Old Dec 09, 2012, 01:26 AM
Justwingit is offline
Find More Posts by Justwingit
They call me Lipo.....
Justwingit's Avatar
United States, TX, Fort Bliss
Joined Apr 2012
Clear packing tape on mine.....
Works like a charm
Justwingit is offline Find More Posts by Justwingit
Old Dec 09, 2012, 12:06 PM
marksp is offline
Find More Posts by marksp
build, fly, crash...repeat
marksp's Avatar
United States, WA, Redmond
Joined Apr 2011
Originally Posted by walter3rd View Post
thoughts on the master airscrew 3 blade for the t-28? i am running the pz corsair 3 blade and love it! not a fan of the stock 2 blade and was wondering if folks like the master 3 ? i prefer the thrust of the 3 blade and am not concerned with top speed as i am getting the extra 300 from santa! the blades look quite narrow compared to the parkzone 3. thoughts? looks like for a given revolution it would grab less air per blade creating less thrust? am i correct in thinking this way? thanks for the imput. i have heard good and bad regarding both 3 blades. thanks, walt.
Here's a pic of my T-28's with the MAS 10x7x3 (painted tips yellow). I also tried the the PZ 3 blade, but preferred the MAS. Flies well and looks even better!
Have to say, after this picture, I switched both to the APC 10x10E which works great!
marksp is offline Find More Posts by marksp
Old Dec 09, 2012, 01:46 PM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
squeezed in 4 flights today as the rain let up a bit. first landing coming in nice and slow picture perfect not much wind to speak of, touch down on the baseball infield dirt ever so gently... dig in and flip! WHAT! i forgot about the soft ribbon that runs through the middle after rain. no damage but shocked the hell out of me! next 3 landings spotted a harder patch and was fine. still a bit soft so roll out was minimal. wow! lesson learned the hard way. after rain touch downs must be spotted on the hardest areas. and with 2.5 tires. stock would have been even worse. still a fun time.
walter3rd is offline Find More Posts by walter3rd
Old Dec 09, 2012, 04:26 PM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
Originally Posted by BlinkguY View Post
what prop you use man?
Finally got a chance to put my T28 on the watt meter. Using a fully charged Gens Ace 2200 mah 30C 3S battery (the battery has about 45 cycles through it), on the Turnigy 3536 1100kv motor with the stock 9.5x7.5 prop I got 38.37 amps and 442.72 watts.
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Dec 09, 2012, 10:08 PM
GCplane is offline
Find More Posts by GCplane
GCplane's Avatar
Manassas, Virginia
Joined May 2008
"And yes, I was holding lots of down elevator to keep her from climbing to the moon"
If the CG was moved back to the factory recommendation there would be no need for lots of down elevator and the plane would fly faster.
GCplane is offline Find More Posts by GCplane
Old Dec 09, 2012, 11:32 PM
XtalHunt is offline
Find More Posts by XtalHunt
United States, TX, Austin
Joined Sep 2012
Whose Tx xtal do you use in the ZX10 radio?
This tx is supposedly "shiftless", How do I take this sucker from channel 54 to 32 and get all my existent receivers to play?
XtalHunt is offline Find More Posts by XtalHunt
Reply With Quote  (Disabled)
Old Dec 10, 2012, 08:12 AM
Justwingit's Avatar
Joined Apr 2012
Unless I'm mistaken, each "channel" has an associated rcv'r...note that channel 54 is 72.67mHz. Channel 32 is probably a different freq.
So you'll have to find a "channel 54" rcv'r...at least that's my understanding. My old Super Cub is flying on 72 mHz and works the same way.
Oh, and my T-28 will cruise around happily all day long, hands-off at 50%. I mean, to the point of flying outta sight if you let it; it's that stable and trimmed. Although it's pilot's preference, normally that's where models are trimmed. They'll pretty much all go into a climb when running full throttle....it's that whole thrust thing....even full-sized planes do it. The pilot counters that by inducing a little down elevator. Or trim. Either way, it's not a result of poor CoG.
Still proud of my little sky scorcher...!
Old Dec 10, 2012, 11:19 AM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
I have 100+ flights on mine now and she flies like new. I have replaced the rear stab and elevator assembly because the "skin" was coming off, but she is fine and the first warbird I put up when I fly.
chucksolo69 is offline Find More Posts by chucksolo69
Old Dec 10, 2012, 04:54 PM
Justwingit's Avatar
Joined Apr 2012
Someday I gotta swing by your field Chuck...
I usually visit my father in San Diego about every other month...
Where do you fly?
Old Dec 10, 2012, 07:12 PM
walter3rd's Avatar
Joined Aug 2012
im at 127 flights and she is a joy to fly. going to be getting the extra 300 from santa so she will get to rest a bit after that purchase. however the cargo van will accomadate both quite nicely so im sure both will be going to the field either way. only problem... im going to need more batteries! i go through 12 with the t-28 each trip to the field and the 300 will need some higher C batteries ideally. ill be chucking in my t-28 batts to start and see how she flies with those. i can see im going to need a bigger hobby room soon... walt.
Old Dec 11, 2012, 08:43 AM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Warm up plane
The T-28 is always my warm-up plane.
Always predictable and stable flyer...must be a male plane!!!
RGS2010 is offline Find More Posts by RGS2010
Old Dec 11, 2012, 08:51 AM
walter3rd's Avatar
Joined Aug 2012
female planes are eratic and unpredictable for sure!
Old Dec 11, 2012, 09:16 AM
Joined Apr 2011
We fly at the Oceanside Senior Center on Rancho Del Oro Rd which is right off of Oceanside Boulevard. You are definately welcome. We have permission to fly there and all of us are AMA anyway so that keeps the Senior Center staff comfortable. It is really a great place to fly. We use an easement that is paved and is dead ended on either end going from West to East as a runway. There is no traffic other than our planes. Usually we have 6-10 fliers on any given Saturday and Sunday. They are a great bunch of guys. Our oldest is 83 and youngest is 45.
Old Dec 11, 2012, 09:29 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
I'm trying to think back a few years but I think those had plug in crystals in them. pull the cover and you will see them. I have since tossed all of mine.
robj is offline Find More Posts by robj
Old Dec 11, 2012, 09:41 AM
PittSpecial is online now
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Bad Idea! Bind Plug Jammed!
I must have used too much force in removing the freaking Bind Plug out of the AR600.
I am serious, I am done with Spektrum!
Did not have any response on the model after the first turn!
Park Zone T-28D Crashes due to Damaged AR600 Blind Pins 12-11-2012 (2 min 30 sec)
PittSpecial is online now Find More Posts by PittSpecial
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
