Old Feb 24, 2013, 03:11 PM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
Originally Posted by Logan4169 View Post
Maybe not as much elevator travel as your Cub cmdl?
true. they're different planes. i'm still surprised that it couldn't even be leveled off but managed to get up in the air.
@BrownEyedFool - did he actually say "Oh sugar honey ice tea" or is that the censored version? LOL
cmdl is online now Find More Posts by cmdl
Old Feb 24, 2013, 03:37 PM
BrownEyedFool is online now
Find More Posts by BrownEyedFool
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
Originally Posted by cmdl View Post
how did he even take off? most tail heavy i have ever tried a plane was my cub. and she took off straight up, literally, like a rocket. i could fly her level without changing trim (about 80% down elevator) but i didn't think it was possible to take off with any more tail heavy than straight vertical.
We think when he pulled sharp elevator to lift off that caused the battery to slide, so he was airborne by the time it was tail heavy.
Either way it should be fixed now.
That is the censored version I figured if it's clean enough for a Pixar movie it's fine here.
BrownEyedFool is online now Find More Posts by BrownEyedFool
Old Feb 24, 2013, 03:43 PM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
aah. ok, now i get it. thanks.
Old Feb 24, 2013, 03:47 PM
Justwingit is online now
Find More Posts by Justwingit
We got some flyin' to do!
Justwingit's Avatar
United States, TX, Fort Bliss
Joined Apr 2012
Mine's dirt stock...I guess I'm boring...
Of course, I also have no C/G issues and therefore don't crash because of it....which is also pretty boring
That's the only reason I'm always a strong advocate of leaving things stock, so that newer pilots reading the thread don't get the idea that they have to mod away to get the model to fly correctly. It'll fly just fine bone-stock, right out of the box. It'll also do any aerobatic maneuver you want it to do, save for 3D flying. Loops, rolls, Cubans, half-Cubans, and inverted half-Cubans, all with ease and plenty of power to spare. I've also had mine clocked on a RADAR gun at 68 MPH, on a 20C 3S2200 with stock power-train and prop, in straight and level flight.
My only mods consist of bolt-ons: I added larger Dubro wheels because I fly alot from grass, and a 10x7x3 MAS prop because I like the additional thrust. I don't believe the prop adds any top-end, but it certainly makes her fly more scale at lower speeds....she just pulls nice and graceful over the top of some humongous loops and performs very nice, slow, scale rolls. Put 'em together and you have some of the prettiest half-Cubans and inverted half-Cubans
But, mod away if you wish; that's the beauty of this model...it's an RC workhorse! I prefer to keep mine stock.
"Less stuff to fiddle with and repair means more time in the air" !
John
Justwingit is online now Find More Posts by Justwingit
Old Feb 25, 2013, 08:13 AM
Joined Sep 2011
The only mod I had ever wanted to do was add a slight motor upgrade and use 2200 packs. Most of my mods have come as a result of crashing. It does snowball a bit, I upsized the nose wheel to provide better grass runway clearance for the stock prop, it tends to mow the grass if it hasn't been freshly mowed.
It's my trainer plane, I just need to do a lot more touch and go practice and get consistent reps with the rudder. Then I have 952 other planes to fly or dream of.
Old Feb 25, 2013, 08:16 AM
Justwingit's Avatar
Joined Apr 2012
Ain't that the truth....!
You must mean 4S2200s as the T-28 will fly all day long on 3S2200s....
Old Feb 25, 2013, 08:38 AM
Joined Sep 2011
No I meant 3s 2200s, since true bone stock is flying with a 3s 1800, though many many peple go to 2200s, I went with the same usage as the previous poster.
Old Feb 25, 2013, 10:01 AM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
but is using a different batt truly a mod? in that case i have never flown a stock t28. i even use a different rx since i have the pnp.
Old Feb 25, 2013, 10:03 AM
Logan4169 is offline
Find More Posts by Logan4169
Joined Nov 2011
Not when it is one of the two recommended in the manual.
Logan4169 is offline Find More Posts by Logan4169
Old Feb 25, 2013, 10:10 AM
Justwingit's Avatar
Joined Apr 2012
Ah, I understand now...
Well, I'll be bold and say that most folks fly their T-28's with a 3S2200mAh battery of varying C ratings. I don't think that using a 2200 is really a mod per se, as there really is no canopy or battery compartment modification necessary for the 2200 to fit. Most 2200's today are smaller than yesterday's 1800's, which the T-28 was originally designed to fly on .
John
Old Feb 25, 2013, 10:11 AM
Justwingit's Avatar
Joined Apr 2012
Originally Posted by logan4169 View Post
not when it is one of the two recommended in the manual.
+1
Couldn't agree more...
Old Feb 25, 2013, 10:28 AM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
Yes actually. I fly mine with both and really don't notice a change in CG as a result. I used to use the Parkzone 1800 battery (green one) but when it puffed, I switched to a Turnigy 1800 mah 25c and then to a Hobby People 2200 mah 20c and found no difference in CG. I can fly about 6 minutes on the Turnigy and about 8 on the Hobby People. BTW - I fly mine pretty much bone stock too with the only mod being the additon of the Parkzone 3 bladed prop. I like the way she flies on that as opposed to the stock prop. Looks more scale too.
chucksolo69 is offline Find More Posts by chucksolo69
Old Feb 25, 2013, 10:36 AM
Joined Nov 2011
My T-28 is heavily modified to lighten it. (So I guess I could also say that it is"lightly modified"?) I normally use 3s 1300 mAh 65C batteries, but it is capable of flying anything from 3s 1000 mAh to 4s 3200 mAh. The biggest that I will ever fly it with is a 2250 mAh 4s though.
Old Feb 25, 2013, 03:19 PM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
2500 gens ace 3s make her quite the power house. thats plenty for me.
walter3rd is offline Find More Posts by walter3rd
Old Feb 25, 2013, 03:28 PM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
What discharge ratings?
Do you have a link to a good deal purchase?
PittSpecial is offline Find More Posts by PittSpecial
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
