Old Nov 30, 2012, 02:17 PM
BlinkguY is offline
Find More Posts by BlinkguY
BlinkguY's Avatar
United States, NJ, Newark
Joined Nov 2005
alright!! thanks!
BlinkguY is offline Find More Posts by BlinkguY
Justwingit is offline
Find More Posts by Justwingit
We got some flyin' to do!
Justwingit's Avatar
United States, TX, Fort Bliss
Joined Apr 2012
Look up a few earlier posts (on this page) and Pittspecial (Carlos) has posted his choices....seems to be the prevailing sentiment amongst folks putting three bladers on their T-28's...
Ooops! Carlos beat me to it; we were typing at the same time....he won
Justwingit is offline Find More Posts by Justwingit
Old Nov 30, 2012, 02:29 PM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Yep, just checked and mine is 10 X 7 X 3 Master Air Screw. I've had the same prop for over a year, it's tough.
RGS2010 is offline Find More Posts by RGS2010
Old Nov 30, 2012, 02:43 PM
BlinkguY is offline
BlinkguY's Avatar
Joined Nov 2005
Originally Posted by PittSpecial View Post
Select your liking:
http://masterairscrew.com/3-bladeseries.aspx
I believe it has been posted for those using this brand 10 X 7 X 3.
Assuming the STOCK Park Zone 480 Brushless.
yeap.. thats the one i j ust ordered from ebay.. cheaper shipping
Old Nov 30, 2012, 05:00 PM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
considering the stock prop is 9.5 i didnt want to go 10 for lack of clearance so i got a 9. will post results when i get her in the air.
walter3rd is offline Find More Posts by walter3rd
Old Nov 30, 2012, 05:03 PM
1Pilgrim is offline
Find More Posts by 1Pilgrim
Look ma, no hands!
1Pilgrim's Avatar
United States, WI, Sheboygan
Joined Aug 2011
So the Dubro 2.5" wheels also get me the extra ground clearance for the 10x7x3 MAS prop - sweet! Is it a simple bolt-on or will I need to mod it?
1Pilgrim is offline Find More Posts by 1Pilgrim
Old Nov 30, 2012, 05:05 PM
BlinkguY is offline
BlinkguY's Avatar
Joined Nov 2005
i just got my 2 APC 9x9 and my turnigy G10 motor... ill make her scream now using stock ESC... Ecalc tells me ill be below 30 amps static, so flying will be around 26 or even 25.... lets see.. WOHOOO
Old Nov 30, 2012, 06:09 PM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
Hi,
My motor had a mechanical failure 6 seconds after take off and i was lucky to have enough altitude and airspeed to make an emergency landing. Poor motor.
So I looked up for a replacement motor and I was completely shocked to see that it costed about 40 dollars for a plastic motor. I know hobbyking had good stuff for cheap. Does anyone here know good cheaper alliterative motor i can get that will fit right on the motor mount and have the proper shaft length?
thanks
shelby
Airplanekid333 is offline Find More Posts by Airplanekid333
Old Nov 30, 2012, 06:19 PM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
I am sure it is the APC "Sport" 9 X 9 2-blade. If it is then, you need good RPMs at the Motor Output shaft to take advantage of that "higher Pitch" other wise you will be at the lower end of the propeller efficiency.
Additionally, the hub is right about the same thickness as the Park Zone propellers but, anything large in diameter starting with 10 inch Sport you will have an issue trying to tighten it with the STOCK Park Zone prop adapters.
The comment about clearance of using the MAS 3-Blade 10 X 7 X 3 is not valid as I have the STOCK Wheels on my T-28D and I have not changed out any wheels and do not have any issues with propeller strikes on the ground nor grass field.
Guapo.
PittSpecial is offline Find More Posts by PittSpecial
Old Nov 30, 2012, 06:21 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Originally Posted by Airplanekid333 View Post
Hi,
thanks
shelby
Shelby,
First, what kind of flying do you want to see out of your T-28? I ask since now you have to change out the motor and this is an opportunity to install something with either more Kv for added airspeed or keeping it the same performance.
Guapo
Old Nov 30, 2012, 07:24 PM
BlinkguY is offline
BlinkguY's Avatar
Joined Nov 2005
Hi,
thanks
shelby
Park 480 great motor man..... Way more power...g10
Old Nov 30, 2012, 07:34 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Agreed, the 1020Kv
http://www.e-fliterc.com/Products/De...rodID=EFLM1505
walter3rd's Avatar
Joined Aug 2012
i have the 2.5 wheels but still like the extra clearance of a 9 prop. i was running a 9 corsair prop and liked the extra room for the occasional bumping landing due to wind, crappy landing zone surface, tall grass etc. i have broken the 9 blade on rough landing due to ground strike. im hoping its a rare thing but i dont need it any closer than stock prop. guess i could get both and have the option to switch to see which i like best.
Old Nov 30, 2012, 07:43 PM
Justwingit's Avatar
Joined Apr 2012
So Mr. Guapo,
Is that a direct bolt in or would I have to do some minor adjustments...
Old Nov 30, 2012, 07:54 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Originally Posted by Justwingit View Post
So Mr. Guapo,
I had thought, someone posted a picture of them using this same exact motor?
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
