Latest blog entry: June 4th...the date that turned the tide...
John,
I can see that Ear-to-Ear Smile from all the way in Central Florida! ![]()
Latest blog entry: E-Flite Retracts & Amplified...
United Kingdom, England, Selby
Joined Jan 2013
Thanks for that JW. Let's hope that there will be considerably less wailing and gnashing of teeth over here. At least you have proof now that I DO listen to your advice and carry it out if I am at all able
it was so windy that i didnt mess around with top speed. tail wind would be cheating and head wind was really strong. i think on a calm day it would be pretty fast! 29 amps WOT static is a pretty strong pull. it felt very strong. much better than the mas 3 blade i use. pitch may be different and those HUGE paddles are grabbing lots on air. looks great as well. im a believer. ill be ordering more thats for sure!
@ Damnandblastit
I have a pair of PZ T-28's. I recently stuffed one nose first from a low level inverted flight incident . One of the best things about this plane is the ease of repair and plentiful supply of parts. Many say the bird flys even better after its been glued back together ![]() They have a week point and break the nose off the fuse. But they almost always glue back together quite well. From this, ![]() to this using nothing more then some glue, I did need to be replaced the motor cowl,
well, checked at one lhs and they only had the parkzone prop and the bf109 stock which i already have. off to the next lhs to hunt for the mas 10x7x3.
However, It's been a long time since I have flown without the most throws mechanically possible on the control surfaces and only at high rates. I'd start out with about 45% for the right hand and 20% on the rudder and adjust as you like. Get use to the stock throws and give them more when you feel ready. |
@dstewart - i didn't realize there was an lhs so close by - i usually go to tony's and ultimate. appreciate the tip. worst case scenario i'll order. @walter - i'll look for the MAS first and then try ordering from durafly. while your prop looks really promising i think the MAS beat it in lower current draw and i want to work my way up. |
| Thread Tools | |
| Article ParkZone T-28 Trojan RTF Review | Jim Walker | Electric Warbirds | 776 | May 12, 2013 02:01 PM |
| Official Parkzone P-51 Owners Thread - Part 2 | monitor | Parkflyers | 2601 | Oct 15, 2012 05:41 PM |
| Discussion Parkzone T-28 Trojan Thread | Edge767 | Parkflyers | 6527 | Jun 04, 2008 05:29 AM |
| Sold Parkzone T-28 Trojan, 480 960kv Motors (2) | Joe in Dublin | Aircraft - Electric - Power Systems (FS/W) | 4 | Jan 17, 2008 01:34 PM |
| Wanted Parkzone T-28 Trojan | webejpn01 | Aircraft - Electric - Airplanes (FS/W) | 4 | Oct 25, 2007 02:48 PM |
