Old Dec 08, 2012, 09:26 AM
GCplane is offline
Find More Posts by GCplane
GCplane's Avatar
Manassas, Virginia
Joined May 2008
Select thread tools. Then show attachments in this thread. Looking at the photos can quickly find items of interest. There are some photos of bashes that turned the T-28 into a taildragger.
There are other helpful photos you will see along the way. When you find an interesting photo select post to jump to the post that discusses the photo.
GCplane is offline Find More Posts by GCplane
Old Dec 08, 2012, 10:13 AM
Bugbitten is offline
Find More Posts by Bugbitten
United States, KY, Madisonville
Joined Mar 2011
Just a reminder. Anyone who uses tape for hinges. My T-28 went down Wednesday.
Aileron failed.
The hinge tape was lying on the ground next to the wreck. Checked the other hinges... tape just peeled off like the adhesive had dried up. Blenderm. Plane is several years old.
Bugbitten is offline Find More Posts by Bugbitten
Old Dec 08, 2012, 10:23 AM
BlinkguY is offline
Find More Posts by BlinkguY
BlinkguY's Avatar
United States, NJ, Newark
Joined Nov 2005
I hate when that happens..
BlinkguY is offline Find More Posts by BlinkguY
Old Dec 08, 2012, 10:33 AM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
Originally Posted by davidterrell80 View Post
Here's some design data on conventional "tail dragger" landing gear.
http://www.aerospaceweb.org/question/design/q0200.shtml
thanks, that gave me the general idea of where to place the gear. its also what was mentioned by the little i could gather from earlier posts and some other threads i searched around.
thanks, i tried that. all i found was pics of trojans on trikes.
cmdl is offline Find More Posts by cmdl
Old Dec 08, 2012, 10:49 AM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Aileron failed.
First, I am very sorry that your Trojan Crashed.
Second, I am very curious as to why you think the Aileron Failed? Are you saying it was the one of the Aileron Servos? Or that the Molded "FOAM" Hinged failed at that control surface on the wing?
My NAVY T-28 Trojan is about 6 years old now, one of the very first Trojan T-28 that Park Zone released and came with the older E-Flite 25-AMP non-switch mode ESC plus with the sorry 72-Mhz FM Receiver. The Airframe is still intact and never have my model exhibit any issues with any of the "Molded Foam" hinges anywhere on the wing.
Now, when the model crashes hard back to mother Earth, there is possibilities that Molded Foam / Tape etc... will rip / come off.
PittSpecial is offline Find More Posts by PittSpecial
Old Dec 08, 2012, 11:17 AM
Joined Mar 2011
The molded foam hinge showed cracks a year ago and I taped the hinge.
The servo did not fail. The crash was nose in from level flight to hard roll. No damage to wing other than flapping aileron.
Old Dec 08, 2012, 11:27 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Interesting,
I almost always check all surfaces on my older T-28 Trojan and never have I come across any "Cracks" on the Molded Foam Aileron Hinges of any wing side.
Could it be possible that your model had a previous encounter with mother Earth?
Old Dec 08, 2012, 03:27 PM
Joined Mar 2011
Interesting,
Several over the past few years.
I'm just saying .... if you have a taped hinge, check the tape.
Old Dec 08, 2012, 03:58 PM
CF105 is offline
Find More Posts by CF105
Arrowhead
Joined Dec 2010
Good advice to always check all the control surfaces before flight!
CF105 is offline Find More Posts by CF105
Old Dec 08, 2012, 04:35 PM
GCplane is offline
GCplane's Avatar
Manassas, Virginia
Joined May 2008
Cmdl,
Hre is a link that has lots of photos of Bashed planes. Some used to be a T-28.
Notice the Skyraider that used to be a t-28 (before the bash).
http://www.rcgroups.com/forums/showthread.php?t=1104830
Old Dec 08, 2012, 04:54 PM
cmdl is offline
cmdl's Avatar
Joined Jan 2012
Cmdl,
thanks very much GCplane. still going through some of the threads listed on DogFly's thread, including the Skyraider conversion. i noticed that on the Bearcat conversion he uses the same LG mounts. that's specially helpful to know since i believe that may entail most of the work and i was spending most of my time wondering if folks used some other plane's LG mounts.
i appreciate the material. i am considering giving this a shot in a couple of weeks when i have some vacation coming up.
Old Dec 08, 2012, 09:15 PM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
thoughts on the master airscrew 3 blade for the t-28? i am running the pz corsair 3 blade and love it! not a fan of the stock 2 blade and was wondering if folks like the master 3 ? i prefer the thrust of the 3 blade and am not concerned with top speed as i am getting the extra 300 from santa! the blades look quite narrow compared to the parkzone 3. thoughts? looks like for a given revolution it would grab less air per blade creating less thrust? am i correct in thinking this way? thanks for the imput. i have heard good and bad regarding both 3 blades. thanks, walt.
walter3rd is offline Find More Posts by walter3rd
Old Dec 08, 2012, 09:26 PM
Joined Mar 2011
Try a hk durafly prop for T-28. You'll need a prop reamer, but best prop I have found
Old Dec 09, 2012, 01:22 AM
Justwingit is offline
Find More Posts by Justwingit
We got some flyin' to do!
Justwingit's Avatar
United States, TX, Fort Bliss
Joined Apr 2012
Had my trusty old T-28 down at the dry lakebed today and got her clocked at 68 MPH on RADAR....and that's on an all stock setup! Not bad for a "trainer"
My buddy flys an Air Force version and somehow got his to 72 MPH on the RADAR gun...! I'm thinkin' (no joke) he was slightly in a dive and levelled out right before hitting the gun. I started my run fairly far out and gunned her about 20-30 feet off the deck. Looked great zipping by at that altitude and then doing a nice climbing bank off to the left after she passed the RADAR.
And yes, I was holding lots of down elevator to keep her from climbing to the moon
Justwingit is offline Find More Posts by Justwingit
Old Dec 09, 2012, 02:20 AM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
My elevator hinge tore a few months ago from hangar rash / during transportation in my car. I used Blenderm tape to reconnect. Just checked and the tape is still holding fast.
Left Coast DJ is offline Find More Posts by Left Coast DJ
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 889 Nov 08, 2015 04:45 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 05:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 06:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 02:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 03:48 PM
