Old Nov 20, 2012, 01:14 PM
BlinkguY is online now
Find More Posts by BlinkguY
BlinkguY's Avatar
United States, NJ, Newark
Joined Nov 2005
damm
BlinkguY is online now Find More Posts by BlinkguY
Old Nov 20, 2012, 04:08 PM
dbergmann is offline
Find More Posts by dbergmann
Joined Sep 2006
Looking for some motor help. My T-28 has stock motor and ESC is 38 amp Castle Creation Thunderbird. No crash and good flight yesterday and now motor has about half power max. Have old motor and same thing. Reprogrammed ESC no help. Any ideas on problem or how to diagnose it. Do I need new ESC? How would I know?
Thanks, Dan
dbergmann is offline Find More Posts by dbergmann
Old Nov 20, 2012, 04:16 PM
BlinkguY's Avatar
Joined Nov 2005
definetly esc problem i think
Old Nov 20, 2012, 04:17 PM
BlinkguY's Avatar
Joined Nov 2005
try a different ESC.. and you will see. if still.. then the motor is the problem
Old Nov 20, 2012, 04:50 PM
theiting is offline
Find More Posts by theiting
Joined Mar 2011
CG Measurement
What is the proper CG and where is it measured from on the leading edge?
Parkzone says 2.5" back when measured against the fuse, but is that in a straight line or following the curvature?
If I move 4" out onto the wing what should the CG be?
I assume the plane should be inverted when checking CG.
Thanks for the help!
theiting is offline Find More Posts by theiting
Old Nov 20, 2012, 05:57 PM
rdcskkrose is online now
Find More Posts by rdcskkrose
TEAM HILLBILLY
rdcskkrose's Avatar
USA, CO, Highlands Ranch
Joined Apr 2009
Originally Posted by Justwingit View Post
! I'm sorry, but I thought I read "3300 4S" Man, that plane must scream! What sized motor and prop are you running. And have you ever had a Radar gun on that bad-boy?
QUOTE=robj;23317632]4yo T-28 does it again! Aerial recon so I could find another plane. With all the briars in this thicket, doubt if I could have found it on the ground.
Power-15, 11x7. Yes. Clocked at 88 with calm and on the straight & level both directions. Flybud's 28 we clocked at 109. Different setup.
SWEET! Google Earth works too.
rdcskkrose is online now Find More Posts by rdcskkrose
Old Nov 20, 2012, 07:13 PM
Justwingit is online now
Find More Posts by Justwingit
We got some flyin' to do!
Justwingit's Avatar
United States, TX, Fort Bliss
Joined Apr 2012
It's alive, it's aliiiive !
Those are some extremely impressive numbers...EDFs have a hard time beating that...
Just another example of the T-28's greatness
Keep 'em flyin'
Justwingit is online now Find More Posts by Justwingit
Old Nov 20, 2012, 08:53 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Don't think google earth updates daily. At least this map is very old.
robj is offline Find More Posts by robj
Old Nov 20, 2012, 10:33 PM
asosestrom is offline
Find More Posts by asosestrom
United States, CA, Santa Rosa
Joined Mar 2011
Rough day at the park. The T was flying full throttle inverted and snagged the tail, switchback clipped a tree and I held the striker to long in an inverted flat spin.
asosestrom is offline Find More Posts by asosestrom
Old Nov 20, 2012, 11:28 PM
Justwingit's Avatar
Joined Apr 2012
I'm so, so sorry...."Oh the humanity!"
We've all been there...perhaps not quite to that level of absolute detruction, but we've all been there...
On the bright side, I suppose this opens the door to finding new aircraft under the tree..
Old Nov 21, 2012, 01:35 AM
didge is offline
Find More Posts by didge
Foam, foam on the range....
didge's Avatar
Adelaide, Australia
Joined Feb 2009
In a straight line. (But there wouldn't be very much difference)
The CG will be the same. The distance back from the leading edge at 4" out, to the balance point will be different, of course, but that will be easy for you to measure with a couple of rulers.
Yes.
didge is offline Find More Posts by didge
Old Nov 21, 2012, 09:23 AM
campbellj is offline
Find More Posts by campbellj
campbellj's Avatar
United States, FL, Port St Lucie
Joined Jan 2011
Anyone know the diameter of the pushrods on the T-28? I want to order some more to put flaps on mine and would like to use the same size rod that's already on it, I just don't have any calipers to measure it. Also what is a good size of carbon fiber rod to use to reinforce the wing? I'm switching over to a 4s setup and want to keep the wings from folding.
campbellj is offline Find More Posts by campbellj
Old Nov 21, 2012, 09:30 AM
robj is offline
robj's Avatar
Joined Nov 2008
Yes.
I think in the old manual the CG was 1" out from the fuse, then 2.5" back. This got it last the little return that is on the front of the wing.
Old Nov 21, 2012, 10:23 AM
Bugbitten is offline
Find More Posts by Bugbitten
United States, KY, Madisonville
Joined Mar 2011
Try this set - http://www.horizonhobby.com/products...t-p-47-PKZ5315
Bugbitten is offline Find More Posts by Bugbitten
Old Nov 21, 2012, 10:51 AM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
ouch. sorry to see that.
cmdl is offline Find More Posts by cmdl
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 892 Mar 20, 2016 09:18 AM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 01:34 PM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
